Daphne Singe American Laser games
sonicboom88
Hi guys wondering if you could help I cant get American Laser games to work in HLHQ Not too sure How to get it to work I have read rons tutorial but still no luck :(.
Hyper Helper Ready To Help
Ok got alg to work but having problems setting up controls my dolphin bar is not working too good but it fine with action max any ideas?
  • 1 month later...
how did you get it to work i can get it to work using the bat files out of hyperlaunch but not in hyperlaunch hq
Bump
Having trouble with ALG?
Be sure they are not the exe games. That they are the ripped games and the guide should work just fine.
Please post your HyperLaunch.log file with the Logging Level set to Troubleshooting.
Thanks,
Ron
ive got mine working completly working
make sure your configurations are correct to which location
mine is set to bat
cd data
cls
@daphne.exe singe vldp -x 800 -y 600 -fullscreen -noserversend -framefile singe/maddog/frame_maddog_cdrom.txt -script singe/maddog/maddog_cdrom.singe
this is the only way to help you guys. is to give a copy of mine with out video files etc and zip it up for download. all you have to do is replace your files within the single folder. 1.70mb in size small in the ftp under my name Daphne Singe.zip
(Midlife crisis) some have hot rods, some have gold chains, I have arcade machine with hyperspin.
mine is set to bat
cd data
cls
That's using the bat file?
It can easily be done with the bat files. If you rename the txt and singe files to the rom names and point HyperLaunchHQ rom path to your singe\singe directory it should work just fine.
Thanks,
Ron
Thanks,
Ron
i just create xml of bat files and your good to go!
how do i set the logging level to troubleshoot?
It's explained in this post. A good read for everyone, if they have not already.
http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
Thanks,
Ron
if you just want the bats to run use PC games change art from American laser games to PC Games.
enable bat files and your good to go
thats how i got around to set it up.
