sonicboom88 Posted November 22, 2014 Posted November 22, 2014 I have just set up pcsx2 and when I play gta vice city I get a slight stutter and sound goes strange could someone help me with this? I have radeon Hd6670 graphics card 16 gb ram AMD Athlon X4750k cpu. Hyper Helper Ready To Help
zxthehedgehog Posted November 22, 2014 Posted November 22, 2014 Hmm... Is this a problem with all games or just GTA Vice City? Either way, I'd try going into Config->Audio->Plugin Settings and changing the Synchronizing Mode setting to Async Mix. It may break some games, but should help your issue. If it doesn't, try a different SPU plugin, and see if it helps.
sonicboom88 Posted November 22, 2014 Author Posted November 22, 2014 thanks that fixed sound issue but still a drop in the frames . Hyper Helper Ready To Help
eezetee Posted November 22, 2014 Posted November 22, 2014 fame, Try checking to see if that game requires and speed hacks or special settings. I had the same issue previously.
HazzardActual Posted November 22, 2014 Posted November 22, 2014 are you using the SPU2-X plugin for audio? check the box in Sync mode, i bet you its set to time stutter. But ive noticed on some games like hot shots golf 4, its stuttering all the time. Im not sure if that because my computer isnt good enough or if its just the game
sonicboom88 Posted November 22, 2014 Author Posted November 22, 2014 it says it in async mix should I change it? Hyper Helper Ready To Help
sonicboom88 Posted November 22, 2014 Author Posted November 22, 2014 tried hacks that makes it too fast. Hyper Helper Ready To Help
eezetee Posted November 23, 2014 Posted November 23, 2014 fame, you can slow down the hacks. There is some slider bar you can move from 0 to 3. Try other numbers. I had hte same issue also, make sure you don't press the TAB button which puts it in overdrive mode. When I hit tab my frame rate jumps from 60 frames/sec to 118 frames/sec
sonicboom88 Posted November 23, 2014 Author Posted November 23, 2014 Thanks think I will make do for now getting used to it its only a slight drop in the frames Hyper Helper Ready To Help
