Runadumb Posted January 27, 2015 Posted January 27, 2015 http://epsxe.com/ ePSXe 1.9.25 for windows and linux have been released. You can find them in the downloads section. The changes are: - Added HLE bios support (an official PS1 is recommend yet). From this version ePSXe can run games without an official PS1 bios. VERY IMPORTANT: Savestates done with a official PS1 bios are NOT compatible with savestates done with ePSXe HLE bios (Besides it uses a different namespace). - Fixed multi-bin format in Windows version (redump format). Now it supports the games saved in multiple bins files + cue file directly. - Better SBI subchannel support (for example in Medievil) and fixed SBI in games with ECM format. Added SBI support in MDS/MDF format. - Added support to save memcards by game. Enabling this option it will create 2 memcards by everygame in memcards/games/ folder, using the serial of the game. In multidisc games, it will share the same memcards by all of discs - Fixes to the CD-Rom decoder and the core which made almost 20 more games playable or working better like. For example this fixed: Arcade Party Pak: Rampage now works, Crash Bash: Pause menu now works, Final Fantasy V, Junclassic C.C. & Rope club, Kamen Rider v3, Minakatakudou Toujyou, NHL Face Off 2001, Nishijin Pachinko Tengoku Vol.3, Omizu no Hanamichi, Sentient (-i), Simple 1500 Series Vol.006 - The Hanafuda [Rerelease], Standby Say You, Tombi, Tombi 2, Twins Story - Kimi ni Tsutaetakute, Vanark: Pause menu now works, Worms Armageddon, Yuukyuu no Eden - The Eternal Eden, Yeh Yeh Tennis - New experimental dmachaincore that maybe can fix some graphic glitches in some games like Tomb Raider Chronicles or Metal Gear Solid. Usage execute epsxe.exe -dmachaincore Regards, ePSXe Team. Will this memory card per game option play badly with the hyperlaunch version? Good the see progress still being made.
rfancella Posted January 27, 2015 Posted January 27, 2015 Nice! I will give it a go and see if I can change up the module to support the new dma option. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
boomerps2 Posted January 29, 2015 Posted January 29, 2015 I had to ditch espxe all together because compatibility was a nightmare. Games where too fast or too slow. It has the best filter enhancements though. I just wish it was more consistent. Moved on to retroarch (Mednafen) and havnt looked back.
KRIS85 Posted November 2, 2018 Posted November 2, 2018 Can someone explain to me why after starting by RL can not see the save, memory card Epsx the latest version, games zipped up 7zip to save space (unless someone knows a better way)
