Mini-Pac Question (Connectors)
TylerDurdenPHI
Hello, I've just started a new cabinet build from an original Gorgar (will introduce the build properly later) and want to pick up a Mini-PAC. Can someone help me choose the proper connectors to purchase?
I have the Ultimate Cab-Builder's Button Kit (http://virtuapin.net...&products_id=38) and have been told that it uses 0.250" and 0.187" terminals.
Which Mini-Pac connectors should I select to ensure that I will have everything needed? (http://www.ultimarc....ct.php?xProd=29)
Options: 6.3mm (1/4in) connectors / 4.8mm connectors / 4.8-2.8 mm connectors.
Thank you in advance!
you will need 4.8 mm for the button micro switches.
6.3 mm's are normally used for the lighting connectors on the buttons
