bulk video question
craiganderson
Craig, I know what you're talking about. Your videos are recorded with the audio up a bit too high and it's causing those crackles and also causing some audio distortion. It won't go away after the fact by just changing the volume after.
So you a chubby chaser.... maybe ask gigapig to put on a skirt & bra ;)
It's the recording volume that's too high and that's causing clipping which is the cause of the crackles. Turn it down to 90 or even 80% and it should be a lot better. I'm not sure what software you are using to record videos with, however.
