psykix Posted January 21, 2015 Posted January 21, 2015 Hopefully this is an easy fix! I have xpadder set up to control the Hyperspin front end and it works great with my Xbox360 controller. However... I control everything through Steam and when I launch Hyperspin from Steam Big Picture, then the controller doesn't work for Hyperspin. Hopefully someone can tell me what I've missed!
gigapig Posted January 21, 2015 Posted January 21, 2015 I launch Steam through HS not the other way around. So your HS xpadder profile isn't being loaded when you start Steam? You could look into the Startup Script or if no one else has any suggestions head over to HyperLaunch.net and ask there. http://www.hyperspin-fe.com/forum/showthread.php?28986-HyperSpin-Startup-Script
psykix Posted January 21, 2015 Author Posted January 21, 2015 gigapig said: I launch Steam through HS not the other way around. So your HS xpadder profile isn't being loaded when you start Steam? You could look into the Startup Script or if no one else has any suggestions head over to HyperLaunch.net and ask there. http://www.hyperspin-fe.com/forum/showthread.php?28986-HyperSpin-Startup-Script I could launch Steam through HS - however the primary use of the PC is as a HTPC running Plex and Hyperspin frontend is a bit bells and whistles and in your face for that imho! I presume that the profile is not being loaded when HS is launched through Steam - obviously I only want xpadder profile to kick in when HS is launched, as it works fine in Steam otherwise. Cheers!
gigapig Posted January 21, 2015 Posted January 21, 2015 Try the startup script then as it seems you need either the script to start when HS starts or you need a HS profile loaded when launching from Steam. You can set xpadder to load the last profile but that assumes the HS profile is the last one. The Startup script does not require xpadder btw.
