Pro Level Support Needed
dytryn
I cannot get this program to work for me. I also picked up a X-Arcade Tankstick + Trackball but it is not being fully recognized. So, is anyone interested in being paid to remote in to my system and fixing the issues (unless you are local to the LA area)?
Thanks
Thanks
Hi and welcome to the Forums!
There are probably a few around here that will help you for pay... But there will be a ton more here that will help out if you give a little more information. ;)
Please read this post if you would like more help: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
Thanks,
Ron
Basically, I copied a friend's HD and he said it worked perfectly on his end with Hyperspin 1.0. Hyperspin launches and the wheel appears and the various game systems appear and rotate when I use the arrows on the keyboard and rotate in some directions with the right tankstick but not the left. HyperHQ loads just fine but no matter what I try, Hyperlaunch will not load. It says there is an error loading the DLL. So, I tried loading the newest Hyperspin downloads and that made matters worse. Now the wheel just rotates super fast when the mouse moves and the tanksticks are not recognized even though I set them up in HyperHQ. This is the least intuitive program I have ever used (worse than Photoshop). I'm totally drained and all I want to do is play some games!
Hypespin 1.0 runs on Hyperlaunch 1 (not sure if it runs Hyperlaunch 2). the latest version of Hyperlaunch (1.3.2) only runs on
RocketLauncher.0. The folder structure is not compatible.
if your friends drive is on Hyperspin 1.0, you are going to need to copy it again. Hopefully you have a backup.
download teamviewer and pm me the user id and password. It should be an easy fix
Thank you! Will do tonight.
I kept both in separate directories just in case.
Tried sending pm but not sure if it sent since it is not showing in my sent items.
I got it. Are you ready?
Your setup isnt salvageable. I'd start with a fresh install of HS and hyperlaunch. Just save your media and emu files
Instagram : baddeolv
Facebook : Brian Addeo
