Hyperlaunch HQ error - autokey.dll (noob warning!)
andrewj83
Hello...First post. Hopefully I won't do anything too offensive. I'm trying to launch MAME, followed the instructions (as far as I know), audit roms, click rocket and I receive this error:
This is the log from within Hyperlaunch HQ:
23:11:52:845 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.1.0.5 BETA (www.hyperlaunch.net)
23:11:52:847 | HL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
23:11:52:921 | HL |     INFO  | +78    | Main - System Specs:
				HyperLaunch Dir: S:\HyperSpin\HyperLaunch
				HyperLaunch is: 32-bit
				OS: Microsoft Windows 7 Home Premium
				SKU: Home Premium
				Total Memory: 12279.05 MB
				Free Memory: 8306.89 MB
				Used Memory: 3972.164 MB
				SystemType: 64-bit
				Physical Processors: 1
				Logical Processors: 4
				GPU 1 Name: AMD Radeon HD 7900 Series
				GPU 1 RAM: -1024.00 MB
				GPU 1 Driver Version: 9.12.0.0
				Sound 1 Device: SB X-Fi Xtreme Audio
				Sound 1 Status: Enabled
				Sound 2 Device: AMD High Definition Audio Device
				Sound 2 Status: Enabled
				Sound 3 Device: High Definition Audio Device
				Sound 3 Status: Enabled
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1680x1050 (1680x1010 work)
				Monitor #1 Orientation: Landscape
				Current AHK Desktop Width: 1680
				Current AHK Desktop Height: 1050
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
23:11:52:923 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\HyperLaunch.exe exists
23:11:52:925 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	Your favorite Front End companion! Visit us @ www.hyperlaunch.net
				FileVersion             	3.1.0.5
				LegalCopyright          	�2014 HyperLaunch
				CompanyName             	HyperLaunch BETA
				File Size:			971264 bytes
				Created:			3/2/2015 - 8:54:10 PM
				Modified:			3/2/2015 - 8:52:41 PM
23:11:52:927 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
23:11:52:929 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			409 bytes
				Created:			3/2/2015 - 8:54:09 PM
				Modified:			3/2/2015 - 8:52:43 PM
23:11:52:930 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
23:11:52:994 | HL |   DEBUG1  | +62    | CheckFile - Attributes:
				FileDescription         	DxWnd MFC application
				FileVersion             	1, 0, 0, 1
				InternalName            	DxWnd
				LegalCopyright          	Copyright (C) 2004/2012
				OriginalFilename        	DxWnd.exe
				ProductName             	DxWnd application
				ProductVersion          	1, 0, 0, 1
				File Size:			539136 bytes
23:11:52:996 | HL |     INFO  | +16    | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\BinHexRW.ahk exists
23:11:52:004 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:006 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			4961 bytes
				Modified:			3/2/2015 - 8:52:42 PM
23:11:53:008 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe exists
23:11:53:082 | HL |   DEBUG1  | +78    | CheckFile - Attributes:
				FileDescription
				InternalName
				OriginalFilename
				ProductName
				File Size:			657920 bytes
23:11:53:084 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\CLR.ahk exists
23:11:53:090 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:092 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10586 bytes
23:11:53:094 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\COM.ahk exists
23:11:53:100 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:102 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26342 bytes
23:11:53:104 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\Control_AniGif.ahk exists
23:11:53:107 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:109 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			5716 bytes
23:11:53:111 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini exists
23:11:53:113 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
23:11:53:115 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe exists
23:11:53:117 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				InternalName            	DxWnd
23:11:53:119 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\gdip.ahk exists
23:11:53:127 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:129 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
23:11:53:131 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\gdip_alt.ahk exists
23:11:53:136 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:138 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3394 bytes
23:11:53:140 | HL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.1
23:11:53:142 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\gsdll32.dll exists
23:11:53:166 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			13090816 bytes
23:11:53:168 | HL |     INFO  | +15    | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\itextsharp.dll exists
23:11:53:187 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileDescription         	iTextSharp
				FileVersion             	5.4.2.0
				InternalName            	itextsharp.dll
				LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
				OriginalFilename        	itextsharp.dll
				ProductName             	iTextSharp
				ProductVersion          	5.4.2.0
				CompanyName             	1T3XT BVBA
				File Size:			3743744 bytes
				Modified:			3/2/2015 - 8:52:44 PM
23:11:53:189 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\Java.ahk exists
23:11:53:193 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:195 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			7841 bytes
23:11:53:197 | HL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
23:11:53:199 | HL |     INFO  | +16    | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\JSON.ahk exists
23:11:53:206 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:208 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
23:11:53:210 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\Origin.ahk exists
23:11:53:216 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:219 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			4901 bytes
23:11:53:220 | HL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.1
23:11:53:222 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll exists
23:11:53:253 | HL |   DEBUG1  | +31    | CheckFile - Attributes:
				File Size:			69120 bytes
23:11:53:255 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\RegRW64.ahk exists
23:11:53:262 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:264 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			6915 bytes
23:11:53:266 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\RIni.ahk exists
23:11:53:278 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:280 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67561 bytes
23:11:53:282 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\SevenZipSharp.dll exists
23:11:53:296 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				FileDescription         	SevenZipSharp
				FileVersion             	0.64.4841.31212
				InternalName            	SevenZipSharp.dll
				LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
				OriginalFilename        	SevenZipSharp.dll
				ProductName             	SevenZipSharp
				ProductVersion          	0.64.4841.31212
				CompanyName             	Markovtsev Vadim
				File Size:			165888 bytes
23:11:53:298 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\Steam.ahk exists
23:11:53:305 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:307 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			5344 bytes
23:11:53:309 | HL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.1
23:11:53:311 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\VA.ahk exists
23:11:53:319 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:11:53:321 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			34688 bytes
23:11:53:323 | HL |     INFO  | +15    | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\VA_Extension.ahk exists
23:11:53:327 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:329 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3833 bytes
23:11:53:331 | HL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
23:11:53:333 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Bezel.ahk exists
23:11:53:339 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:342 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			101738 bytes
23:11:53:344 | HL |   DEBUG1  | +0     | Bezel.ahk Version: 1.0.9
23:11:53:346 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Fade.ahk exists
23:11:53:351 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:353 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			36402 bytes
23:11:53:355 | HL |   DEBUG1  | +16    | Fade.ahk Version: 1.0.9
23:11:53:357 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Fade Init.ahk exists
23:11:53:361 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:363 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			999 bytes
23:11:53:365 | HL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
23:11:53:367 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Fade Animations.ahk exists
23:11:53:373 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:375 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67602 bytes
23:11:53:377 | HL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.1
23:11:53:379 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\HyperPause.ahk exists
23:11:53:391 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:394 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			392193 bytes
23:11:53:396 | HL |   DEBUG1  | +0     | HyperPause.ahk Version: 1.0.8
23:11:53:398 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\HyperPause Init.ahk exists
23:11:53:402 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:404 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			537 bytes
23:11:53:406 | HL |   DEBUG1  | +0     | HyperPause Init.ahk Version: 1.0.1
23:11:53:408 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Keymapper.ahk exists
23:11:53:413 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:415 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			32953 bytes
23:11:53:417 | HL |   DEBUG1  | +16    | Keymapper.ahk Version: 1.0.9
23:11:53:419 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Keymapper Init.ahk exists
23:11:53:423 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:426 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3435 bytes
23:11:53:428 | HL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.2
23:11:53:430 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\MultiGame.ahk exists
23:11:53:434 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:437 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			40584 bytes
23:11:53:439 | HL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.6
23:11:53:441 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\MultiGame Init.ahk exists
23:11:53:445 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:447 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			161 bytes
23:11:53:449 | HL |   DEBUG1  | +15    | MultiGame Init.ahk Version: 1.0.0
23:11:53:451 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\MultiPlayer.ahk exists
23:11:53:456 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:459 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			58605 bytes
23:11:53:461 | HL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.4
23:11:53:463 | HL |     INFO  | +16    | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Password.ahk exists
23:11:53:467 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:469 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10035 bytes
23:11:53:471 | HL |   DEBUG1  | +0     | Password.ahk Version: 1.0.0
23:11:53:473 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Rom Mapping Launch Menu.ahk exists
23:11:53:479 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:481 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			73560 bytes
23:11:53:483 | HL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.3
23:11:53:485 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Shared.ahk exists
23:11:53:492 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:494 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			140963 bytes
23:11:53:496 | HL |   DEBUG1  | +16    | Shared.ahk Version: 1.2.1
23:11:53:498 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Statistics.ahk exists
23:11:53:503 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:505 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26170 bytes
23:11:53:507 | HL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.2
23:11:53:509 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\Statistics Init.ahk exists
23:11:53:513 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:516 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			33 bytes
23:11:53:517 | HL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
23:11:53:517 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\XHotkey.ahk exists
23:11:53:517 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:517 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			29623 bytes
23:11:53:517 | HL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.2
23:11:53:517 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Lib\XHotkey Init.ahk exists
23:11:53:532 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:11:53:532 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			1236 bytes
23:11:53:532 | HL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.0
23:11:53:532 | HL |   DEBUG1  | +0     | Main - Raw CLI received: "-s MAME -r 1941 -f S:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1"
23:11:53:532 | HL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "1941"
23:11:53:532 | HL |   DEBUG1  | +0     | Main - dbName: 1941
23:11:53:532 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Plugins\HyperSpin.plugin exists
23:11:53:548 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			8999 bytes
				Modified:			3/2/2015 - 8:52:45 PM
23:11:53:548 | HL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
23:11:53:548 | HL |     INFO  | +0     | Main - HyperLaunch received "MAME" and "1941"
23:11:53:548 | HL |     INFO  | +0     | Main - 1941 is using the default emulator: MAME
23:11:53:565 | HL |     INFO  | +15    | Main - Checking for a [MAME] section in S:\HyperSpin\HyperLaunch\Settings\MAME\Emulators.ini
23:11:53:567 | HL |     INFO  | +0     | Main - Checking for a [MAME] section in S:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
23:11:53:569 | HL |     INFO  | +0     | Main - Found [MAME] in S:\HyperSpin\HyperLaunch\Settings\Global Emulators.ini
23:11:53:571 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk exists
23:11:53:574 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			12086 bytes
23:11:53:579 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
23:11:53:581 | HL |     INFO  | +0     | Main - 1941 will use module: S:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk
23:11:53:597 | HL |     INFO  | +16    | Main - Did not find a "S:\HyperSpin\HyperLaunch\Settings\MAME\Game Options.ini" file, skipping any game-specific options.
23:11:53:599 | HL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
23:11:53:605 | HL |     INFO  | +15    | CheckFile - Checking if S:\HyperSpin\Emulators\MAME\0159\mame64.exe exists
23:11:53:608 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	Multiple Arcade Machine Emulator
				FileVersion             	0, 159, 0, 0
				InternalName            	MAME
				LegalCopyright          	Copyright Nicola Salmoria and the MAME team
				OriginalFilename        	MAME
				ProductName             	MAME
				ProductVersion          	0.159
				CompanyName             	MAME Team
				File Size:			93157376 bytes
				Created:			3/2/2015 - 9:19:56 PM
				Modified:			2/25/2015 - 9:31:44 AM
23:11:53:610 | HL |     INFO  | +0     | Main - INI Keys read
23:11:53:612 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\7z.exe exists
23:11:53:631 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				File Size:			163840 bytes
23:11:53:633 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\7z.dll exists
23:11:53:652 | HL |   DEBUG1  | +31    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			914432 bytes
23:11:53:654 | HL |     INFO  | +0     | CheckFile - Checking if S:\HyperSpin\HyperLaunch\Module Extensions\FontReg.exe exists
23:11:53:656 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	Font Registration Utility (x86-32)
				FileVersion             	2.1.3.0
				OriginalFilename        	FontReg.exe
				File Size:			6144 bytes
23:11:55:256 | HL |     INFO  | +1591  | Main - "1941" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
23:11:55:258 | HL |     INFO  | +16    | CheckPaths - Started
23:11:55:260 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: S:\HyperSpin\Emulators\MAME\0159\roms\1941.zip
23:11:55:263 | HL |     INFO  | +0     | CheckPaths - Found rom: S:\HyperSpin\Emulators\MAME\0159\roms\1941.zip
23:11:55:265 | HL |   DEBUG1  | +0     | CheckPaths - Current romName: 1941
23:11:55:267 | HL |   DEBUG1  | +0     | CheckPaths - Current romPath: S:\HyperSpin\Emulators\MAME\0159\roms
23:11:55:269 | HL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .zip
23:11:55:271 | HL |     INFO  | +0     | CheckPaths - Ended
23:11:55:274 | HL |     INFO  | +15    | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 10
				pluginPath = S:\HyperSpin\HyperLaunch\Plugins
				pluginName = HyperSpin
				pluginExt = .plugin
				contextOnExit = 1
				hlMode =
				hlTitle = HyperLaunch
				hlVersion = 3.1.0.5 BETA
				hlAuthor = djvj
				hlURL = www.hyperlaunch.net
				langFile = S:\HyperSpin\HyperLaunch\Data\Language\Localization.ini
				frontendPID =
				frontendPath = S:\HyperSpin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = S:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = S:\HyperSpin\Emulators\MAME\0159\mame64.exe
				emuPath = S:\HyperSpin\Emulators\MAME\0159
				emuName = MAME
				emuExt = exe
				romPath = S:\HyperSpin\Emulators\MAME\0159\roms
				romPathFromIni = S:\HyperSpin\Emulators\MAME\0159\roms
				romExtension = .zip
				romExtensionOrig = .zip
				romExtensions = zip|7z
				executable = mame64.exe
				systemName = MAME
				dbPath =
				dbName = 1941
				dbExt =
				romName = 1941
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 400
				romMappingMenuMargin = 65
				romMappingTextMargin = 15
				romMappingMenuFlagWidth = 55
				altArchiveNameOnly =
				altRomNameOnly =
				altArchiveAndRomName =
				altArchiveAndManyRomNames =
				altRomNamesOnly =
				romMapScenario =
				skipchecks = false
				romMatchExt = false
				blockInputTime = 0
				blockInputFile = S:\HyperSpin\HyperLaunch\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				lockLaunch = false
				lockLaunchGame =
				screenRotationAngle = 0
				screenRotationAngleGame =
				logFile = S:\HyperSpin\HyperLaunch\HyperLaunch.log
				logLevel = 10
				logShowDebugConsole = false
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = true
				hlDebugConsoleStdout =
				sysType = 64-bit
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1680
				originalHeight = 1050
				dtEnabled = false
				dtPath =
				dtUseSCSI = true
				dtAddDrive = true
				servoStikEnabled = false
				ledblinkyEnabled = false
				ledblinkyFullPath =
				ledblinkyProfilePath = S:\HyperSpin\HyperLaunch\Profiles\LEDBlinky
				ledblinkyHLProfile = S:\HyperSpin\HyperLaunch\Profiles\LEDBlinky\HyperLaunch
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeMuteEmulator = false
				fadeUseBackgrounds = false
				fadeWidthBaseRes = 1920
				fadeHeightBaseRes = 1080
				fadeLyr1Color = FF000000
				fadeLyr2X = 0
				fadeLyr2Y = 0
				fadeLyr2W =
				fadeLyr2H =
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 450
				fadeLyr3Y = 450
				fadeLyr3W =
				fadeLyr3H =
				fadeLyr3Adjust = 1
				fadeLyr3PicPad = 0
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3StaticX = 0
				fadeLyr3StaticY = 870|1575
				fadeLyr3StaticW =
				fadeLyr3StaticH =
				fadeLyr3StaticAdjust = 1
				fadeLyr3StaticPicPad = 0
				fadeLyr4Adjust = 1
				fadeLyr4X = 1792|952
				fadeLyr4Y = 891|1596
				fadeLyr4W = 128
				fadeLyr4H =
				fadeLyr4Pos = No Alignment
				fadeLyr4FPS = 50
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = Image
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 900
				fadeBarWindowH =
				fadeBarWindowR = 30
				fadeBarWindowM = 30
				fadeBarWindowHatchStyle = 8
				fadeBar = 7zOnly
				fadeBarNon7zProgressTime = 0
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 30
				fadeBarR = 10
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 8
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 150
				fadeRomInfoSystemName = image
				fadeRomInfoManufacturer = text with label
				fadeRomInfoGenre = disabled
				fadeRomInfoRating = image
				fadeRomInfoTextMargin = 7
				fadeStatsInfoTextMargin = 7
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeText3 = Loading Game
				fadeText4 = Loading Complete
				fadeFont = Bebas Neue
				fadeExtractionTime = disabled
				fadeExtractionTimeTextX = 0
				fadeExtractionTimeTextY = 0
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = S:\HyperSpin\HyperLaunch\Media\Fade
				HLDataPath = S:\HyperSpin\HyperLaunch\Data
				HLMediaPath = S:\HyperSpin\HyperLaunch\Media
				HLErrSoundPath = S:\HyperSpin\HyperLaunch\Media\Sounds\Error
				modulesPath = S:\HyperSpin\HyperLaunch\Modules
				moduleFullName = S:\HyperSpin\HyperLaunch\Modules\MAME\MAME.ahk
				moduleName = MAME
				modulePath = S:\HyperSpin\HyperLaunch\Modules\MAME
				moduleExtension = ahk
				moduleExtensionsPath = S:\HyperSpin\HyperLaunch\Module Extensions
				libPath = S:\HyperSpin\HyperLaunch\Lib
				7zEnabled = false
				7zPath = S:\HyperSpin\HyperLaunch\Module Extensions\7z.exe
				7zDllPath = S:\HyperSpin\HyperLaunch\Module Extensions\7z.dll
				7zExtractPath = C:\Users\Andrew\AppData\Local\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgWidthBaseRes = 1920
				mgHeightBaseRes = 1080
				mgYOffset = 500|800
				mgFont = Arial
				mgText2Offset = 100
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgCandidate =
				mgOnLaunch = false
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = S:\HyperSpin\HyperLaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {shift down}{F7 down}{F7 up}{shift up}
				hpLoadStateKeyCodes = {F7 down}{F7 up}
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper = xpadder
				xpadderFullPath = S:\HyperSpin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = S:\HyperSpin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = S:\HyperSpin\HyperLaunch\Profiles\xpadder
				keymapperFrontEndProfileName = HyperLaunchHQ
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				JoyIDsPreferredControllersGlobal = playsega controller
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				rotateMethod = false
				FEProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperLaunchHQ
				defaultProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default
				systemProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\MAME
				xPadderSystemProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\MAME\_Default
				emuProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\MAME\MAME
				romProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\MAME\1941
				HyperLaunchProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\HyperLaunch
				blankProfile = S:\HyperSpin\HyperLaunch\Profiles\xpadder\_Default\blank
				ahkFEProfile = S:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunchHQ
				ahkDefaultProfile = S:\HyperSpin\HyperLaunch\Profiles\AHK\_Default
				ahkSystemProfile = S:\HyperSpin\HyperLaunch\Profiles\AHK\MAME
				ahkEmuProfile = S:\HyperSpin\HyperLaunch\Profiles\AHK\MAME\MAME
				ahkRomProfile = S:\HyperSpin\HyperLaunch\Profiles\AHK\MAME\1941
				ahkHyperLaunchProfile = S:\HyperSpin\HyperLaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				bezelICEnabled = false
				statisticsEnabled = true
				pressDuration = -1
				emuVolume = 1
				dxwndIni = S:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.ini
				dxwndFullPath = S:\HyperSpin\HyperLaunch\Module Extensions\dxwnd\dxwnd.exe
				mon1O = 0
				pacDrivedllFile = S:\HyperSpin\HyperLaunch\Module Extensions\PacDrive32.dll
				userFadeAnimIniFile = S:\HyperSpin\HyperLaunch\Lib\User Fade Animations.ini
23:11:55:276 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
23:11:55:278 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
23:11:55:280 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
23:11:55:282 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
23:11:55:284 | HL |     INFO  | +0     | BuildScript - Validating module
23:11:55:288 | HL |     INFO  | +0     | BuildScript - Validation complete
23:11:55:290 | HL |     INFO  | +16    | BuildScript - Module:
				MEmu = MAME
				MEmuV =  v0.150
				MURL = http://www.mame.net/
				MAuthor = djvj
				MVersion = 2.1.5
				MCRC = 968DA0CB
				iCRC = D88577B3
				MID = 635038268903403479
				MSystem = "AAE","Cave","Capcom","LaserDisc","MAME","Nintendo Arcade Systems","Sega Model 1","Sega ST-V","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS"
				; Notes:
				; No need to edit mame.ini and set your rom folder, module sends the rompath for you.
				; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html
				; High Scores DO NOT SAVE when cheats are enabled!
				; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html
				; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1
				; Bezels:
				; Module settings control whether HyperLaunch or MAME bezels are shown
				; In the bezel normal mode only HyperLaunch Bezels will be show and the MAME use_bezels option will be forced disbaled
				; In the bezel layout mode, HyperLaunch Bezels will be drawn only when you do not have a layout file on your MAME folders for the current game
				; ServoStik:
				; The module will automatically control any connected ServoStiks found on the system.
				; It does this by reading the xml info from MAME. If that XML info has directional info at 4 or less, 4-way mode will be enabled. All others get 8-way mode.
				StartModule()
				BezelGUI()
				FadeInStart()
				legacyMode := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "LegacyMode","false",,1)
				hlsl := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "HLSL","false",,1)
				Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1)
				pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1)	; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers
				bezelMode := IniReadCheck(settingsFile, "Settings", "BezelMode","layout",,1)	; "layout" or "normal"
				cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1)
				cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1)	; user defined key to be held down before launching a mame rom.
				sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1)
				romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1)
				mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1)
				Artwork_Crop := IniReadCheck(settingsFile, systemName . "|" . romName, "Artwork_Crop", "true",,1)
				Use_Bezels := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Bezels", "false",,1)
				Use_Overlays := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Overlays", "true",,1)
				Use_Backdrops := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Backdrops", "true",,1)
				Use_Cpanels := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Cpanels", "false",,1)
				Use_Marquees := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Marquees", "false",,1)
				volume := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "Volume",,,1)
				autosave := IniReadCheck(settingsFile, systemName . "|" . romName, "Autosave", "false",,1)
				artworkCrop := If (Artwork_Crop = "true") ? " -artwork_crop" : " -noartwork_crop"
				useBezels := If (Use_Bezels = "true") ? " -use_bezels" : " -nouse_bezels"
				useOverlays := If (Use_Overlays = "true") ? " -use_overlays" : " -nouse_overlays"
				useBackdrops := If (Use_Backdrops = "true") ? " -use_backdrops" : " -nouse_backdrops"
				UseCpanels := If (Use_Cpanels = "true") ? " -use_cpanels" : " -nouse_cpanels"
				UseMarquees := If (Use_Marquees = "true") ? " -use_marquees" : " -nouse_marquees"
				hideEmuObj := Object(dialogOpen . " ahk_class ConsoleWindowClass",0,"ahk_class MAME",1)	;Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
				; Process mame's ListXML for certain features
				If (bezelEnabled = "true" || servoStikEnabled != "false") {
					ListXMLObject := Object()
					ListXMLObject := ListXMLInfo(romName)
					If (bezelEnabled = "true") {
						If (bezelMode = "layout"){
							BezelStart("layout",ListXMLObject["Parent"].Value,ListXMLObject["Angle"].Value,romName)
						} Else { ;bezel mode = normal
							useBezels := " -nouse_bezels"   ; force disabling MAME built-in bezels
							BezelStart(,,ListXMLObject["Angle"].Value)
					If (servoStikEnabled != "false") {
						ServoStik(If ListXMLObject["Ways"].Value <= 4 ? 4 : 8)	; If "ways" in the xml is set to 4 or less, the servo will go into 4-way mode, else 8-way mode will be enabled
				; -romload part of 147u2 that shows what roms were checked when missing roms
				winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel"
				fullscreen := If (Fullscreen = "true") ? " -nowindow" : " -window"
				hlsl := If hlsl = "true" ? " -hlsl_enable" : " -nohlsl_enable"
				videomode := If (Videomode != "" ) ? " -video " . videomode : ""
				sysParams := If sysParams != ""  ? A_Space . sysParams : ""
				romParams := If romParams != ""  ? A_Space . romParams : ""
				autosave := If autosave = "true"  ? " -autosave" : ""
				volume := If volume != ""  ? " -volume " . volume : ""
				StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1	; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms
				mameRomPaths := " -rompath """ .  (If mameRomName ? romPath : mameRomPaths) . """"	; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom
				If InStr(romParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If InStr(sysParams,"-rompath")
					ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
				If mameRomName {
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension%	; rename rom to match what mame needs
					originalRomName := romName	; store romName from database so we know what to rename it back to later
					romName := mameRomName
					If ErrorLevel
						ScriptError("There was a problem renaming " . romName . "  to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8)
					Else	; if rename was successful, set var so we know to move it back later
						fileRenamed = 1
				If cheatMode = true
				{	If (!FileExist(emuPath . "\cheat.zip") && !FileExist(emuPath . "\cheat.7z"))
						ScriptError("You have cheats enabled for " . MEmu . " but could not locate a ""cheat.zip"" or ""cheat.7z"" in " . emuPath)
					If cheatModeKey	; if user wants to use a key to enable CheatMode
						cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? " -cheat" : ""	; only enables cheatMode when key is held down on launch
					Else	; no cheat mode key defined
						cheatEnabled := " -cheat"
				HideEmuStart()
				If legacyMode = true
					errLvl := Run(executable . A_Space . romName . fullscreen . cheatEnabled . volume . mameRomPaths . sysParams . romParams, emuPath, winstate)
				Else
					errLvl := Run(executable . A_Space . romName . fullscreen . hlsl . cheatEnabled . volume . videomode . artworkCrop . useBezels . useOverlays . useBackdrops . UseCpanels . UseMarquees . mameRomPaths . sysParams . romParams . autosave, emuPath, winstate)
				If errLvl {
					If (errLvl = 1)
						Error = Failed Validity
					Else If(errLvl = 2)
						Error = Missing Files
					Else If(errLvl = 3)
						Error = Fatal Error
					Else If(errLvl = 4)
						Error = Device Error
					Else If(errLvl = 5)
						Error = Game Does Not Exist
					Else If(errLvl = 6)
						Error = Invalid Config
					Else If errLvl in 7,8,9
						Error = Identification Error
					Else
						Error = MAME Error
					Log("MAME Error - " . Error,3)
				WinWait("ahk_class MAME")
				WinWaitActive("ahk_class MAME")
				BezelDraw()
				HideEmuEnd()
				FadeInExit()
				BezelExit()
				If fileRenamed {	; rename file back to alternate name for next launch
					FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension%
					If ErrorLevel	; if rename was successful, set var so we know to move it back later
						ScriptError("There was a problem renaming " . romName . " back to " . originalRomName)
				FadeOutExit()
				ExitModule()
				ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution
					Global emuFullPath, emuPath
					listXMLVarLog :=
					RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide
					Fileread, ListxmlContents, %emuPath%\tempBezel.txt
					RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent)
					RegExMatch(parent,"cloneof=" . """" . ".*", parent)
					RegExMatch(parent,"""" . ".*", parent)
					StringTrimLeft, parent, parent, 1
					RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle)
					RegExMatch(angle,"[0-9]+", angle, "-6")
					RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width)
					RegExMatch(width,"[0-9]+", width, "-6")
					RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height)
					RegExMatch(Height,"[0-9]+", Height, "-6")
					RegExMatch(ListxmlContents, "s)<control.*ways=" . """" . "[0-9]+" . """", Ways)
					RegExMatch(Ways,"[0-9]+", Ways, "-6")
					logVars := "Parent|Angle|Height|Width|Ways"
					Loop, Parse, logVars, |
						currentobj:={}
						currentobj.Label := A_Loopfield
						currentobj.Value := %A_Loopfield%
						ListXMLObject.Insert(currentobj["Label"], currentobj)
						listXMLLog .= "`r`n`t`t`t`t`t" . currentobj["Label"] . " = " . currentobj["Value"]
					Log("Module - MAME ListXML values: " . listXMLLog,5)
					If (ListXMLObject["Height"].Value > ListXMLObject["Width"].Value) {
						ListXMLObject["Angle"].Value := true
						Log("Module - This game's height is greater than its width, forcing vertical mode",5)
					FileDelete, %emuPath%\tempBezel.txt
					Return ListXMLObject
				HaltEmu:
					If pauseMethod = 1
					{	disableSuspendEmu = true
						disableRestoreEmu = true
						PostMessage,0x211, 1, , , ahk_class MAME
					} Else If pauseMethod = 2
					} Else If pauseMethod = 3
						PostMessage,% 0x0400+6, 1, , , ahk_class MAME
					} Else If pauseMethod = 4
					} Else If pauseMethod = 5
						Send, {P down}
						Sleep, 1000
						Send, {P up}
				Return
				RestoreEmu:
					If pauseMethod = 1
					{	PostMessage,0x212, 1, , , ahk_class MAME
						WinActivate, ahk_class MAME
					{	PostMessage,% 0x0400+6, 0, , , ahk_class MAME
						Send, {P down}
						Sleep, 1000
						Send, {P up}
					} Else If pauseMethod = 6
				Return
				CloseProcess:
					FadeOutStart()
					WinClose("ahk_class MAME")
				Return
23:11:55:302 | HL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
23:11:55:310 | HL |     INFO  | +16    | BuildScript - Loaded Statistics.ahk script
23:11:55:317 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
23:11:55:324 | HL |     INFO  | +15    | BuildScript - Finished injecting functions into module
23:11:55:332 | HL |     INFO  | +0     | Main - Module is built
23:11:55:335 | HL |     INFO  | +16    | CheckFile - Checking if S:\HyperSpin\HyperLaunch\AutoHotkey.dll exists
23:11:55:337 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			785408 bytes
				Modified:			3/2/2015 - 8:52:39 PM
23:11:55:340 | HL |     INFO  | +0     | Main - Running module
23:11:55:342 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
23:21:56:598 | HL |     INFO  | +601259 | Main - Module ended, exiting HyperLaunch normally
23:21:56:603 | HL |     INFO  | +0     | ExitScript - Started
23:21:56:616 | HL |     INFO  | +15    | SystemCursor - Restoring mouse cursor
23:21:56:624 | HL |     INFO  | +0     | ExitScript - Ended
I suspect I'm doing/have done something very stupid indeed, but I've no idea what.
If you've just done a git pull, you will get that error, I know, I did.
You can wait for it to be fixed or roll back the modules.
More info at HyperLaunch.net
Just done a git update and now I get Steam errors when I try to run any Mame game
Update: Autohotkey.dll error trying to run anything in Hyperlaunchhq, error says Too Many Parameters Passed then gives a load of Steam errors
