Hyperspin freezes opening rom til I hit escape?
Jefferrari
Everytime I'm trying to open a rom on n64 or any sega system, hyperspin freezes and I can hear the rom running. Once I hit escape it goes to the rom and I can play,but then I must hit escape again and it takes it out of full screen then I have to close that window to get back into hyperspin.
Anyway I can fix this so when I open the rom it loads instantly, and when I escape it goes directly back to hyperspin?
Welcome to the forum :)
Those emulators use the escape key to switch between full and windowed. You need to change the exit emulator key in HLHQ to something other than escape.
Why the emulators aren't in focus I don't know, make sure everything is up to date and then post your HyperLaunch log set to troubleshooting.
I'm trying to run the latest project 64, but not sure if hyperlaunch has the latest module for it? or whether I just cant find that module! lol first time setting this stuff up so slowly but surely trying to do everything properly.
Do you know anything about the n64 project64 v.2 module?
Thanks for the help!
OK, so lets go back to the beginning. Did you download Hyperlaunch from HyperLaunch.net or did you download the files just from here?
If just from here then you need to head over to http://www.hyperlaunch.net/forum/downloads.php and grab the files from there.
Next follow a guide for installing it all correctly, you can try this or I have some video guides in my signature.
Once installed correctly I would then recommend you set up GIT to keep it up to date.
When all that is done, then you can start setting up emulators and running games.
Sorry it's a lot to take in :)
I have git configured in my Arcade, but when I'm in another PC and want to download everything I use the GIT repository via web: https://code.google.com/p/hyperlaunch-3/source/browse/
just click download zip or tar.gz in that link, it download a file called hyperlaunch-3-### then you just copy and paste it in your arcade cab hyperlaunch main folder.
We are at HyperLaunch v3.1.0.4 Beta btw :D
Yea I have hyperspin 1.3 and the Hyperlaunch v3.1.0.4 beta, but now everytime I add a system its not showing up on my list, I even do the add database from roms folder and it scans and says it found over 6000 roms, yet I cant add the system?
Im still having trouble...Im using an external hard drive, should I set everything to be in my c drive instead? like c:/hyperspin
and just have it direct my roms to my hard drive?
I thought I wrote a reply, but still having trouble....I am using an external hard drive for this, not sure If i specifically have to have the emulators installed in c:/hyperspin emulators folder or not
