TurboGrafx - CD and Retroarch Help.
scooter1974
Does anyone have any tips for getting the games to work for the TurboGrafx CD system in Retroarch? I have mounted one of the games in daemon tools and it worked with the Magic Engine emulator, but all I get in RA is a black screen. I looked through the RA log files and saw no errors. My paths and core are all correct and I also have the right bios file in the right location (confirmed by the core info screen). Help!!
Check out my MAME Arcade classics themes
Check your roms. They need to be in Cue Bin format. If you have a rom set with mp3 files in it, it won't work. I had the same issue. Converting it to wav files will only produce music, not sound effects.
Get the set from PD or a trurip set.
Also, do you have the right bios?
The set I have is from PD and are in ccd/img/sub format. I will convert one over to bin/cue format and see how that goes. I am pretty sure I have the right bios. I tried with the US and Japan one. Thanks for the heads up about the format Styphelus.
You don't need to convert them. I have the same set. Wait until tonight and I will send you my settings for Retroarch. Mine is working perfectly fine.
  • 1 year later...
