System Wheel Art sometimes not showing
or8ital
I'm having a problem with the wheel art for two of my systems. On the main menu for Gamecube and Playstation the default text shows. If I select that system and then back out to the main menu the logo shows. How can I fix that?
Edit: After deleting the existing themes and waiting a couple hours (not sure why that was necessary??) Hypersynch finally recognized the files were missing and brought them back down. After that they worked fine again. Still not sure of the reason for the issue in the first place but glad it is working now. Thanks.
Info on HyperspinHelper Software: http://hyperspinhelper.wordpress.com. Allows you to enable two additional displays as a Marquee and a controls help screen as well as map UltraStik 360 controls. Works exclusively with Hyperspin.
In my travels, and through other posts I've read here, it was discovered that if a file's extension was uppercase (.PNG instead of .png), images would randomly disappear.
This and syntax error in the xml as far as I can remember.
  • 2 years later...
In case anyone else has this issue I fixed it by compiling a custom xml. I have know idea why because I see no syntax errors but doing to fixed the two random wheel images that would disappear from my main menu.
and there's a known bug with HS where it wants speakers plugged in btw
