strawdog Posted January 11, 2015 Author Posted January 11, 2015 Just one more thought... When I setup a new console... I actually never use HyperHQ... I just edit the mainmenu.xlm.... then I set up everything through HyperLaunchHQ to setup the application directory and the rom path... Maybe your problem is that you set the executable? Took your advice mate, removed the executable path in HyperHQ, i noticed you have "O" in the directory, i presume that is your root location for Hyperspin. I cannot get to alter mine, if i click on the folder icon, i have to select a full path. if i leave it totally blank i get an error when loading the game saying " path must end with a "/" I have also taken Giga's advice, got a clean download of Hyperspin, looked at the settings.ini and pasted the 'hyperspin path line' into mine - line reads... "Hyperlaunch_Path=C:\Hyperspin\HyperLaunch\" (Note - i changed the C to P, as that is my root drive letter) but it makes no difference, I still the same error saying "Nintendo GameCube is not a supported system "
gigapig Posted January 11, 2015 Posted January 11, 2015 Have you looked at both the main menu xml and the Gamecube xml for reference to an exe? I think that's correct, or post them here.
strawdog Posted January 11, 2015 Author Posted January 11, 2015 Nintendo GameCube.xml has no sign of an exe path, just all the games listed (this is inside the Nintendo GameCube folder within Databases) xml info here - <script src="http://pastebin.com/embed_js.php?i=g1AspnCw"></script> and also no sign of an exe path in Main Menu.ini which is inside the Hyperspin/Settings folder Main Menu.ini info here... "[wheel] alpha=0 small_alpha = 1 style=normal speed=high vert_wheel_position=right norm_large=470 norm_small=250 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=400 horz_small=100 horz_wheel_y=700 text_width=800 text_font=Style3 small_text_width=280 large_text_width=600 text_stroke_size=7 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=1 shadow_distance=6 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 y_rotation=left [pointer] animated = true x = 965 y = 384 [video defaults] path=C:\HyperSpin\Media\Main Menu\Video\ [sounds] game_sounds=true wheel_click=true [special Art A] default=false active=false x = 512 y = 720 in = .4 out = .4 length = 3 delay = .1 type = normal start = bottom [special Art B] default=false active=false x = 512 y = 740 in = .4 out = .4 length = 3 delay = .1 type = fade start = none"
strawdog Posted January 11, 2015 Author Posted January 11, 2015 thanks Jeremy, Going crazy here now, how do we do team viewer? i have installed, Pm me info thanks a lot
strawdog Posted January 11, 2015 Author Posted January 11, 2015 There is no reason you need a settings.ini from somewhere/someone else. I am willing to take a look through teamviewer just let me know. BIG THANKS TO jeremy0203 he took the time to sift through my hyperspin drive and fix this, i have learned my lesson- i cut corners by grabbing some custom sets of emu's - looks like i will now save my media and rom folders and do a clean install thanks again for the help
gigapig Posted January 11, 2015 Posted January 11, 2015 Could Jeremy let's us know what the fault was so I can mark this as solved?
strawdog Posted January 12, 2015 Author Posted January 12, 2015 yeah i warned you i was new to this ! will take my roms,media and emus out and clean install this week. thanks again
