Running mame at 640 x 288 through hyperspin - Can someone help with this script?
barakawins
I found this fix:
I'm running a standard resolution monitor and need to run mame at 640 x 288. Is there a way to make hyperspin launch this attached script
before mame so the screen changes resolution form 640 x 480 to 640 x 288? Hopefully someone can assist.
I have solved this problem in Hyperspin for my Egret 2 arcade machine (Using Windows 7 X64, ArcadeVGA and J-Pac).
Get the Switchres.zip file posted earlier in this thread.
Unzip it into you mame folder.
Edit Hyperlaunch.akh in your Hyperspin folder. (Make a backup of Hyperlaunch.exe, and Hyperlaunch.ahk first)
Change the MAME part to this:
;*************************************MAME**************************************
else if (systemName = "MAME" && executable = "mame.exe")
hideDesktop()
Hotkey, %exitEmulatorKey%, CloseProcess
Runwait, c:\Emu\Mame\640x288.exe, Hide UseErrorLevel
Runwait, %executable% %romName%, %EmuPath%, Hide UseErrorLevel
Process, waitClose, %executable%
Runwait, c:\Emu\Mame\640x480.exe, Hide UseErrorLevel
exitapp
Change the path names to 640x288.exe and 640x480.exe, to your mame installation, before saving.
Download Autohotkey from here: http://www.autohotkey.com/download/
Install it and run the compiler. (Compiler\Ahk2Exe.exe)
Select the new hyperlaunch.ahk and compile it into a new hyperlaunch.exe.
Replace the old hyperlaunch.exe with the new one you made. (Remember to always make a backup first)
And now DirectDraw in MAME under windows 7 works.
What this change does is whenever you launch a MAME game from Hyperspin the resolution is changed to 640x288 before mame is started.
Mame runs, sets the right directdraw resolution and avoid the interlace/non-interlace bug in Windows 7.
When you exit mame the resolution is reset to 640x480.
And everything works. :D
DirectDraw looks glorious on a 15Khz monitor. A huge difference compared to D3D. Well worth the bother. :laugh:
Regards
/Finn
Well, turns out this won't work with the current version of mame since the hyperlaunch.ahk doesn't contain any mame code in it to replace.
Anyone else know how to make something like this work?
  • 1 month later...
SOLVED...this are the solution
; Use this function to define any code you want to run in every module on start
StartGlobalUserFeatures(){
Global systemName
Log("StartGlobalUserFeatures - Starting")
WinGetClass, CurrentActiveProgramClass, A
if (systemName="MAME") {
run, C:\Hyperspin\Switchres\640x288.exe
Log("StartGlobalUserFeatures - Ending")
; Use this function to define any code you may need to stop or clean up in every module on exit
StopGlobalUserFeatures(){
Global systemName
Log("StopGlobalUserFeatures - Starting")
run, C:\Hyperspin\Switchres\640x480.exe
Log("StopGlobalUserFeatures - Ending")
Change right path of your file
Copy and paste this on LIB > User Functions (Example).ahk
Remove (Example)
Run Hyperspin or test a game in HLHQ
  • 2 months later...
I found this fix:
hideDesktop()
exitapp
Regards
/Finn
When I do this I get this error when loading into mame:
"make sure your paths contain a backslash on the end"
This is what I have replaced in my Hyperlaunch.ahk mame section:
    hideDesktop()
    Runwait, C:\Users\MAME\Desktop\Hyperspin Project - The Frontend\Emulators\MAME\640x288.exe, Hide UseErrorLevel
    Runwait, C:\Users\MAME\Desktop\Hyperspin Project - The Frontend\Emulators\MAME\640x480.exe, Hide UseErrorLevel
    exitapp
Please Help!!!
