CRT Royale Shader settings issue
keltoigael
Currently running the beta 1.0.0.3 of retroarch just so I can run the advance shaders and new cores. I have never had an issue with crt royale before, I used to run it on a nightly build before I even ever tried the official 1.0.0.2 version. For some weird reason, every time I make changes to the settings via menu, none of the changes I make stick. It wont even save my custom settings via the save as menu. Never had this happen before. It is consistent, I have even went back to deleted core.cfgs, deleting the shader "shaders/crt/" path out of retroarch.cfg and it happens every darn time. I even edited the system.dll.gdp files with the settings I want and it still wont show them. Is there something I am missing?
I never use the menu for changing shader settings. I prefer to edit them in the shader's files myself. I never have any issues with things not sticking that way. For Royale, all it's settings can be handled by editing the user-settings.h file in it's folder. After opening that in your text editor of choice, change:
#define RUNTIME_SHADER_PARAMS_ENABLE
to
//#define RUNTIME_SHADER_PARAMS_ENABLE
That disables changing this shader's settings from the menu. It makes the shader run better too. Now all your settings are handled in the user-settings.h file. Basically, any line in that file that doesn't have a // in front of it is a setting you can change, and there's documentation above each one describing what they do.
to
Holy moly! Never knew that, thanks man. This should certainly fix the issue. I will try it out tonight after work.
You can try opening a file from the crt-royale-settings-files folder with the name of whatever graphics you have (intel, nvidia, or ati/amd). Then copy the contents of that and paste it over everything in your user-settings.h. Then add the // to the beginning of that line again and see if it works.
Idk why but, when ever I enable the //#define RUNTIME_SHADER_PARAMS_ENABLE I just get a black screen. If I disable it, it works but will not accept changes. Such a weird predicament. This is one of two different PC's so it isn't pertained to just the one. I am using 1.0.0.3 beta x64, not a nightly. I am currently trying both GL and D3D video driver settings. If that fails, maybe I should try the x86 version even though I am on 7 64.
*Update*
Switched over the x86 build and everything seems to be working as should. I was able to manually edit in the settings I wanted via the command you listed. I guess I will avoid the x64 build until official release. No idea what the conflict is or why the x64 would give a black screen and the x86 wouldn't.
*shrugs*
Hi! I had the same problems. I think the Nightly files of x64 fixed that ... I don't remember but I sure had those same exact issues :(
I have it working on more than 10 systems now, more to come. I like the flexibility of changing things on the fly. Bezels. Shaders. Core options. Controls.
I think I have used in the Consoles systems, to use the Xbox 360 controler better (can power on the controler AFTER the emulator)... this is a BIG PLUS!!
*Update*
*shrugs*
That's quite strange, but at least you found something that lets you edit your settings. 32bit builds are somewhat limited, no PPSSPP core and Mupen64 32bit crashed the last time I tried it. Hopefully a nightly like vampirolatino2 suggests or 1.1 when that comes out fixes 64bit for you if you want to use those cores. The latest nightlies have a problem with hardware sampling in Royale, which I like to use with the shadow mask option, so I'm trying out crt-easymode as my default for a bit. Since it's a single pass shader it starts up much faster, but I'm not quite used to how much darker it is yet...
Does anyone know of a recommended nightly x64 build that works with the royale shader? I was thinking about checking out CRT Easymode, from the screens I saw I didn't care for the darkness like you mentioned. I am sure it can be adjusted. If you find a good setting could you take a screen and post your settings? Thanks!
The last nightly that didn't have the issue I mentioned was 2015-02-18. I tried some modifications to easymode, but so far I like how it looks with defaults. Here are a few shots:
Diddy Kong Racing - http://abload.de/img/retroarch-0226-1342048lu5j.png
Ninja Gaiden II - http://i.imgur.com/cuLQoGh.png
Holy Umbrella - http://i.imgur.com/iwlLmuN.png
Sonic 2 Beta - http://i.imgur.com/uTQlSkl.png
Rayforce - http://abload.de/img/retroarch-0226-1347474wu2r.png
Ibara - http://abload.de/img/retroarch-0226-134919k6utf.png
Gunbird 2 - http://abload.de/img/retroarch-0226-1349441kuyj.png
