craiganderson Posted January 10, 2015 Posted January 10, 2015 Hello. I wanted a module that simply opened and closed the Touhou games. No more or no less. Just like you were clicking on the .exe file outside of hyperspin. So I used the existing one and created this for myself. It works really well so far. Opens and Closes each Touhou game (both .hdi and .exe) without difficulty. Gotta name shortcuts and move a few files around differently than the other setups. I will be glad to elaborate if anybody is interested. Just FYI. No biggie either way.... But if you had any trouble setting up Touhou this might be a nice option to give a try.... MEmu = MEmuV = MURL = MAuthor = craiganderson MVersion = 1.0 MCRC = iCRC = mId = MSystem = "Touhou" ;---------------------------------------------------------------------------- ; Notes: ;---------------------------------------------------------------------------- StartModule() FadeInStart() If romExtension = .lnk { executable=%romName%.exe Run, %romPath%\%romName%%romExtension% WinWait, A WinWaitActive, A } If romExtension = .hdi { executable=Next.exe IniWrite, %romPath%\%romName%%romExtension%, %emuPath%\MAIN.INI, DISK, DISK02 IniWrite, 1, %emuPath%\MAIN.INI, Control, AutoRun ; required for games to start on emu launch Run(executable,emuPath,"Hide") WinWait("Emulation Window ahk_class T98-Next") WinWaitActive("Emulation Window ahk_class T98-Next") Sleep, 1000 ; need this otherwise mouse doesn't move off screen ; If romName = 3th - Phantasmagoria of Dim Dream ; Run, remap_keys.exe, %modulePath% } MouseMove 0,2000,0 ;Move mouse off screen FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() Process, Close, th06.exe Process, Close, th06e.exe Process, Close, th07.exe Process, Close, th07e.exe Process, Close, th075.exe Process, Close, th075e.exe Process, Close, th08.exe Process, Close, th08e.exe Process, Close, th09.exe Process, Close, th09e.exe Process, Close, th095.exe Process, Close, th095e.exe Process, Close, th095_ver102a.exe Process, Close, th10.exe Process, Close, th10e.exe Process, Close, th105.exe Process, Close, th105e.exe Process, Close, th11.exe Process, Close, th11e.exe Process, Close, th12.exe Process, Close, th12e.exe Process, Close, th123.exe Process, Close, th123e.exe Process, Close, th125.exe Process, Close, th125e.exe Process, Close, th128.exe Process, Close, th128e.exe Process, Close, th13.exe Process, Close, th13e.exe Process, Close, th135.exe Process, Close, th135e.exe Process, Close, th14.exe Process, Close, th14e.exe Process, Close, th143.exe Process, Close, th143e.exe Process, Close, Next.exe Process, Close, Banshiryuu.exe Process, Close, Kioh Gyoku.exe Process, Close, Shuusou Gyoku.exe Process, Close, Rain.exe Return http://craigandersonthemes.weebly.com/
craiganderson Posted January 10, 2015 Author Posted January 10, 2015 Anybody know where to get the "remap_keys.exe"?? thanks http://craigandersonthemes.weebly.com/
zerojay Posted January 10, 2015 Posted January 10, 2015 Did you somehow run into issues with these games and the current modules? From what I remember, it pretty much just does the same thing you put in your module here anyways...?
craiganderson Posted January 10, 2015 Author Posted January 10, 2015 Did you somehow run into issues with these games and the current modules? From what I remember, it pretty much just does the same thing you put in your module here anyways...? yeah..i was getting "waiting for ahk class " type errors on a few games. i couldnt fix and thought i would just make a very simple one to do the job and some games didnt want to close very well i trimmed them down to a pretty simple level i didnt need all the extra stuff that was in the other modules im not smart enough to figure them out http://craigandersonthemes.weebly.com/
craiganderson Posted January 10, 2015 Author Posted January 10, 2015 the module needs tweaking for a couple games doing it now for some reason when you load th075e.exe,,....the process in task manager drops the "e" stuff like that fixing now http://craigandersonthemes.weebly.com/
craiganderson Posted January 10, 2015 Author Posted January 10, 2015 I have an updated module that doesn't have that errorbut to use if tbe user will have to hange some other stuff around (different shortcuts and move t98 emulator to did folder etc.)) Now works perfect and ell exit perfectly as well. Exits via task manager type command Let me know if anybody wants to try it http://craigandersonthemes.weebly.com/
craiganderson Posted January 12, 2015 Author Posted January 12, 2015 OK. I will have to add some more info for you. Regarding naming etc. Dont try it just yet. thanks craig http://craigandersonthemes.weebly.com/
drewjbx1 Posted August 19, 2015 Posted August 19, 2015 craiganderson... found your thread, Im using a T98-Next.ahk and the newer games start and exit ok, but its the first few ones that wont allow me to use my joystick and the esc and altF4 wont exit the game.. it goes into that dos looking interface. Any help appreciated
