Ive gotta be missing something, HELP
Joenaz
I have tried for weeks to solve my issue as to not clog up the forum with another "Easy question"... heres the situation, I have started an install from scratch and have all the latest versions, including the hyperlaunch (git) update. Dons tools tells me that all my rom names match, Starting with NES, followed install and set up to the letter, Hyperlaunch HQ will launch the rom, Hyperlaunch will also launch the rom, Hyperspin will not. "Cannot find rom..with any provided extension". triple checked HyperHQ and extensions are exactly as they should be... PLease help.
Hyperspin Log:
11:34:07 AM | HyperSpin Started
11:34:07 AM | Going windowed mode
11:34:07 AM | Checking for updates
11:34:07 AM | Update Check Complete
11:34:07 AM | Startup program unavailable
11:34:07 AM | Playing intro video
11:34:19 AM | Error intializing joysticks
11:34:19 AM | Menu Mode is multi
11:34:19 AM | Loading Main Menu.xml
11:34:19 AM | Main Menu.xml successfully loaded
11:34:20 AM | Main Menu wheel loaded successfully
11:34:23 AM | Loading Nintendo Entertainment System.xml
11:34:23 AM | Main Menu.xml successfully loaded
11:34:24 AM | Nintendo Entertainment System wheel loaded successfully
11:34:26 AM | Launching Game
11:34:26 AM | Using HyperLaunch
11:34:26 AM | Getting HyperLaunch path
11:34:26 AM | HyperLaunch located at X:\Hyperspin\HyperLaunch.exe
11:34:26 AM | Running HyperLaunch.exe
11:34:26 AM | HyperLaunch Command Line is: X:\Hyperspin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"
11:34:32 AM | Nintendo Entertainment System wheel loaded successfully
11:34:36 AM | Launching Game
11:34:36 AM | Using HyperLaunch
11:34:36 AM | Getting HyperLaunch path
11:34:36 AM | HyperLaunch located at X:\Hyperspin\HyperLaunch.exe
11:34:36 AM | Running HyperLaunch.exe
11:34:36 AM | HyperLaunch Command Line is: X:\Hyperspin\HyperLaunch.exe "Nintendo Entertainment System" "1943 - The Battle of Midway (USA)"
11:34:38 AM | Loading Main Menu.xml
11:34:39 AM | Main Menu.xml successfully loaded
11:34:39 AM | Main Menu wheel loaded successfully
11:34:43 AM | Exit program unavailable
11:34:43 AM | Quiting Hyperspin
11:34:43 AM | Bye!
HyperLaunch Log:
11:34:36 AM |  HyperLaunch v2.25c
11:34:36 AM |  System Specs:
	HyperSpin Dir: X:\Hyperspin
	OS: WIN_VISTA
	OS Language: 0409
	OS Admin Status: No
	Monitor #1 (\\.\DISPLAY1): 1680x1050 (1680x1020 work)
	HyperSpin Res: 174x106
	AHK Version: 1.1.07.03
11:34:36 AM |  HyperLaunch received "Nintendo Entertainment System" and "1943 - The Battle of Midway (USA)"
11:34:36 AM |  INI Keys read
11:34:36 AM |  Checking paths
11:34:37 AM |  Cannot find Rom - X:\Emulators\Nintendo\Roms\1943 - The Battle of Midway (USA) with any provided extension
JNES plays roms fine, HyperLaunch and HLHQ launch the rom
Help Plea
you may have the latest version of Hyperlaunch installed in your system, but your Hyperspin set up is using Hyperlaunch 2.25
go to the folder C:\HyperSpin\Settings
open this ini --> Settings.ini
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Nintendo Wii
Hyperlaunch_Path=C:\HyperSpin\HyperLaunch\
make sure you set this path to RocketLauncher
Make sure you have set your Hyperlaunch Log level to troubleshoot, your log should be about X10 times longer.
sorry that was an old hyperlaunch log from another folder...
Hyperlaunch log:
12:09:47:679 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.4 BETA (www.hyperlaunch.net)
12:09:48:224 | HL |     INFO  | +546   | Main - System Specs:
				HyperLaunch Dir: X:\Hyperspin\HyperLaunch
				HyperLaunch is: 32-bit
				OS: Microsoft® Windows Vista™ Home Premium
				SKU: Home Premium
				Total Memory: 7934.27 MB
				Free Memory: 1820.31 MB
				Used Memory: 6113.953 MB
				SystemType: 64-bit
				Physical Processors: 1
				Logical Processors: 3
				GPU 1 Name: ATI Radeon HD 3200 Graphics
				GPU 1 RAM: 256.00 MB
				GPU 1 Driver Version: 7.01.01.747
				Sound 1 Device: High Definition Audio Device
				Sound 1 Status: Enabled
				Sound 2 Device: Microsoft LifeCam Cinema.
				Sound 2 Status: Enabled
				Sound 3 Device: Realtek High Definition Audio
				Sound 3 Status: Enabled
				Sound 4 Device: PlayOn Virtual Audio Device
				Sound 4 Status: Enabled
				OS Admin Status: No
				Monitor #1 Orientation: Landscape
				Current AHK Desktop Width: 1680
				Current AHK Desktop Height: 1050
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
12:09:48:224 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
12:09:48:224 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
12:09:48:225 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
12:09:48:227 | HL |     INFO  | +0     | GetSystems - Started
12:09:48:227 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\HyperLaunchHQ\Databases\Systems.xml exists
12:09:48:228 | HL |     INFO  | +0     | GetSystems - Found a HyperLaunch Systems.xml: "X:\Hyperspin\HyperLaunch\HyperLaunchHQ\Databases\Systems.xml"
12:09:48:232 | HL |     INFO  | +16    | GetSystems - Ended
12:09:48:274 | HL |     INFO  | +31    | Main - HyperLaunch launched directly
12:09:58:621 | HL |     INFO  | +10358 | Main - HyperLaunchHQ.exe coordinates are x200 y200 w200 h200
12:09:58:621 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Plugins\HyperLaunchHQ.plugin exists
12:09:58:622 | HL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperLaunchHQ"
12:09:58:622 | HL |     INFO  | +0     | Main - HyperLaunch received "Nintendo Entertainment System" and "10-Yard Fight (USA, Europe)"
12:09:58:636 | HL |     INFO  | +16    | Main - 10-Yard Fight (USA, Europe) is using the default emulator: JNes
12:09:58:636 | HL |     INFO  | +0     | Main - Checking for a [JNes] section in X:\Hyperspin\HyperLaunch\Settings\Nintendo Entertainment System\Emulators.ini
12:09:58:637 | HL |     INFO  | +0     | Main - Checking for a [JNes] section in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
12:09:58:638 | HL |     INFO  | +0     | Main - Found [JNes] in X:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
12:09:58:638 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Modules\JNes\JNes.ahk exists
12:09:58:653 | HL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
12:09:58:653 | HL |     INFO  | +0     | Main - 10-Yard Fight (USA, Europe) will use module: X:\Hyperspin\HyperLaunch\Modules\JNes\JNes.ahk
12:09:58:679 | HL |     INFO  | +15    | Main - Did not find a "X:\Hyperspin\HyperLaunch\Settings\Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options.
12:09:58:679 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
12:09:58:681 | HL |     INFO  | +0     | Main - INI Keys read
12:09:58:681 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe exists
12:09:58:683 | HL |     INFO  | +16    | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll exists
12:09:58:684 | HL |     INFO  | +0     | CreateRomMapTable - Started
12:09:58:685 | HL |     INFO  | +0     | AltNameExistCheck - Found rom: X:\Emulators\Nintendo\Roms\10-Yard Fight (USA, Europe).nes
12:09:58:685 | HL |     INFO  | +0     | CreateRomMapTable - Ended, No mapping inis found.
12:09:58:685 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\Module Extensions\FontReg.exe exists
12:10:03:709 | HL |     INFO  | +5023  | Main - "10-Yard Fight (USA, Europe)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
12:10:03:709 | HL |     INFO  | +0     | CheckPaths - Started
12:10:03:710 | HL |     INFO  | +0     | CheckPaths - Found rom: X:\Emulators\Nintendo\Roms\10-Yard Fight (USA, Europe).nes
12:10:03:710 | HL |     INFO  | +0     | CheckPaths - Ended
12:10:03:711 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 0
				pluginPath = X:\Hyperspin\HyperLaunch\Plugins
				pluginName = HyperLaunchHQ
				pluginExt = .plugin
				hlMode =
				hlTitle = HyperLaunch
				hlVersion = 3.1.0.4 BETA
				hlAuthor = djvj
				hlURL = www.hyperlaunch.net
				langFile = X:\Hyperspin\HyperLaunch\Data\Language\Localization.ini
				frontendPID = 264
				frontendPath = X:\Hyperspin\HyperLaunch\HyperLaunchHQ
				frontendExe = HyperLaunchHQ.exe
				frontendExt = exe
				frontendName = HyperLaunchHQ
				frontendDrive = X:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = X:\Emulators\Nintendo\Jnes.exe
				emuPath = X:\Emulators\Nintendo
				emuName = JNes
				emuExt = exe
				romPath = X:\Emulators\Nintendo\Roms
				romPathFromIni = X:\Emulators\Nintendo\Roms
				romExtension = .nes
				romExtensionOrig = .nes
				romExtensions = 7z|zip|nes
				executable = Jnes.exe
				systemName = Nintendo Entertainment System
				dbPath =
				dbName = 10-Yard Fight (USA, Europe)
				dbExt =
				romName = 10-Yard Fight (USA, Europe)
				romMapPath = X:\Hyperspin\HyperLaunch\Settings\Nintendo Entertainment System\Rom Mapping
				romMappingEnabled = true
				romMappingFirstMatchingExt = true
				romMappingMenuWidth = 400
				romMappingMenuMargin = 65
				romMappingTextMargin = 15
				romMappingMenuFlagWidth = 55
				altArchiveNameOnly =
				altRomNameOnly =
				altArchiveAndRomName =
				altArchiveAndManyRomNames =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = true
				blockInputTime = 0
				blockInputFile = X:\Hyperspin\HyperLaunch\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				lockLaunch = false
				lockLaunchGame =
				screenRotationAngle = 0
				screenRotationAngleGame =
				logFile = X:\Hyperspin\HyperLaunch\HyperLaunch.log
				logLevel = 3
				logShowDebugConsole = false
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				hlDebugConsoleStdout =
				sysType = 64-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1680
				originalHeight = 1050
				dtEnabled = false
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				servoStikEnabled = false
				ledblinkyEnabled = false
				ledblinkyFullPath =
				ledblinkyProfilePath = X:\Hyperspin\HyperLaunch\Profiles\LEDBlinky
				ledblinkyHLProfile = X:\Hyperspin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeMuteEmulator = false
				fadeUseBackgrounds = false
				fadeWidthBaseRes = 1920
				fadeHeightBaseRes = 1080
				fadeLyr1Color = FF000000
				fadeLyr2X = 0
				fadeLyr2Y = 0
				fadeLyr2W =
				fadeLyr2H =
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 450
				fadeLyr3Y = 450
				fadeLyr3W =
				fadeLyr3H =
				fadeLyr3Adjust = 0.8
				fadeLyr3PicPad = 0
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3StaticX = 0
				fadeLyr3StaticY = 870|1575
				fadeLyr3StaticW =
				fadeLyr3StaticH =
				fadeLyr3StaticAdjust = 1
				fadeLyr3StaticPicPad = 0
				fadeLyr4Adjust = 1
				fadeLyr4X = 1792|952
				fadeLyr4Y = 891|1596
				fadeLyr4W = 128
				fadeLyr4H =
				fadeLyr4Pos = No Alignment
				fadeLyr4FPS = 50
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = Image
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 900
				fadeBarWindowH = 180
				fadeBarWindowR = 30
				fadeBarWindowM = 30
				fadeBarWindowHatchStyle = 8
				fadeBar = 7zOnly
				fadeBarNon7zProgressTime = 0
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 30
				fadeBarR = 10
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 8
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 150
				fadeRomInfoSystemName = image
				fadeRomInfoManufacturer = text with label
				fadeRomInfoGenre = disabled
				fadeRomInfoRating = image
				fadeRomInfoTextMargin = 7
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeText3 = Loading Game
				fadeText4 = Loading Complete
				fadeFont = Arial
				fadeExtractionTime = disabled
				fadeExtractionTimeTextX = 0
				fadeExtractionTimeTextY = 0
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = X:\Hyperspin\HyperLaunch\Media\Fade
				HLDataPath = X:\Hyperspin\HyperLaunch\Data
				HLMediaPath = X:\Hyperspin\HyperLaunch\Media
				HLErrSoundPath = X:\Hyperspin\HyperLaunch\Media\Sounds\Error
				modulesPath = X:\Hyperspin\HyperLaunch\Modules
				moduleFullName = X:\Hyperspin\HyperLaunch\Modules\JNes\JNes.ahk
				moduleName = JNes
				modulePath = X:\Hyperspin\HyperLaunch\Modules\JNes
				moduleExtension = ahk
				moduleExtensionsPath = X:\Hyperspin\HyperLaunch\Module Extensions
				libPath = X:\Hyperspin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = X:\Hyperspin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = X:\Hyperspin
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgWidthBaseRes = 1920
				mgHeightBaseRes = 1080
				mgYOffset = 500|800
				mgFont = Arial
				mgText2Offset = 100
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = X:\Hyperspin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {1 down}{1 up}{F5 down}{F5 up}|{2 down}{2 up}{F5 down}{F5 up}|{3 down}{3 up}{F5 down}{F5 up}|{4 down}{4 up}{F5 down}{F5 up}|{5 down}{5 up}{F5 down}{F5 up}|{6 down}{6 up}{F5 down}{F5 up}|{7 down}{7 up}{F5 down}{F5 up}|{8 down}{8 up}{F5 down}{F5 up}|{9 down}{9 up}{F5 down}{F5 up}|{0 down}{0 up}{F5 down}{F5 up}
				hpLoadStateKeyCodes = {1 down}{1 up}{F7 down}{F7 up}|{2 down}{2 up}{F7 down}{F7 up}|{3 down}{3 up}{F7 down}{F7 up}|{4 down}{4 up}{F7 down}{F7 up}|{5 down}{5 up}{F7 down}{F7 up}|{6 down}{6 up}{F7 down}{F7 up}|{7 down}{7 up}{F7 down}{F7 up}|{8 down}{8 up}{F7 down}{F7 up}|{9 down}{9 up}{F7 down}{F7 up}|{0 down}{0 up}{F7 down}{F7 up}
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper = xpadder
				xpadderFullPath = X:\Hyperspin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = X:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = X:\Hyperspin\HyperLaunch\Profiles\xpadder
				keymapperFrontEndProfileName = HyperLaunchHQ
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				JoyIDsPreferredControllersGlobal =
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				rotateMethod = false
				FEProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunchHQ
				defaultProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default
				systemProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System
				xPadderSystemProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System\_Default
				emuProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System\JNes
				romProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\Nintendo Entertainment System\10-Yard Fight (USA, Europe)
				HyperLaunchProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\HyperLaunch
				blankProfile = X:\Hyperspin\HyperLaunch\Profiles\xpadder\_Default\blank
				ahkFEProfile = X:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunchHQ
				ahkDefaultProfile = X:\Hyperspin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = X:\Hyperspin\HyperLaunch\Profiles\AHK\Nintendo Entertainment System
				ahkEmuProfile = X:\Hyperspin\HyperLaunch\Profiles\AHK\Nintendo Entertainment System\JNes
				ahkRomProfile = X:\Hyperspin\HyperLaunch\Profiles\AHK\Nintendo Entertainment System\10-Yard Fight (USA, Europe)
				ahkHyperLaunchProfile = X:\Hyperspin\HyperLaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				bezelICEnabled = false
				statisticsEnabled = true
				pressDuration = -1
				emuVolume = 1
				dxwndIni = X:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini
				dxwndFullPath = X:\Hyperspin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe
				mon1O = 0
				pacDrivedllFile = X:\Hyperspin\HyperLaunch\Module Extensions\PacDrive32.dll
				userFadeAnimIniFile = X:\Hyperspin\HyperLaunch\Lib\User Fade Animations.ini
12:10:03:712 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
12:10:03:712 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
12:10:03:712 | HL |  WARNING  | +0     | BuildScript - "X:\Hyperspin\HyperLaunch\Lib\User Functions Init.ahk" not found
12:10:03:712 | HL |     INFO  | +0     | BuildScript - Validating module
12:10:03:713 | HL |     INFO  | +0     | BuildScript - Validation complete
12:10:03:713 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = JNes
				MEmuV =  v1.1
				MURL = http://www.jabosoft.com/categories/1
				MAuthor = djvj
				MVersion = 2.0
				MCRC = 828E1757
				MID = 635038268900200827
				MSystem = "Nintendo Entertainment System","Nintendo Famicom"
				; Notes:
				; To set fullscreen, goto Options->Video->Display and check Enter full screen mode after game is loaded. Leave Full Screen unchecked.
				; If you have any issues with the emu not showing up, remove the Hide at the end of the run line. It's there to give the emu a cleaner launch
				StartModule()
				FadeInStart()
				Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath)
				WinWait("ahk_class Jnes Window")
				WinWaitActive("ahk_class Jnes Window")
				FadeInExit()
				7zCleanUp()
				FadeOutExit()
				ExitModule()
				CloseProcess:
					FadeOutStart()
					WinClose("ahk_class Jnes Window")
				Return
12:10:03:724 | HL |     INFO  | +16    | BuildScript - Loaded Multi-Player scripts
12:10:03:726 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
12:10:03:727 | HL |  WARNING  | +0     | BuildScript - "X:\Hyperspin\HyperLaunch\Lib\User Functions.ahk" not found
12:10:03:727 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
12:10:03:728 | HL |     INFO  | +0     | Main - Module is built
12:10:03:728 | HL |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
12:10:03:734 | HL |     INFO  | +0     | Main - Running module
12:10:03:915 | MD |     INFO  | +N/A   | Module initialized
12:10:03:918 | MD |     INFO  | +0     | StartModule - Started
12:10:03:918 | MD |     INFO  | +0     | StartModule - MEmu: JNes
				MEmuV: v1.1
				MURL: http://www.jabosoft.com/categories/1
				MAuthor: djvj
				MVersion: 2.0
				MCRC: 828E1757
				iCRC:
				MID:
				MSystem: "Nintendo Entertainment System","Nintendo Famicom"
12:10:03:918 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Nintendo Entertainment System"
12:10:03:921 | MD |     INFO  | +0     | PluginInit - Started
12:10:03:921 | MD |     INFO  | +0     | CheckFile - Checking if X:\Hyperspin\HyperLaunch\HyperLaunchHQ\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml exists
12:10:03:939 | MD |     INFO  | +31    | PluginInit - Ended
12:10:03:940 | MD |     INFO  | +0     | StartModule - Ended
12:10:03:940 | MD |     INFO  | +0     | Run - Running: X:\Emulators\Nintendo\Jnes.exe "X:\Emulators\Nintendo\Roms\10-Yard Fight (USA, Europe).nes"
12:10:03:975 | MD |     INFO  | +31    | WinWait - Waiting for "ahk_class Jnes Window"
12:10:04:456 | MD |     INFO  | +484   | WinWaitActive - Waiting for "ahk_class Jnes Window"
12:10:05:231 | MD |     INFO  | +764   | Process - WaitClose Jnes.exe
12:10:08:074 | MD |     INFO  | +2855  | WinClose - Closing: ahk_class Jnes Window
12:10:09:823 | MD |     INFO  | +1747  | ExitModule - Started
12:10:09:823 | MD |     INFO  | +0     | Starting Updating Statistics:
12:10:10:063 | MD |     INFO  | +234   | Game section statistics updated.
12:10:10:067 | MD |     INFO  | +0     | ExitModule - Ended
12:10:10:067 | MD |     INFO  | +0     | End of Module Logs
12:10:10:121 | HL |     INFO  | +6396  | Main - Module ended, exiting HyperLaunch normally
12:10:10:121 | HL |     INFO  | +0     | ExitScript - Started
12:10:10:256 | HL |     INFO  | +124   | SystemCursor - Restoring mouse cursor
12:10:10:267 | HL |     INFO  | +16    | ExitScript - Ended
Again, Hyper Launch and HLHQ will launch the game, (i just double checked)
