SEGA CD - Won't find roms folder. See post.
barakawins
Frustrated again.. Set up all Sega Emulators, But this Sega CD thing is bugging me. Why won't it find the rom path?
See below:
19:30:31:835 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1c
19:30:32:085 | HL |     INFO  | +249   | Main - System Specs:
				HyperLaunch Dir: C:\Hyperspin\Hyperlaunch
				OS: Microsoft Windows 7 Professional
				SKU: Professional
				Total Memory: 2046.16 MB
				Free Memory: 1335.55 MB
				Used Memory: 710.609 MB
				SystemType: X86-based PC
				Physical Processors: 1
				Logical Processors: 2
				GPU 1 Name: ATI Radeon X300/X550/X1050 Series
				GPU 1 RAM: 128.00 MB
				GPU 1 Driver Version: 8.593.100.0
				GPU 2 Name: ATI Radeon X300/X550/X1050 Series Secondary
				GPU 2 RAM: 0.00 MB
				GPU 2 Driver Version: 8.593.100.0
				Sound 1 Device: Unimodem Half-Duplex Audio Device
				Sound 1 Status: Enabled
				Sound 2 Device: SoundMAX Integrated Digital Audio
				Sound 2 Status: Enabled
				OS Admin Status: Yes
				Monitor #1 (\\.\DISPLAY1): 1280x1024 (1280x984 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
19:30:32:085 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
19:30:32:085 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\HyperLaunch.exe exists
19:30:32:085 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\Databases\Main Menu\Main Menu.xml exists
19:30:32:210 | HL |     INFO  | +125   | Main - HyperLaunch launched directly
19:30:42:022 | HL |     INFO  | +9813  | Main - HyperLaunch received "Sega CD" and "3 Ninjas Kick Back (USA)"
19:30:42:069 | HL |     INFO  | +46    | Main - 3 Ninjas Kick Back (USA) is using the default emulator: Fusion
19:30:42:069 | HL |     INFO  | +0     | Main - Checking for a [Fusion] section in C:\Hyperspin\Hyperlaunch\Settings\Sega CD\Emulators.ini
19:30:42:069 | HL |     INFO  | +0     | Main - Checking for a [Fusion] section in C:\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini
19:30:42:069 | HL |     INFO  | +0     | Main - Found [Fusion] in C:\Hyperspin\Hyperlaunch\Settings\Global Emulators.ini
19:30:42:069 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Modules\Fusion\Fusion.ahk exists
19:30:42:100 | HL |     INFO  | +32    | Main - CRC Check - CRC matches, this is an official unedited module.
19:30:42:100 | HL |     INFO  | +0     | Main - 3 Ninjas Kick Back (USA) will use module: C:\Hyperspin\Hyperlaunch\Modules\Fusion\Fusion.ahk
19:30:42:131 | HL |     INFO  | +31    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
19:30:42:131 | HL |     INFO  | +0     | Main - INI Keys read
19:30:42:131 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\7z.exe exists
19:30:42:131 | HL |     INFO  | +0     | CheckFile - Checking if C:\Hyperspin\Hyperlaunch\Module Extensions\7z.dll exists
19:30:42:131 | HL |     INFO  | +0     | CheckPaths - Started
19:30:49:742 | HL |    ERROR  | +7613  | Cannot find Rom
In any Rom_Paths provided:
"C:\Hyperspin\ROMS\Sega CD"
With any provided Rom_Extension:
"7z|zip|sg|sc|gg|sms|gen|32x|md|cue|bin"
19:30:49:742 | HL |     INFO  | +0     | ExitScript - Started
19:30:49:805 | HL |     INFO  | +62    | SystemCursor - Restoring mouse cursor
19:30:49:820 | HL |     INFO  | +16    | ExitScript - Ended
Strangely.. If if I load the 3 Ninjas Kick Back (USA) zip file directly from fusion, it load and plays fine. But through Hyperlaunch it won't work.
I'm not sure why this is happening. Any ideas?
Well, I added all possible extensions as suggested. Same error. I'm using RocketLauncher.0. I have 7zip enabled through hyperlaunch.
I can load the zip file in fusion and it's no problem. Somehow in hyperspin when I pick the game from the wheel it won't load. Anyone see anything else I could
be doing wrong?
My friends. Thanks for all your help. All my Sega CD files are in zip format. You need to fix the Global Emulators .ini file to make this work. UGH!!!!!!! What a headache.
I pieced together what previous poster, "Pinsanity" said and went to my global emulators ini which is in hyperlaunch/settings/global emulators.
I included every extension possible in the Rom_Extension line and voila!! All worky now. Only took 2 days for this!!!
Anyway, alter your global emulator file to reflect that line and you're good to go.
[Fusion]
Emu_Path=..\EMULATORS\sega\Fusion.exe
Rom_Extension=7z|zip|sg|sc|gg|sms|gen|32x|md|cue|bin|iso|ccd|img|sub
Module=Fusion.ahk
HyperPause_Save_State_Keys={F5 down}{F5 up}
HyperPause_Load_State_Keys={F8 down}{F8 up}
  • 2 years later...
  • 4 weeks later...
My zips are .iso inside them so I needed iso added to my paths in rocket launcher.  Also I did not need to have 7z turned on as mine r in winzip (zip) format so not sure if that's a factor
