So I installed Vjoy and it fixes the control issues with Mortal Kombat X while using an ipac control panel (see this topic http://www.hyperspin-fe.com/topic/7908-mortal-kombat-x/page-2) which is great.
Problem is that while it fixes MKX, it also completely breaks Ultra Street Fighter IV. It causes USFIV to read the Vjoy inputs instead of the keyboard inputs, and this makes the joystick inputs super sensitive. Joystick inputs fly through menus so fast you can't actually select what you want except by luck. Simply exiting the game can take forever trying to land on the "yes I want to quit" selection. Selecting a character is a nightmare.
As long as Vjoy is on it won't let you switch it back to standard keyboard inputs. Simply turning Vjoy off doesn't fix it either. To get Vjoy to stop interfering you have to either go into the Device Manager and disable it (under human interface) or uninstall it completely. The entire point of having Hyperspin as a front end is so that everything works seamlessly from it so going out to disable Vjoy isn't a fix.
Is there a workaround? I was thinking an AHK that opens device manager and activates Vjoy when MKX is launched and turns it off again when you exit back to the Hyperspin menu? Or is there another program that can curb the craziness of Vjoy? If I install x360cu will it keep the joysticks from going nuts? Can xpadder help in any way? Anyone else experience this? Anyone have a fix, advice or ideas?
I just found an easy way to fix it!
Within Rocketlauncher/Hyperlaunch simply give USFIV its own VJoy profile under the keymapper tab. However leave this profile basically blank... keep the "enabled" button checked (or Enabled=True in the ini file), but keep all joystick/button inputs set to none. This way when you launch USFIV this blank/disabled profile seems to keep VJoy from interfering at all.
I just did several tests within Hyperspin and it all seems solid Launch MKX and it loads it's VJoy profile and MK works perfectly. Exit out then launch USFIV and it loads its blank VJoy profile and seems to work perfectly. So happy.
I can't be the only person that plays MK and SF so hopefully this helps some other out too.
