brolly Posted December 24, 2014 Posted December 24, 2014 Rename the executable back to the original name and replace this line in the module: Run(executable . " " . options . " -s """ . (If romExtension = .txt ? "" : romPath . "\" . romName . romExtension) . """", emuPath) With: Run("""" . executable . """ " . options . " -s """ . (If romExtension = .txt ? "" : romPath . "\" . romName . romExtension) . """", emuPath) and let me know if that fixes the problem. Also please report any HyperLaunch related issues in the HyperLaunch site from now on.
azzajess Posted December 24, 2014 Posted December 24, 2014 Thanks for the reply. I renamed it back to Emma 02.exe and tried again with the changed line in the module. Unfortunately i get the weird dialog that comes up that is attached to the first post. Although now, the cmd prompt does not say that it cannot be launched like before, im guessing due to the change in code. Im not sure if this error message im getting is emulator related or Hyperlaunch related. Here is the after the change: 20:37:08:001 | HL | INFO | +N/A | Main - HyperLaunch v3.0.1.1c 20:37:08:069 | HL | INFO | +78 | Main - System Specs: HyperLaunch Dir: D:\Arcade\Hyperlaunch OS: Microsoft Windows 8 SKU: Windows 8 Total Memory: 16342.89 MB Free Memory: 13458.65 MB Used Memory: 2884.238 MB SystemType: x64-based PC Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce 210 GPU 1 RAM: 1024.00 MB GPU 1 Driver Version: 9.18.13.3165 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: NVIDIA High Definition Audio Sound 2 Status: Enabled Sound 3 Device: NVIDIA High Definition Audio Sound 3 Status: Enabled Sound 4 Device: NVIDIA High Definition Audio Sound 4 Status: Enabled Sound 5 Device: NVIDIA High Definition Audio Sound 5 Status: Enabled Sound 6 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 6 Status: Enabled OS Language: English_United_Kingdom OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) AutoHotkey Path: C:\Program Files (x86)\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 20:37:08:069 | HL | INFO | +0 | Main - HyperSpin.exe coordinates are x320 y180 w1280 h720 20:37:08:085 | HL | INFO | +16 | CheckFile - Checking if D:\Arcade\Hyperlaunch\HyperLaunch.exe exists 20:37:08:085 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! FileVersion 3.0.1.1 LegalCopyright ©2013 HL squad ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName djvj's one swell guy! File Size: 910336 bytes Created: 10/1/2014 - 7:49:17 PM Modified: 9/30/2014 - 11:30:46 PM 20:37:08:085 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\itextsharp.dll exists 20:37:08:089 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 9/30/2013 - 6:49:47 AM 20:37:08:089 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\SevenZipSharp.dll exists 20:37:08:093 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 9/30/2013 - 6:49:48 AM 20:37:08:093 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\gsdll32.dll exists 20:37:08:093 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 8818688 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 9/30/2013 - 6:49:45 AM 20:37:08:097 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\BlockInput.exe exists 20:37:08:097 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 12/24/2014 - 2:36:56 PM Modified: 12/24/2014 - 2:36:24 PM 20:37:08:101 | HL | INFO | +15 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\gdip.ahk exists 20:37:08:105 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:37:08:109 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 9/30/2013 - 6:49:44 AM 20:37:08:109 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\RIni.ahk exists 20:37:08:113 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:37:08:113 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 9/30/2013 - 6:49:48 AM 20:37:08:117 | HL | INFO | +16 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\CLR.ahk exists 20:37:08:117 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:37:08:121 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 4/17/2014 - 6:47:16 PM Modified: 9/30/2013 - 6:49:43 AM 20:37:08:121 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\COM.ahk exists 20:37:08:125 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:37:08:125 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 4/17/2014 - 6:47:16 PM Modified: 9/30/2013 - 6:49:44 AM 20:37:08:125 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\JSON.ahk exists 20:37:08:129 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:37:08:129 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 9/30/2013 - 6:49:47 AM 20:37:08:133 | HL | INFO | +15 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Fade Init.ahk exists 20:37:08:133 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:137 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1145 bytes Created: 4/17/2014 - 6:47:05 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:137 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\HyperPause Init.ahk exists 20:37:08:137 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:141 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 691 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:141 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Keymapper Init.ahk exists 20:37:08:145 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:145 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2845 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:145 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\MultiGame Init.ahk exists 20:37:08:149 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:149 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:149 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Statistics Init.ahk exists 20:37:08:153 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:153 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 167 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:35 AM 20:37:08:157 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Fade.ahk exists 20:37:08:157 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:161 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 25516 bytes Created: 4/17/2014 - 6:47:05 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:161 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\HyperPause.ahk exists 20:37:08:169 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:173 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 360180 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:173 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Keymapper.ahk exists 20:37:08:177 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:177 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29638 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:181 | HL | INFO | +15 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\MultiGame.ahk exists 20:37:08:181 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:185 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36332 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:185 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Bezel.ahk exists 20:37:08:189 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:193 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 83095 bytes Created: 4/17/2014 - 6:47:05 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:193 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Statistics.ahk exists 20:37:08:197 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:197 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26153 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:35 AM 20:37:08:197 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Rom Mapping Launch Menu.ahk exists 20:37:08:201 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:205 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 63798 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:205 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Shared.ahk exists 20:37:08:209 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:209 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 77320 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 10/7/2013 - 11:08:37 AM 20:37:08:209 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\XHotkey.ahk exists 20:37:08:213 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:213 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 28374 bytes Created: 4/17/2014 - 6:47:06 PM Modified: 9/30/2013 - 6:49:35 AM 20:37:08:217 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Lib\Fade Animations.ahk exists 20:37:08:221 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 20:37:08:221 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 49050 bytes Created: 4/17/2014 - 6:47:05 PM Modified: 9/30/2013 - 6:49:34 AM 20:37:08:221 | HL | INFO | +0 | Main - HyperLaunch received "RCA Studio II" and "TV Arcade I - Space War (USA)" 20:37:08:229 | HL | INFO | +15 | Main - TV Arcade I - Space War (USA) is using the default emulator: Emma 02 20:37:08:229 | HL | INFO | +0 | Main - Checking for a [Emma 02] section in D:\Arcade\Hyperlaunch\Settings\RCA Studio II\Emulators.ini 20:37:08:233 | HL | INFO | +0 | Main - Checking for a [Emma 02] section in D:\Arcade\Hyperlaunch\Settings\Global Emulators.ini 20:37:08:233 | HL | INFO | +0 | Main - Found [Emma 02] in D:\Arcade\Hyperlaunch\Settings\Global Emulators.ini 20:37:08:237 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Modules\Emma 02\Emma 02.ahk exists 20:37:08:237 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2691 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 12/24/2014 - 8:33:47 PM 20:37:08:241 | HL | WARNING | +16 | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk. 20:37:08:241 | HL | INFO | +0 | Main - TV Arcade I - Space War (USA) will use module: D:\Arcade\Hyperlaunch\Modules\Emma 02\Emma 02.ahk 20:37:08:253 | HL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 20:37:08:257 | HL | INFO | +15 | Main - INI Keys read 20:37:08:261 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\7z.exe exists 20:37:08:261 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 4/17/2014 - 6:47:16 PM Modified: 9/30/2013 - 6:49:43 AM 20:37:08:265 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\7z.dll exists 20:37:08:265 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 4/17/2014 - 6:47:16 PM Modified: 9/30/2013 - 6:49:43 AM 20:37:08:269 | HL | INFO | +0 | CheckPaths - Started 20:37:08:269 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Arcade\RCA Studio II\Roms\TV Arcade I - Space War (USA).zip 20:37:08:269 | HL | INFO | +0 | CheckPaths - Found rom: D:\Arcade\RCA Studio II\Roms\TV Arcade I - Space War (USA).zip 20:37:08:273 | HL | DEBUG1 | +16 | CheckPaths - Current romName: TV Arcade I - Space War (USA) 20:37:08:273 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: D:\Arcade\RCA Studio II\Roms 20:37:08:277 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: .zip 20:37:08:277 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Emulators\Emma 02\Emma 02.exe exists 20:37:08:281 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 7076352 bytes Created: 12/24/2014 - 5:27:46 PM Modified: 12/16/2014 - 10:58:46 PM 20:37:08:285 | HL | INFO | +0 | CheckPaths - Ended 20:37:08:285 | HL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 hlMode = frontendPID = 2928 frontendPath = D:\Arcade frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = D: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = D:\Arcade\Emulators\Emma 02\Emma 02.exe emuPath = D:\Arcade\Emulators\Emma 02 emuName = Emma 02 emuExt = exe romPath = D:\Arcade\RCA Studio II\Roms romPathFromIni = D:\Arcade\RCA Studio II\Roms romExtension = .zip romExtensionOrig = .zip romExtensions = zip|st2|txt executable = Emma 02.exe systemName = RCA Studio II dbName = TV Arcade I - Space War (USA) romName = TV Arcade I - Space War (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfWheelsByScreen = 7 romMappingMenuWidth = 300 romMappingMenuMargin = 50 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s40 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 5 romMappingTextMargin = 10 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s60 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s15 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s15 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 40 romMappingMenuFlagSeparation = 5 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false skipchecks = false romMatchExt = true blockInputTime = 0 blockInputFile = D:\Arcade\Hyperlaunch\Module Extensions\BlockInput.exe errorLevelReporting = false logFile = D:\Arcade\Hyperlaunch\HyperLaunch.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = true logCommandWindow = false sysLang = English_United_Kingdom navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Z navP2UpKey = W navP2DownKey = S navP2LeftKey = A navP2RightKey = D navP2SelectKey = R originalWidth = 1920 originalHeight = 1080 dtEnabled = true dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe dtUseSCSI = true dtAddDrive = true emuIdleShutdown = 0 hideCursor = true hideEmu = false hideFE = false fadeIn = true fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Align to Top Left fadeLyr2Pos = Bottom Right Corner fadeLyr2X = 300 fadeLyr2Y = 300 fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr3Pos = Center fadeLyr3X = 300 fadeLyr3Y = 300 fadeLyr3Adjust = 0.75 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3PicPad = 0 fadeLyr4Adjust = 0.75 fadeLyr4X = 100 fadeLyr4Y = 100 fadeLyr4Pos = Above Layer 3 - Left fadeLyr4FPS = 10 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = false fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 600 fadeBarWindowH = 120 fadeBarWindowR = 20 fadeBarWindowM = 20 fadeBarWindowHatchStyle = 8 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 20 fadeBarR = 5 fadeBarColor = DD00BFFF fadeBarHatchStyle = 3 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 100 fadeRomInfoDescription = text fadeRomInfoSystemName = text fadeRomInfoYear = text fadeRomInfoManufacturer = text fadeRomInfoGenre = text fadeRomInfoRating = text fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = topRight fadeRomInfoTextMargin = 5 fadeRomInfoText1Options = cFF555555 r4 s20 Bold fadeRomInfoText2Options = cFF555555 r4 s20 Bold fadeRomInfoText3Options = cFF555555 r4 s20 Bold fadeRomInfoText4Options = cFF555555 r4 s20 Bold fadeRomInfoText5Options = cFF555555 r4 s20 Bold fadeRomInfoText6Options = cFF555555 r4 s20 Bold fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topLeft fadeStatsInfoTextMargin = 5 fadeStatsInfoText1Options = cFF555555 r4 s20 Bold fadeStatsInfoText2Options = cFF555555 r4 s20 Bold fadeStatsInfoText3Options = cFF555555 r4 s20 Bold fadeStatsInfoText4Options = cFF555555 r4 s20 Bold fadeStatsInfoText5Options = cFF555555 r4 s20 Bold fadeStatsInfoText6Options = cFF555555 r4 s20 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFFFFFFF r4 s20 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFFFFFFF r4 s20 Right Bold fadeText2 = Extraction Complete fadeFont = Arial fadeSystemAndRomLayersOnly = false fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = D:\Arcade\Hyperlaunch\Media\Fade HLDataPath = D:\Arcade\Hyperlaunch\Data HLMediaPath = D:\Arcade\Hyperlaunch\Media HLErrSoundPath = D:\Arcade\Hyperlaunch\Media\Sounds\Error modulesPath = D:\Arcade\Hyperlaunch\Modules moduleFullName = D:\Arcade\Hyperlaunch\Modules\Emma 02\Emma 02.ahk moduleName = Emma 02 modulePath = D:\Arcade\Hyperlaunch\Modules\Emma 02 moduleExtension = ahk moduleExtensionsPath = D:\Arcade\Hyperlaunch\Module Extensions libPath = D:\Arcade\Hyperlaunch\Lib 7zEnabled = true 7zPath = D:\Arcade\Hyperlaunch\Module Extensions\7z.exe 7zDllPath = D:\Arcade\Hyperlaunch\Module Extensions\7z.dll 7zExtractPath = D:\Arcade\cache 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgYOffset = 500 mgImageAdjust = 1 mgFont = Arial mgText1Options = x10p y30p w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 70 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgArtworkDir = Artwork1 hpEnabled = true hpKey = ~NumpadAdd hpBackToMenuBarKey = X hpZoomInKey = C hpZoomOutKey = V hpScreenshotKey = ~PrintScreen hpHiToTextPath = D:\Arcade\Hyperlaunch\Module Extensions\HiToText.exe hpSaveStateKeyCodes = hpLoadStateKeyCodes = keymapperEnabled = false keymapperAHKMethod = false keymapper = ahk xpadderFullPath = D:\Arcade\Tools\Xpadder\Xpadder.exe joyToKeyFullPath = C:\Windows\Utilities\VJoy\VJoy.exe keymapperProfilePath = D:\Arcade\Hyperlaunch\Profiles\ahk keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = false keymapperHyperLaunchProfileEnabled = false JoyIDsEnabled = false JoyIDsPreferredControllersSystem = use_global JoyIDsPreferredControllersGlobal = use_global CustomJoyNamesEnabled = false CustomJoyNames = FEProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\HyperSpin defaultProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\_Default systemProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\RCA Studio II xPadderSystemProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\RCA Studio II\_Default emuProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\RCA Studio II\Emma 02 romProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\RCA Studio II\TV Arcade I - Space War (USA) HyperLaunchProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\HyperLaunch blankProfile = D:\Arcade\Hyperlaunch\Profiles\ahk\blank ahkFEProfile = D:\Arcade\Hyperlaunch\Profiles\AHK\HyperSpin ahkDefaultProfile = D:\Arcade\Hyperlaunch\Profiles\AHK\_Default ahkSystemProfile = D:\Arcade\Hyperlaunch\Profiles\AHK\RCA Studio II ahkEmuProfile = D:\Arcade\Hyperlaunch\Profiles\AHK\RCA Studio II\Emma 02 ahkRomProfile = D:\Arcade\Hyperlaunch\Profiles\AHK\RCA Studio II\TV Arcade I - Space War (USA) ahkHyperLaunchProfile = D:\Arcade\Hyperlaunch\Profiles\AHK\HyperLaunch bezelEnabled = false statisticsEnabled = true 20:37:08:289 | HL | INFO | +16 | BuildScript - Loaded XHotkey Init.ahk scripts 20:37:08:289 | HL | INFO | +0 | BuildScript - Loaded Fade Init.ahk scripts 20:37:08:293 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\Module Extensions\VA.ahk exists 20:37:08:293 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 20:37:08:297 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 4/17/2014 - 6:47:17 PM Modified: 9/30/2013 - 6:49:48 AM 20:37:08:297 | HL | INFO | +0 | BuildScript - Loaded HyperPause Init.ahk scripts 20:37:08:301 | HL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 20:37:08:301 | HL | INFO | +0 | BuildScript - Loaded User Functions Init.ahk script 20:37:08:305 | HL | DEBUG1 | +15 | BuildScript - Module starts on line: 2 20:37:08:309 | HL | INFO | +0 | BuildScript - Module: MEmu = Emma 02 MEmuV = v1.18 MURL = http://www.emma02.hobby-site.com/ MAuthor = brolly MVersion = 2.0.1 MCRC = 868D853D iCRC = 1E716C97 MID = 635038268887179980 MSystem = "RCA Studio II" ;---------------------------------------------------------------------------- ; Notes: ; Best way to configure controls is to run Emma 02.exe directly do all the changes you want and then go to %APPDATA%\Emma 02 and copy the file emma_02.ini ; to the emulators data folder otherwise to edit controls you need to edit this file manually since when running in portable mode you don't have access to the GUI. ; ; To run the built-in games create txt files with the correct names and put them on your roms folder ; Built-in games require pressing a specific button on the controller in order to start, so make sure you edit the keys on the module below to match your own configuration ; Most of the games require you to press a button to start the game, like 1 or 2. So the game screen will be black until you do. ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) 7z(romPath, romName, romExtension, 7zExtractPath) If romExtension in %7zFormats% ScriptError(MEmu . " only supports extracted roms. Please extract your roms or turn on 7z for this system as the emu is being sent this extension: """ . romExtension . """") options := "-p" . (If Fullscreen = "true" ? " -f" : "") . " -u -c=studio" Run("""" . executable . """ " . options . " -s """ . (If romExtension = .txt ? "" : romPath . "\" . romName . romExtension) . """", emuPath) WinWait("Studio II ahk_class wxWindowNR") WinWaitActive("Studio II ahk_class wxWindowNR") ;Built-In Games require a button press for selection ;Make sure you change the keys below to match your own configuration! If romExtension = .txt { SetKeyDelay, 50 Sleep, 1500 ;Increase if game doesn't start automatically If romName contains Doodle SendInput, {k down}{k up} ; Press 1 on P1 controller If romName contains Patterns SendInput, {Up down}{Up up} ; Press 2 on P1 controller If romName contains Bowling SendInput, {x down}{x up} ; Press 3 on P1 controller If romName contains Freeway SendInput, {Left down}{Left up} ; Press 4 on P1 controller If romName contains Addition SendInput, {z down}{z up} ; Press 5 on P1 controller } FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("Studio II ahk_class wxWindowNR") Return 20:37:08:309 | HL | INFO | +0 | BuildScript - Loaded HyperPause scripts 20:37:08:313 | HL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 20:37:08:313 | HL | INFO | +0 | BuildScript - Loaded User Functions.ahk script 20:37:08:313 | HL | INFO | +0 | BuildScript - Finished injecting functions into module 20:37:08:317 | HL | INFO | +0 | Main - Module is built 20:37:08:317 | HL | INFO | +0 | CheckFile - Checking if D:\Arcade\Hyperlaunch\AutoHotkey.dll exists 20:37:08:321 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 4/17/2014 - 6:47:04 PM Modified: 9/30/2013 - 6:49:13 AM 20:37:08:325 | HL | INFO | +0 | Main - Running module 20:37:08:325 | HL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 20:37:08:441 | MD | INFO | +N/A | Module initialized 20:37:08:469 | MD | DEBUG1 | +32 | fadeInTransitionAnimation: DefaultAnimateFadeIn 20:37:08:469 | MD | DEBUG1 | +0 | fadeOutTransitionAnimation: DefaultAnimateFadeOut 20:37:08:473 | MD | DEBUG1 | +0 | fadeLyr3Animation: DefaultFadeAnimation 20:37:08:473 | MD | DEBUG1 | +0 | fadeLyr37zAnimation: DefaultFadeAnimation 20:37:08:501 | MD | INFO | +31 | StartModule - Started 20:37:08:501 | MD | INFO | +0 | StartModule - MEmu: Emma 02 MEmuV: v1.18 MURL: http://www.emma02.hobby-site.com/ MAuthor: brolly MVersion: 2.0.1 MCRC: 868D853D iCRC: 1E716C97 MID: MSystem: "RCA Studio II" 20:37:08:505 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "RCA Studio II" 20:37:08:505 | MD | DEBUG1 | +0 | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: TV Arcade I - Space War (USA) 20:37:08:509 | MD | INFO | +15 | Hiding mouse cursor 20:37:08:525 | MD | INFO | +16 | StartModule - Ended 20:37:08:525 | MD | DEBUG1 | +0 | FadeInStart - Started 20:37:08:529 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\RCA Studio II\TV Arcade I - Space War (USA)\Layer 1*.* 20:37:08:533 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\RCA Studio II\_Default\Layer 1*.* 20:37:08:533 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 1 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1*.* 20:37:08:537 | MD | DEBUG1 | +16 | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1*.png 20:37:08:537 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Layer 1 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1.png 20:37:08:537 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1*.gif 20:37:08:541 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1*.tif 20:37:08:541 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1*.bmp 20:37:08:545 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 1 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1*.jpg 20:37:08:545 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Layer 1 will use D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 1.png 20:37:08:549 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 2 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\RCA Studio II\TV Arcade I - Space War (USA)\Layer 2*.* 20:37:08:549 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 2 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\RCA Studio II\_Default\Layer 2*.* 20:37:08:549 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 2 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2*.* 20:37:08:553 | MD | DEBUG1 | +15 | GetFadePicFile - Looking for Fade Layer 2 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2*.png 20:37:08:553 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Layer 2 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2 (HS alt).png 20:37:08:557 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Layer 2 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2.png 20:37:08:557 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 2 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2*.gif 20:37:08:561 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 2 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2*.tif 20:37:08:561 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 2 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2*.bmp 20:37:08:561 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 2 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2*.jpg 20:37:08:565 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Layer 2 will use D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 2.png 20:37:08:649 | MD | INFO | +94 | DefaultAnimateFadeIn - Started 20:37:08:653 | MD | INFO | +0 | DefaultAnimateFadeIn - Drawing First FadeIn Image. 20:37:09:149 | MD | INFO | +500 | DefaultAnimateFadeIn - Ended 20:37:09:153 | MD | DEBUG1 | +0 | FadeInStart - Ended 20:37:09:153 | MD | INFO | +0 | StartGlobalUserFeatures - Starting 20:37:09:153 | MD | INFO | +0 | StartGlobalUserFeatures - Ending 20:37:09:157 | MD | DEBUG1 | +0 | CoverFE - Started 20:37:09:161 | MD | DEBUG1 | +0 | CoverFE - Ended 20:37:09:161 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 20:37:09:161 | MD | INFO | +0 | Module Setting - [settings] - Fullscreen: true 20:37:09:165 | MD | INFO | +16 | CreateMGRomTable - Started 20:37:09:165 | MD | DEBUG1 | +0 | CreateMGRomTable - romTable does not exist, creating one for "TV Arcade I - Space War (USA)" 20:37:09:169 | MD | INFO | +0 | CreateRomTable - Started 20:37:09:169 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "TV Arcade I - Space War (USA)" and "(Disc" 20:37:09:169 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "TV Arcade I - Space War (USA)" and "(Disk" 20:37:09:173 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "TV Arcade I - Space War (USA)" and "(Cart" 20:37:09:173 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "TV Arcade I - Space War (USA)" and "(Tape" 20:37:09:173 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "TV Arcade I - Space War (USA)" and "(Cassette" 20:37:09:177 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "TV Arcade I - Space War (USA)" and "(Part" 20:37:09:177 | MD | DEBUG1 | +0 | CreateRomTable - Checking for match: "TV Arcade I - Space War (USA)" and "(Side" 20:37:09:181 | MD | INFO | +15 | CreateRomTable - Ended, 7 Loops to create table. 20:37:09:181 | MD | INFO | +0 | CreateMGRomTable - Ended 20:37:09:181 | MD | INFO | +0 | 7z - Started, received D:\Arcade\RCA Studio II\Roms\TV Arcade I - Space War (USA).zip. If rom is an archive, it will extract to D:\Arcade\cache 20:37:09:185 | MD | DEBUG1 | +0 | 7z - Using Standard method to extract this rom 20:37:09:185 | MD | DEBUG1 | +0 | 7z - ".zip" found in .zip,.rar,.7z,.lzh,.gzip,.tar 20:37:09:189 | MD | INFO | +0 | CheckFile - Checking if D:\Arcade\RCA Studio II\Roms\TV Arcade I - Space War (USA).zip exists 20:37:09:189 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 821 bytes Created: 4/18/2014 - 1:41:27 AM Modified: 11/12/2013 - 12:27:36 PM 20:37:09:241 | MD | INFO | +63 | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "TV Arcade I - Space War (USA).ST2" 20:37:09:245 | MD | DEBUG1 | +0 | 7z - Invoked COM Object, ROM extracted size: 768 bytes 20:37:09:245 | MD | DEBUG1 | +0 | 7z - File already exists in 7z_Extract_Path with a size of: 768 bytes 20:37:09:249 | MD | DEBUG1 | +0 | 7z - File already exists in "D:\Arcade\cache\TV Arcade I - Space War (USA)". Breaking out of 7z to load existing file 20:37:09:249 | MD | DEBUG1 | +0 | 7z - FadeIn is true, but no extraction needed as it already exists in 7z_Extract_Path. Using Fade_Layer_3_Animation instead. 20:37:09:249 | MD | DEBUG1 | +0 | 7z - Starting non-7z FadeIn animation. 20:37:09:253 | MD | INFO | +0 | DefaultFadeAnimation - Started 20:37:09:253 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\RCA Studio II\TV Arcade I - Space War (USA)\Layer 3*.* 20:37:09:257 | MD | DEBUG1 | +15 | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\RCA Studio II\_Default\Layer 3*.* 20:37:09:257 | MD | DEBUG1 | +0 | GetFadePicFile - Checking if any Fade Layer 3 images exist in: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3*.* 20:37:09:257 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3*.png 20:37:09:261 | MD | DEBUG1 | +0 | GetFadePicFile - Found Fade Layer 3 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3.png 20:37:09:261 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3*.gif 20:37:09:265 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3*.tif 20:37:09:265 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3*.bmp 20:37:09:269 | MD | DEBUG1 | +0 | GetFadePicFile - Looking for Fade Layer 3 pic: D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3*.jpg 20:37:09:269 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade Layer 3 will use D:\Arcade\Hyperlaunch\Media\Fade\_Default\Layer 3.png 20:37:09:273 | MD | INFO | +16 | ReadHyperSpinXML - Started 20:37:09:273 | MD | INFO | +0 | ReadHyperSpinXML - Ended 20:37:10:049 | MD | INFO | +766 | DefaultFadeAnimation - Ended 20:37:10:049 | MD | DEBUG1 | +0 | FadeInDelay - Started 20:37:10:053 | MD | DEBUG1 | +15 | FadeInDelay - Ended 20:37:10:057 | MD | INFO | +0 | 7z - Ended 20:37:10:057 | MD | INFO | +0 | Run - Running: D:\Arcade\Emulators\Emma 02\"Emma 02.exe" -p -f -u -c=studio -s "D:\Arcade\cache\TV Arcade I - Space War (USA)\TV Arcade I - Space War (USA).ST2" 20:37:10:065 | MD | INFO | +0 | Run - Showing Command Window to troubleshoot launching. ProcessID: 15032 20:37:10:446 | MD | DEBUG1 | +391 | Run - ""Emma 02.exe" -p -f -u -c=studio -s "D:\Arcade\cache\TV Arcade I - Space War (USA)\TV Arcade I - Space War (USA).ST2"" Process ID: 15032 20:37:10:446 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: C:\Windows\system32\cmd.exe | Class: ConsoleWindowClass | State: 0 | X: 26 | Y: 26 | Width: 677 | Height: 343 | Window HWND: 0x1e0962 | Process ID: 15032 | Process Path: C:\Windows\SysWOW64\cmd.exe 20:37:10:450 | MD | INFO | +0 | WinWait - Waiting for "Studio II ahk_class wxWindowNR" 20:37:10:781 | MD | DEBUG1 | +328 | GetActiveWindowStatus - Title: wxWidgets Debug Alert | Class: #32770 | State: 0 | X: 725 | Y: 443 | Width: 477 | Height: 205 | Window HWND: 0x170a04 | Process ID: 14508 | Process Path: D:\Arcade\Emulators\Emma 02\Emma 02.exe 20:37:10:783 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: wxWidgets Debug Alert | Class: #32770 | State: 0 | X: 725 | Y: 443 | Width: 477 | Height: 205 | Window HWND: 0x170a04 | Process ID: 14508 | Process Path: D:\Arcade\Emulators\Emma 02\Emma 02.exe 20:37:10:785 | MD | INFO | +0 | WinWaitActive - Waiting for "Studio II ahk_class wxWindowNR" 20:37:33:280 | HL | ERROR | +24953 | ExitScript - User pressed Exit_Script_Key to force HyperLaunch shutdown 20:37:33:283 | HL | INFO | +0 | ExitScript - Started 20:37:33:288 | HL | DEBUG1 | +16 | ExitScript - Checking what application is currently in focus. 20:37:33:290 | HL | DEBUG1 | +0 | ExitScript - wxWidgets Debug Alert is currently active. Putting focus back on HyperSpin.exe 20:37:33:419 | HL | DEBUG1 | +125 | ExitScript - Took 1 attempts to put HyperSpin.exe back in focus. 20:37:33:426 | HL | INFO | +0 | SystemCursor - Restoring mouse cursor 20:37:33:433 | HL | INFO | +15 | ExitScript - Ended Thanks
brolly Posted December 24, 2014 Author Posted December 24, 2014 That dialog comes from the emu, did you follow the instructions in the module's notes regarding the portable install? Also check the emulator version you're using. Try creating and running .bat file with these contents and see if you get the same error: "Emma 02.exe" -p -f -u -c=studio -s "D:\Arcade\cache\TV Casino I - Blackjack (USA)\TV Casino I - Blackjack (USA).ST2"
azzajess Posted December 24, 2014 Posted December 24, 2014 I am running Emma 02 1.19 (I thought i would try to specifically get 1.18 from the website however when downloading it shows 1.17) I did follow the notes in regards with the module, where i had to copy over the emma_02.ini from my roaming folder to the data folder in the emulator folder. I created a .bat file using your line of code and i got the same error message as before.
brolly Posted December 24, 2014 Author Posted December 24, 2014 1.19 was just released so there might be something wrong with the command line arguments. Try 1.18 which is the one supported by the module, and yeah I think Marcel forgot to change the version number so that should be correct, I think he released 1.18 specifically to fix an issue I reported him back then. You should probably report that problem to Marcel though so he can have a look at it.
azzajess Posted December 24, 2014 Posted December 24, 2014 Unfortunately im unable to go back to version 1.18 because the download link on their website makes me download the 1.17 version (Which i installed just to see if it was a miss type in the installer name and it isnt, it is 1.17) instead of the 1.18. Ill Regularly check for the download link to be fixed on their website or find it somewhere else for. When i do find it, ill test it out and report back to let you know if it fixed the issue. Thanks for the help
sudopinion Posted December 24, 2014 Posted December 24, 2014 Unfortunately im unable to go back to version 1.18 because the download link on their website makes me download the 1.17 version (Which i installed just to see if it was a miss type in the installer name and it isnt, it is 1.17) instead of the 1.18.Ill Regularly check for the download link to be fixed on their website or find it somewhere else for. When i do find it, ill test it out and report back to let you know if it fixed the issue. Thanks for the help http://dl.dropbox.com/u/3880958/Emma%2002/Emma_02_setup_v1.18.exe
azzajess Posted December 25, 2014 Posted December 25, 2014 Hello, After installing 1.18 and booting it a few times, i got errors about missing files. After filling in what was asked from the errors it has finally booted up and i believe everything is working as it should! Thanks again for the help.
