[Solved] BERZERK: BLACK SCREEN/BEEPING. Please help
SCUTTER BLASTER
Hello,
I am almost ready to shell my computer.. but I ran into a problem. I own several versions of Berzerk so I thought it would be awesome to add it to MamePlus 0.146. When I start Berzerk it requests me to move the joystick left and right, then it goes to a black screen with beeping. A bunch of white lines (squares) pop up.
I tried several roms but they all do the same thing. I tried clones (version 2 and german) and they also do the same thing. Can anyone please help me with this? The only thing I found online was someone deleted their hiscore.dat file...I tried that but nothing. Very much appreciated. I respond fast.
(It worked when I had the normal Mame 0.146. I switched to MamePlus 0.146 to save high scores)
How about deleting the bezerk cfg file in the cfg folder? I assume the Roms match the Mame version? As I would say try a newer version of Mame.
Why not Google
"Mameuifx nonag hiscore"
Try this as an alternative.
I would have posted a link but I'm on my mobile and can't test the download.
I'm using mameuifx version 0.159 I'm quite sure. It works fine for bezerk and has hiscore support (already built in).
Hmm.. So an interesting turn of events... I tried Mameuifx 0.159 and it does the same thing with Berzerk. I also tried my original Mame 0.146 and Berzerk is also doing the same thing on that. So all 3 versions of Mame, with multiple roms of Berzerk, are all doing the same thing. I wonder why.. (tried the clones too)
Anything I can provide that may help you guys?
Try delete the cfg file for bezerk as gigapig mentioned and also ensure you have deleted any nvram files for bezerk.
Failing that delete your mame.ini file.
Make a backup of course.
I can check my roms but it will take a couple days
Solved :) I deleted these files relating to Berzerk: cfg, nvram, hiscore, snap.
I didn't need to delete the .ini file but those above fixed it! :D Thanks so much for your help. I can now enjoy one of my favourite games on the arcade machine.
It's nice wake up and find things are fixed.
Just in case it happens again, a black screen  can be caused by the Mame artwork if you have it switch on. If there is no artwork for that game then you can get a black screen  but still here the sound.
