barakawins Posted December 10, 2014 Posted December 10, 2014 I'm loading daphne in the loader for all games and they come up fine. No issues at all. I get into hyperlaunch and I get a daphne error "Open GL v 2.0" error. Why can I load the games in the daphne loader but when running launching through hyperlaunch I get his message? Any ideas?
barakawins Posted December 10, 2014 Author Posted December 10, 2014 Ok.. There is a work around for this. I took it from someon's post but lost it. If you're upgrading to RocketLauncher.0 and get an Open GL v2.0 error when launching Daphne through Hyperspin, you will need to: Go into Hyperlaunch/Modules/Daphne folder. You will see a line in there which has -OpenGL listed. Remove this line in it's entirety and Daphne should launch through Hyperlaunch. Anyone know why this happens? I can get daphne and all the games to run through DaphneLoader. But when using Hyperlaunch it will give me the Open GL v2.0 error
barakawins Posted December 10, 2014 Author Posted December 10, 2014 Hmmmmmm.. I have a X300-X600 series Radeon Graphics card. I checked and it supports OpenGL v2.0. I shouldn't have any problems running daphne through Hyperlaunch. Does the Daphne Module need to be changed from -OpenGL to something else to make Hyperlaunch work properly with Daphne? I'm running RocketLauncher.0 and never had these issues until upgrading. So what I'm seeing is this: -Daphne runs fine out of Hyperlaunch using Daphne loader (all games function fine) -Hyperlaunch Modules were updated with 3.0 -Launching a game from the hypersin wheel gives me a Daphne error (OpenGL v2.0 error - read Daphne Log) -If I go into the Daphne Module and remove the line (-OpenGL) all games come up but slower. I'm obviously not using OpenGL as is meant to be for this. So, I'm wondering, anyone have to modify their module file in another way to make Daphne run correctly? Hyperlaunch issue? How would I get OpenGL v2.0 to work?
Krakerman Posted December 10, 2014 Posted December 10, 2014 I believe when setting up Daphne in HLHQ your suppose to use Daphne.exe not DaphneLoader.exe Sent from my iPhone using Tapatalk
rfancella Posted December 10, 2014 Posted December 10, 2014 Make sure your video card drivers are up to date and you are running Daphne v1.0..12. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
barakawins Posted December 10, 2014 Author Posted December 10, 2014 Yes. Daphne.exe works fine if I remove -OpenGL from the daphne module file. I'll try to update my video card drivers tonight.
rfancella Posted December 10, 2014 Posted December 10, 2014 Yes. Daphne.exe works fine if I remove -OpenGL from the daphne module file. I'll try to update my video card drivers tonight. It is the updated Daphne emulator? The old version 1.0 does not work with OpenGL very well. You must have the newest. Also, when launched from Daphne Loader (Outside of HyperSpin/HyperLaunch) is it using OpenGL? You can tell, by opening up Daphne Loader. Select the game you are testing (proper testing procedures recommend you always use the same criteria). Hit the Configure button. Go to the Advanced tab and make sure Display command line is Enabled. Hit OK. Launch the game and look at the Command Line. Does it say "-opengl" or "-nohwaccel" or neither? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
barakawins Posted December 13, 2014 Author Posted December 13, 2014 Got it. Downloaded ATI driver which loaded up OpenGL v.20. All is well here.
