Pac-Man Museum/Battle Royale
Conrad
So I ran into an issue with playing Battle Royale under Pac-man Museum. I have the Ultrastick U360 joysticks and have the buttons running into the u360 to give that gamepad input. I also have an IPAC as this is how I originally ran it all before making the switch with the U360 Wire Harnesses. My question is, how can I make these buttons be a start button for this game? The game usually uses xbox 360 controllers it looks like. But I figured I can somehow get them to work with the cab. The first player will automatically as I select the game but not the rest. How can I get a input start button? Xpadder doesn't have a start button option to configure with. Any Ideas? I would love to have 4 players playing this game against each other in my cab.
Thanks,
Conrad
Noones done this? I'm really surprised as its such a fun game. I have the xbox controllers working. Just would rather do it with joysticks....
yeah from what i gather, this game only responds to xbox controllers. Pretty lame if that's the case. I couldn't figure out how to get anything to control it other than an xbox controller. I guess we have to get 4?
Yeah I only have 2 xbox 360 controllers... Guess I have to see if I can find a couple more used for a good price. What a shame that is. I did add Mortal Kombat 9 on and it worked flawless with the joysticks which was awesome to play a newer version. Now I will have to get the next version coming out next month.
Or check x360ce :)
hmmm that looks like it could do the trick. Wish someone could hack the code to the actual game to allow a normal input reconfiguration menu option.
I use x360ce for everything it works... There is 2 versions. App version easy to use. And lib verwion that requerw manual ini editong. The best option if you have problems with the app version is to use lib version ingame and use app version just for buttons configuration. There is an advanced guide somewhere
Well that's awesome to hear. I'm going to have to check this out as it looks like it would do the trick! Wow, thank you so much :)
I just wanted to state that this did work and now I can use Pac-Man Battle Royal with 4 joysticks on my cab :)
