jon Posted January 13, 2015 Posted January 13, 2015 hi all, i have been working on my hyperspin setup, mame works no problem in fact its so good i want to add my snes emulator which is zsnes. all of the wheel/themes videos are set up correctly its the emulator/hyperlaunch im having a problem with. zsnes itself works no problem outside hyperspin, the problem i have is launching it through hyperspin via hyperlaunch which gives no errors it just wont start literally nothing happens its not even showing zsnes working in my task manager. out of interest i can get snes9x or bsnes to work but i want zsnes in particular any suggestions are very much appreciated atb jon
Fromlostdays Posted January 13, 2015 Posted January 13, 2015 First, try and launch through HyperLaunchHQ, if that doesn't work, post troubleshooting logs. Second, you should be able to use esc as your exit key for those emulators as well as mednafen, and Retroarch, which in my opinion are all better choices for snes emulation. If they won't exit emulation via escape it sounds like you don't have hyperlaunch configured correctly. Walter:beerglass:
Styphelus Posted January 13, 2015 Posted January 13, 2015 1. I would not exist via ESC. If you plan on ever setting up DOS or ScummVM, you will run into a lot of problem because the ESC key is used to exist menus. Pick a different key to exit. 2. Znes has problem running full screen with Windows 8. It will crash, at least on my machine. I would recommend you used snes9x or Retroarch.
pucpuc Posted January 13, 2015 Posted January 13, 2015 which key would you use to exit? - ESC also could be configured to hols for 1 second. I'd also recommend Retroarch
jon Posted January 14, 2015 Author Posted January 14, 2015 thanks for the replys, i want to stick with zsnes for now as i have it all set up how i want it, i found the joystick mapping easy to set up and i can exit via the xbox button instead of using the escape key. i will look into the suggested emulators but for now zsnes is what im using on windows xp its full screen no issues. it has taken me a while to get hyperspin to run ive had the usual crashing and the wheel spinning issues if i used my xbox controller but have sorted out those problems, i will look into the hyperlaunchhq again as this looked far to complicated at first glance. i was able to set up mame without using it, i will see if this gives me any results, again thanks for the replys
jon Posted January 23, 2015 Author Posted January 23, 2015 just for the record i have my set up working just fine, the problem seemed to be with the.ahk file thanks for all the suggestions jon
