Xpadder making Hyperspin to lose focus
Captsu
Hi guys, I'm a very new Hyperspin/launch user, started about a week ago. I really love making my setup, tons of fun.
But it's not really fun if everything work immediatly right ?
Here's my problem : I managed to install Hyperspin/launch and ~20 systems with the help of various tuto, great. Managed to configure all my xpadder profiles, fantastic.
Now, when testing in Hyperspin, everything is loading correctly, games and xpadder profiles but when I exit an emulator, Hyperspin is minimized and I have to Alt+tab to regain the focus.
Exiting an emulator without Xpadder enabled works just fine.
This guy had a similar issue and couldn't find a answer.
What can I do ? I'm using the xpadder version 2015.1.1, Hyperspin 1.3.2.0 and RocketLauncher.0.1.1
Yeah I already looked into that thread but since I already had xpadder, I wanted to make it work. But definitely gonna look more in depth, looks awesome. I'm gonna try without the intro first.
Isn't HyperSpin Startup Script only to use my 360 controller with hyperspin ? I mean, it doesn't load specific xpadder profiles with each system, does it ? (my profiles are very different depending the system I play on)
Should I use the xpadder's built-in autoprofil to load them at the start of each emulator ?
Thanks again for you reply.
With the latest version the HyperSpin Startup Script is no longer limited to the 360 controller. It is now limited to many of one type of joystick whatever that is for you. It does not deal with xpadder profiles at all.
To not lose your current setup of loading system xpadder profiles, all you need to do is turn off the front end profile. The loading of the front end profile sounds like what has been messing you up.
The script now works without an intro video on my end with the latest released version of the script.
I did not fixed my original problem. I'm using the hyperspin startup script now and it does the trick.
Thank you guys !
Quick edit for the ones who also have this problem. Djvj informed me about the "Restore front end on exit" setting and switch it from "Restore" to "Restore and click" fixed it.
Still using the hyperspin startup script for the front end, it's awesome.
