iNTiGOD Posted February 4, 2015 Posted February 4, 2015 Hey guys, I've just recently setup dosbox but am having some difficulties with screen resolution. I want to be able to set dosbox to use my full screen resolution of 1024x768 (and fill this resolution as much as possible). I'm using exodos additionally. I believe to setup fullscreen resolution I need to edit the dosbox.conf. My questions are what are the settings required to ensure I use the fullscreen resolution and i'm filling the screen. Also does this mean I have to edit each of the dosbox.conf files for each individual game that come with exodos as well or is there a universal setting? My plasma is at the moment switching resolutions on the fly (e.g. 640x480)for different games but it shits itself every now and again and goes blank (damn you samsung), hence my reason for wanting one resolution permanently. Cheers MAME High Score Tutorial For HyperSpin
damageinc86 Posted February 4, 2015 Posted February 4, 2015 Wow sounds like a little bit of a headache. I use D-Fend Reloaded and I have no problem with any resolutions. It's a great program for organizing the DOS games.
iNTiGOD Posted February 5, 2015 Author Posted February 5, 2015 hmmm... exodos already has the games well organized and the are all working well... just hoping to find a way to force dosbox not to switch resolutions MAME High Score Tutorial For HyperSpin
dougan78 Posted February 5, 2015 Posted February 5, 2015 If you are using hyperlaunch I noticed there is a module setting for Full Screen resolution and you can set it to desktop. If your desktop on your plasma is 1024x768 that would work I think. Maybe that will help. Good luck.
iNTiGOD Posted February 5, 2015 Author Posted February 5, 2015 If you are using hyperlaunch I noticed there is a module setting for Full Screen resolution and you can set it to desktop. If your desktop on your plasma is 1024x768 that would work I think. Maybe that will help. Good luck. dougan that did the trick i'm also fiddling with the "scaler" module setting to stretch it to full screen thanks heaps MAME High Score Tutorial For HyperSpin
