Ibanezmike Posted February 28, 2015 Posted February 28, 2015 I am trying to get games to load in STEEM for the Atari ST. I can open the STEEM emulator no worries and it has "Disk A", "Disk B" and the "Trash" at the bottom. But when I open HyperlaunchHQ and try to launch a game, it just opens up the STEEM emulator to the desktop every time. Now I am a super noob in reguards to the Atari ST and old computer systems so I know it's probably just a setting i need to set but there are quite a few settings in STEEM and I have no idea what 3/4 of them do. Is there another emulator I should be using for the Atari ST or do you guys need a screen shot of all my settings to help me figure out whats wrong? Thanks -Mike
craiganderson Posted March 1, 2015 Posted March 1, 2015 you could try this it uses gamebase to launch steem just an option http://www.hyperspin-fe.com/forum/showthread.php?38664-Atari-ST http://craigandersonthemes.weebly.com/
Ibanezmike Posted March 1, 2015 Author Posted March 1, 2015 you could try thisit uses gamebase to launch steem just an option http://www.hyperspin-fe.com/forum/showthread.php?38664-Atari-ST I would rather have just hyperspin running as I am building a cabinet and dont want to have multiple front ends just to run different emulators. If it isn't possible to get the Atari ST to work with Hyperspin it wouldnt worry me in the slightest, I am just a bit of an OCD freak and like to have all systems supported if possible.
craiganderson Posted March 1, 2015 Posted March 1, 2015 I would rather have just hyperspin running as I am building a cabinet and dont want to have multiple front ends just to run different emulators. If it isn't possible to get the Atari ST to work with Hyperspin it wouldnt worry me in the slightest, I amd just a bit of an OCD freak and like to have all systems supported if possible. it does what you are stating gamebase is used as the "emulator" in this setup.... and then gamebase loads steem all via hyperspin/hyperlaunch!! its just that gamebase allows more games to actually work/load/run just an option good luck/have fun either way! here is a video of it working for me kKnLkGIW1wA http://craigandersonthemes.weebly.com/
Ibanezmike Posted March 1, 2015 Author Posted March 1, 2015 Alrighty, I have downloaded Gamebase v1.1 but when i go to "manage emulators" and try to add STEEM the OK button is greyed out? I have typed Atari ST as the name and chose the STEEM exe for the Path/Filename.
craiganderson Posted March 1, 2015 Posted March 1, 2015 some of the necessary stuff to download is located on my little page http://craigandersonthemes.weebly.com/ scroll down and look for atari st but i would say read the instructions here FIRST here are the instructions look for red text takes a little tinkering http://www.hyperspin-fe.com/forum/showthread.php?38664-Atari-ST/page6 http://craigandersonthemes.weebly.com/
Ibanezmike Posted March 1, 2015 Author Posted March 1, 2015 some of the necessary stuff to download is located on my little pagehttp://craigandersonthemes.weebly.com/ scroll down and look for atari st but i would say read the instructions here FIRST here are the instructions look for red text takes a little tinkering http://www.hyperspin-fe.com/forum/showthread.php?38664-Atari-ST/page6 I have tried step by step following your instructions but each time I try to setup STEEM through the "Manage Emulators" the OK button is greyed out. Also I looked at the video of you setting up the STEEM emulator path and you have 3 emulators that show up in the GEMU menu whereas I only have the Manage Emulators listed. I am completley and utterly lost in all this, I think I will just leave the Atari ST alone for a while. Thanks for all the help you've given me, I am quite new to the world of emulators so I will come back to the more advanced emulators a bit later on.
Nexus23 Posted March 1, 2015 Posted March 1, 2015 You can also use Hatari, find it on my FTP folder! It`s not hard to setup! Craiganderson turtorial is also very good, do it step by step! Take a lock at the Video! Hatari also works good for Atari ST, but i think steem is the better Emulator with more compatible!
craiganderson Posted March 1, 2015 Posted March 1, 2015 I have tried step by step following your instructions but each time I try to setup STEEM through the "Manage Emulators" the OK button is greyed out. Also I looked at the video of you setting up the STEEM emulator path and you have 3 emulators that show up in the GEMU menu whereas I only have the Manage Emulators listed. I am completley and utterly lost in all this, I think I will just leave the Atari ST alone for a while. Thanks for all the help you've given me, I am quite new to the world of emulators so I will come back to the more advanced emulators a bit later on. I think that would be a reasonable plan. Mess around with some easier systems and then come back to this one. http://craigandersonthemes.weebly.com/
