Sega saturn help ssf
ryan666
help i get a error using hyperlaunch 2.0 useing ssf test version by djvj 1.1 modual error call to non existant function line 43 :ssfini:=checkfile (emupath)."ssf.ini
Thank you for the bug report. While we get this sorted out, please use this older module version with slight modification:
; Sega Saturn
; SSF Test Verson 07-09-2011
; by djvj
; 1.0
; Info:
; Make sure your path_to_daemontools in Settings\settings.ini is correct
; romExtension should be mds,cue,iso,cdi,nrg
; In the SSF.ini, make sure you have your CDDrive set to whatever number you use for your games. 0 is most likely your hardware drive, while 1 may be your virtual drive (depending on how many you have) SSF's GUI did not let me set the virtual drive, had to edit the ini directly
; For correct fullscreen operation, make sure these settings are set in Option->Screen: Enforce Aspect Ratio (Fullscreen) and Full Size
; If you are getting clipping, turn on VSynchWaitFullscreen, or set it to 1 in the ini
; On first launch, press Alt+Enter to enter fullscreen mode. Then exit the emu. Next time you launch it, it will be fullscreen.
; This gets rid of the emu window that pops up on launch
Gui +AlwaysOnTop -Caption +ToolWindow
Gui Color, 000000
Gui Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%, HSHIDE
Process, Close, Xpadder.exe
RunWait, "%daemonToolsPath%" -mount 0`,"%romPath%%romName%%romExtension%", Min
Run, %executable%, %emuPath%
Sleep, 3000
Gui, Destroy
WinShow, SSF Ver0.12 beta R1
Process, WaitClose, %executable%
ExitApp
CloseProcess:
return
Copy the above text into Notepad and save as "Sega Saturn.ahk" in your Sega Saturn module folder.
Once we have an update, it'll be uploaded to HyperList or we'll make specific mention of any recommendations here within your thread.
<em class='bbc'>"But does one ever truly have a choice? One can only match, move by move, the machinations of Fate, and thus defy the tyrannous stars."</em>
That error happens most likely because you're using an older hyperlaunch version, and that's why the checkfile function is missing.
Update to 2.13 and everything should be fine.
i am running 2.13 had no prob with all the other systems . thank you for the help this community kicks ass i wilol try that modual
That function was moved into hyperlaunch on v2.09. Please make sure you are using the latest hyperlaunch before making threads on errors.
http://www.hyperspin-fe.com/forum/showthread.php?p=148184&highlight=checkfile#post148184
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
yep that worked fine thank you but i cant get damion tools lit to find the direct drive just scsi ones dose that matter i will figur it out
  • 2 months later...
anyone know what this error is in SSF IDirect3D9::CreateDevice0 error
File : ./Direct3D9.cpp
Line : 1137
Function : Direct3D9::_InitializeDirect3D9
its hyperspin that is doing it because it loads fine outside of hyperspin and when i load in hyperspin i get that error and if i go back to the emulator itself i get the error untill i delete the setting and config for the emulator and start again.
Make sure you are running the same version SSF as the module was made for.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Sorry got it working with a new version of ssf. New problem dt lite is not unmounting with the script above.^^ it lets me pick any game in that system
but when i leave and go to a new system that uses dt i get a black screen because the game from ssf is still mounted is there a umount dt action in the script? thanks.
Yes all my modules that have DT have both mounting and unmounting. Make sure you are following the module notes and if it tells you to use a scsi drive, use it because the script won't unmount a DT drive.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
  • 2 years later...
I know this thread is old but I'm having the same issue. I have set up everything as stated in the module notes, the SSF version I'm running is 0.12 Beta R4.
I get the IDirect3D9 error. DirectX is updated.
Now, here is the weird part; If I start the emulator by itself after mounting the disc image it runs fine but when I try to use Hyperlaunch I can see it opens Daemon Tools and mounts the image by itself (as suppose to SCSI drive) and then loads the emulator followed by the error. Interesting enough, after that I am unable to get the emulator running again just by clicking on the *exe file, I have to unzip a fresh copy to the directory and start the process...
Anyone can help me with this? The error is as follows:
IDirect3D9::CreateDevice() error.
File:./Direct3D9.cpp
Line: 1148
Thank you in advance
Hi everyone. After searching (a lot) I managed to find a solution. Apparently if you encounter this error you can fix it by using another (older) version of SSF. The one that worked for me was 0.08_beta_R6 and I got it clicking on the "4.1 Prior versions" link in this page http://segaretro.org/SSF
