Hyperlaunch only able to launch one game?
vicviper99
Hey guys, bit of a noob here.
I am trying to get MAME to function smoothly within Hyperspin. I have everything up and running, and HyperLaunch is able to load roms, but I have to force quit HyperLaunch.exe in the task manager between each load.
If it has not been run previously, it will load a rom no problem, but once it has done so I have to force quit it before I can load the next game. I can hit start all day on the next game and nothing will happen, unless I first quit HyperLaunch.exe in task manager.
I'm sure there must be something stupid I am missing here. Any help is appreciated!
I had that issue
its to do with Hyperlaunch.exe not being killed when you exit a game
I did make a thread about it actually
I found using a external drive cause this issue but internal drive everything was fine
looks in task manager and monitor this situation
you will find that when you start your first game hyperlaunch .exe will start and then when you press escape to exit hyperlaunch.exe wont end. manually end it and try launch another game. if it works there is your problem
I jumped the gun posting my question, as I didn't realize there was a newer version of Hyperlaunch available. Once I obtained the new version, that took care of the problem.
