Setting up two AimTrak Guns in Mame
brucelee00
Just realized it only applies the patch when I tick 64bit processor. Nothing else works. i have a quad core.
*EDIT* Realized I needed to tick 64bit processor AND Quad core in order for it to patch successfully. Hit Go again to compile. Still getting errors at the end of the compile
  • Replies 103
I bought two new Aimtrak guns. And I am having trouble with the inital setup. Im not sure what the configuration software means when it says each one has to have its own unique id. Like I understand each gun has to register separately but the process to do so is vague.
I plug one in, calibrate it. I plug the other one in and everything goes wonky. I click on the device 2 in the bottom left corner and im lost. Also, its not like the software runs me through how to connect. Just tells you each one needs a separate ID.
Like how do you actually assign the guns to ID one, ID two etc in the other tab.
Any help would be appreciated. Thanks
Plug 1 gun in. (both guns come stock as ID1). Fire up aimtrak utility. Go to change device id tab. Click on set id to 2. Close aimtrak utility. plug in gun 2. Open aimtrak utility. Drop down for gun ID is to select the gun to mess with Device 1 Should show Green firmware and version number. Hit drop down and select device 2. It should show Green firmware and version number in the bottom right. Good luck.
