Bulk Image Converter
ninja2bceen
index.php?app=downloads&module=display&section=screenshot&id=7845
File Name: Bulk Image Converter
File Submitter: ninja2bceen
File Submitted: 06 May 2015
File Category: Artwork tools
Credits: slade73
Ever had a TON of pics that are jpegs and you asked yourself if only there was a way to make all these png files so hyperspin would read them? Look no further with this batch process. Just select the directory of your media. Select from bmp, emf, exif,gif,jpeg, png, tiff,wmf files to convert to or from those same format. Happy picture conversions!
This is how i do it..
You can use the rename – or ren – DOS command in a Command Prompt window to rename multiple files at once. It accepts the wildcard character – * – to match multiple files. The quickest way to open a Command Prompt window at your desired location is to hold Shift, right-click in the folder, and select “Open command window here.”
So ..
ren *.html *.txt
easier =)
