  • 0
How do I populate MAME.AHK module for a second MAME wheel in RocketLaunch?
griffin518
Question
Hi Everyone,
I know this isn't the RL forums, but I'm hoping maybe someone can help me out. I've run into an issue with a second MAME wheel I set up for some rom separation. Functionally everything works fine, but when it comes to HLSL, RocketLaunch seems to be relying on the module settings. The problem is, mame.ahk doesn't show up under modules for my second wheel (nothing does, actually). It's through the module that I'm specifying the ini directory where my settings file is located (for that nice curved look).
If anyone could point me in the right direction, or if you've got a similar setup and it's not an issue for you, I'd appreciate knowing.
Thanks.
3 answers to this question
Or is there a way to clone the MAME wheel in RL? I'd be open to recreating what I have in place.
Dude. Perfect answer.
Thank you so much!
FYI - looks like in RL 1.0 (maybe other versions as well) you can go with option A and still specific individual settings per wheel. That's exactly what I ended up doing.
All I'm saying is that at least in RL 1.0 (just released), when editing the global module settings for the mame.ahk module, there's a tab for the "MAME" wheel as well as for my secondary wheel "Arcade Classics." All of those changes are independent, even though they're now sharing the same module. This shows up when working within each wheel, in the modules menu. I haven't tried it from the global wheel settings. Could this be a new feature? Maybe, but I haven't had time to go back to HL 3.0 and test.
