Another ePsxe woe
MisterC21
Hi guys, i have ePsxe working both inside and outside of HS as long as i do not select "rom only" in HQ. As soon as i select this it will not go to psx sub wheel, but if i leave it unchecked it will. Games can be played (as long as i have them) but i want to tidy up. What is going on?
Thanks, Dave
Hi, yes am using up to date xml. I use epsxe as i use an aimtrak lightgun and managed to get it working with this (with Troubleshooter). Does Retroarch have Aimtrak support?
I am going to D/L a full PSX romset if i have to, but this seems overkill!! If i mark as Wheel Art Only it works fine, but as soon as Rom is selected in HQ its a no-go
Hmmm a good question. I have never used them so I have not looked into it. It does have a mountain of options to play with so I would think it may... afraid I cant confirm.
I understand your XML is up to date... but the games you have, are they named the same as the names in the XML?
Have renamed approx 100 roms to match XML, which still leaves 400ish named wrongly. I am testing on games i know are audited and found through HLHQ thus i know are correctly named :)
Thanks for that, have read through attached link and i think (!) it is starting to make a bit more sense :) At least others have found the same problems as me :)
Austin585, how long is long? Lol. Have found a full torrent of approx 380Gb which is 7z, could i just d/l and use as is? Sorry but showing my inexperience now :)
