Issue with Override Transitions
Cruel Moose
So I've begun playing around with these, but I've noticed an issue. If I have themes wait for special checked in HyperHQ, it will play the override transition in the foreground (like I want it to), BUT, after that only 1 video or none will play. So if I scroll to another game it won't bother to play any videos for ANY games (and sometimes not even for the game I've selected the transition for). Now if I have this box unchecked, videos work perfectly fine, however, the transitions play in the background, which is a lot less cooler :( Any idea how to solve this problem? Thanks in advance.
Edit: Seems like the issue happens if I interrupt a transition by scrolling through the wheels before letting it finish. They also interact kinda weird with videos as well, since they seem to fight a bit on who is on top with wait for theme special checked.
  • 1 year later...
I have found that same issue and used a diff workaround.
When "Wait for Special" is not activated, the videos continuously show, but the Transitions are in the background which makes the Sonic Ring transition for the Genesis for example alsmot invisible.
Here's what I did. I opened every Main Menu Theme and added 2 second delays to all effects and Artwork the Themes use. This make the Artwork come in after the Transistion is finished or while its finishing and makes it look like I am used to from older HS versions.
  • 8 months later...
