nephilim Posted October 26, 2012 Posted October 26, 2012 Hello All, I struggled with getting Daphne and Hyperlaunch 2.25C working the way I wanted for a while. Finally got it all ironed out and working nicely and wanted to share a few notes that may help others in my boat. Also, huge thanks to jonnieboyrevel as his "sort of" guide got me on the right path. (A 'Sort Of' Guide to Daphne) Configuration: I am using an ArcadeVGA to 15k Arcade monitor and HotRodSE controls (transplanted to an arcade cabinet) Windows 7 64bit Main Issue Encountered: I could not get Daphne to recognize the controls I configured in DaphneLoader. I tried the method pointed out by jonnieboyrevel in changing the top line of the Daphne Settings.ini that referenced "homedir= ." to the actual path of my daphne emulator folder. This would not work. What did work is creating a dapinput.ini file as suggested by the Daphne Wiki https://www.daphne-emu.com:9443/mediawiki/index.php/Input. I had to alter my coin and button keys to match my input controller. The list of keys are in a link call keylist and is available from the Daphne wiki link to customize controls for Daphne. https://www.daphne-emu.com:9443/mediawiki/index.php/KeyList [table=width: 500] [tr] [td] dapinput.ini [/td] [/tr] [tr] [td] [KEYBOARD] KEY_UP = 273 264 0 KEY_DOWN = 274 258 0 KEY_LEFT = 276 260 0 KEY_RIGHT = 275 262 0 KEY_BUTTON1 = 32 306 0 KEY_BUTTON2 = 308 115 0 KEY_BUTTON3 = 304 113 0 KEY_START1 = 49 0 0 KEY_START2 = 50 0 0 KEY_COIN1 = 51 0 0 KEY_COIN2 = 52 0 0 KEY_SKILL1 = 304 119 0 KEY_SKILL2 = 122 105 0 KEY_SKILL3 = 120 107 0 KEY_SERVICE = 57 0 0 KEY_TEST = 283 0 0 KEY_RESET = 284 0 0 KEY_SCREENSHOT = 293 0 0 KEY_QUIT = 27 0 0 [/td] [/tr] [/table] Hope that helps anyone. There were a few other items I had to work through such as dropping opengl 2.0 support since my videocard didnt support it and assigning the right exit emulator keys. Once through that, daphne is solid now. -Nephilim Nephilim - Sasha Killz [sIGPIC][/sIGPIC]
djvj Posted October 27, 2012 Posted October 27, 2012 Glad you got it working, but just want to make it clear to anyone that reads this. This is not HyperLaunch related at all, nor are any configs you did above. This is strictly getting it to run how you need it to via CLI instead of through daphne launcher. Same goes for every other emulator, it is your job to set your keys in the emu to how you need them. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
nephilim Posted October 30, 2012 Author Posted October 30, 2012 Totally, thanks djvj. I wasn't sure where to put this as I only had the issue when launching a rom via hyperlaunch, controls came across fine when using daphneloader directly. Thanks a ton for your great modules. Nephilim - Sasha Killz [sIGPIC][/sIGPIC]
djvj Posted October 30, 2012 Posted October 30, 2012 Np man, and this is the correct section. From the title, it makes it sound like it's something related to HL, so I just wanted to clarify. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
dietjoke Posted November 14, 2014 Posted November 14, 2014 Hi nephilim Thanks for the tip!!! Question: Did you figure out how to not use the spacebar as your sword in dragon's lair1/2? I mapped it to another button and it's still looking for the spacebar. Weird.
rfancella Posted November 18, 2014 Posted November 18, 2014 Hi nephilimThanks for the tip!!! Question: Did you figure out how to not use the spacebar as your sword in dragon's lair1/2? I mapped it to another button and it's still looking for the spacebar. Weird. This is a pretty old thread. Are you using HL2 or RL? With RL and the new module for Daphne, you can customize the controls per game if you want. Here is a guide for RL and Daphne: http://www.hyperspin-fe.com/forum/showthread.php?29410-Complete-Guide-for-Daphne-in-HyperSpin-and-RL Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
