dreamkey56 Posted December 1, 2014 Posted December 1, 2014 Hello guys. I built a widenody cab, and use the standard Siemens contactors usually used. 24 Volts. They sound fine, as long my cab is open. But as soon as I put the glas on, and close all doors, the flipper contacors sound and feel very weak I did this mod with the steel washer in the contactors, but still not loud enough. Is there a way to increase the sound, and the dorce feedback of the contactors? Or is there a better way, instead of these Siemens ones? Thanks, HP
maxxsinner Posted December 5, 2014 Posted December 5, 2014 What is the part number of your contactors dreamkey56 Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
maxxsinner Posted March 10, 2015 Posted March 10, 2015 Sprecher & Schuh CA7-9E-M 24 For contactor models that are confirmed to work well - http://www.hyperspin-fe.com/forum/showthread.php?18867-All-about-contactors Electropin - Enough lights to land a jet on an aircraft carrierHigh Voltage Pinball - Cause one build just wasn't enough Voltek Arcade - Funglo pedestal style mame cabinet Pinball Electrical Tutorial - Wire All Your Bling With Confidence and Fewer House Fires
