Snesx9 problem
Beardedgamer23
As title says when I try open this outside hyperspin it's just a black screen
No option to edit controls like I did before with my xbox 360 pad
I just want to edit the controller any help as this is my last system to set up
if you right click in snesx9 emulator itself there will be a tab that pops up and youl be able to bring up the options
http://www.fantasyanime.com/emuhelp/emuhelp_snes9x.htm
or slide your cursor up the top and you should see a whole tab that shows
Setting up the buttons on your keyboard or gamepad
Click on Input menu then Joypad Configuration, or press Alt+F7. You'll end up here. This box tells you the buttons that correspond to each SNES button. If you wish to change them, click on the box the arrow is pointing, then press the button you want it to change to. This automatically activates the auto configuration, so the highlighting will jump to each box, awaiting your command for the button that you want it to change to.
Back to top
sig.png 100%
sorry read this part my bad Setting up the buttons on your keyboard or gamepad
Back to top
ALT+F7
sig.png 100%
