cannot find hyperlaunch.exe
acko64
wasn't sure if I should start a new thread or use this one. I am having a similiar issue but unsure why.
Just to be clear I had a working 1.3 setup and I decided to do a fresh install of 1.4 I did not buy a drive. I I can launch a game in RLauncher but I can not launch any games from within hyperspin since I updated to 1.4. I can see all of my games and wheels but when I hit enter on my keyboard games do not launch from within hyperspin.
here is what I believe to be the important part of my settings.ini:
[Main]
Menu_Mode=multi
Single_Mode_Name=Nintendo Wii
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Nintendo Entertainment System
Hyperlaunch_Path=E:\HyperSpin\HyperLaunch\
and here is the my last log:
10:36:32 PM |  HyperSpin Started
10:36:32 PM |  Going windowed mode
10:36:32 PM |  Checking for updates
10:36:32 PM |  Update Check Complete
10:36:32 PM |  Startup program unavailable
10:36:32 PM |  Menu Mode is multi
10:36:32 PM |  Loading Main Menu.xml
10:36:32 PM |  Main Menu.xml successfully loaded
10:36:33 PM |  Main Menu wheel loaded successfully
10:36:34 PM |  Loading Nintendo Entertainment System.xml
10:36:34 PM |  roms_only is true, checking files
10:36:34 PM |  Main Menu.xml successfully loaded
10:36:34 PM |  Nintendo Entertainment System wheel loaded successfully
10:36:35 PM |  Launching Game
10:36:35 PM |  Using HyperLaunch
10:36:35 PM |  Getting Launcher path
10:36:35 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
10:36:35 PM |  Launcher located at E:\HyperSpin\HyperLaunch.exe
10:36:35 PM |  Running Launcher
10:36:35 PM |  Launcher Command Line is: E:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"
10:36:38 PM |  Launching Game
10:36:38 PM |  Using HyperLaunch
10:36:38 PM |  Getting Launcher path
10:36:38 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
10:36:38 PM |  Launcher located at E:\HyperSpin\HyperLaunch.exe
10:36:38 PM |  Running Launcher
10:36:38 PM |  Launcher Command Line is: E:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"
10:36:39 PM |  Launching Game
10:36:39 PM |  Using HyperLaunch
10:36:39 PM |  Getting Launcher path
10:36:39 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
10:36:39 PM |  Launcher located at E:\HyperSpin\HyperLaunch.exe
10:36:39 PM |  Running Launcher
10:36:39 PM |  Launcher Command Line is: E:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"
10:36:40 PM |  Launching Game
10:36:40 PM |  Using HyperLaunch
10:36:40 PM |  Getting Launcher path
10:36:40 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
10:36:40 PM |  Launcher located at E:\HyperSpin\HyperLaunch.exe
10:36:40 PM |  Running Launcher
10:36:40 PM |  Launcher Command Line is: E:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "1942 (Japan, USA)"
10:36:41 PM |  Launching Game
10:36:41 PM |  Using HyperLaunch
10:36:41 PM |  Getting Launcher path
10:36:41 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
10:36:41 PM |  Launcher located at E:\HyperSpin\HyperLaunch.exe
10:36:41 PM |  Running Launcher
10:36:41 PM |  Launcher Command Line is: E:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "1942 (Japan, USA)"
10:37:07 PM |  Loading Main Menu.xml
10:37:07 PM |  Main Menu.xml successfully loaded
10:37:08 PM |  Main Menu wheel loaded successfully
10:37:09 PM |  Exit program unavailable
10:37:09 PM |  Quiting Hyperspin
10:37:09 PM |  Bye!
does anyone have any ideas? I am sure I am just overlooking something but I am not sure what it would be at this point. long week at work and I just want to play some games.
Thanks in advance as I know someone will see what I am missing.
Hey Austin! Thanks for responding so quickly.
My hyperspin folder is just called HyperSpin
I have changed it to point towards rocketlauncher (which I just thought the actual launcher exe just never got renamed when they upgraded to rocketlauncher) and I get the same issue:
[Main]
Menu_Mode=multi
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Hyperlaunch_Path=E:\RocketLauncher\RocketLauncher\
and I don't know what the transition tool is... I did follow your video though when I did the fresh install.
that is exact. but I got it to work just now. I had to add the .exe at the end so now my setting that work look like this:
[Main]
Menu_Mode=multi
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Hyperlaunch_Path=E:\RocketLauncher\RocketLauncher.exe
I didn't think you had to type .exe I thought you just needed RocketLauncher. Whew. I knew someone could kick my butt in the right direction.
Thank you Austin!
Can I delete Hyperlaunch from my hyperspin folder then? I have no clue why it is still there since I did the 1.4 upgrade and am using rocketlauncher.
For anyone else with same issue, what needed to be done was THIS
Now for the HyperLaunch Folder yes mate, there should be no problem getting rid of it.  although make sure you have all your settings and media backed up from there if you have used it previously as you may want to add them to your RocketLauncher setup.
Media such as Bezels and Fade could be in there depending on how you had it setup :)
Glad your up and running mate!
