NullDC and Hyperspin - Games Launch but Black Screen and sound only
delt31
I know it's hyperspin b/c emu plays perfectly outside.  When I boot the game in hyperspin a popup window opens asking me to pick my game which I do and then the emu plays but I get only a black screen w/sound of the emu running and I must alt tab to get out.
Seems like others have had this issue but due to the recent forums upgrade, none of the threads are accessible.  sweet.
I think this has something to do with the cfg file and the ahk I'm using.  anyone have any suggestions?
my nulldc config file is listed as defaultload of 0 meaning when I launch nulldc (even outside of hyperspin), the blue null dc program screen is there and a window pops up asking me to pick the game/image, putting my default or last image in the selection box but I need to confirm before it loads.
I can change the value to 1 in the cfg and that pop up won't happen so that's not really the issue.  It's when I load nulldc through hyperspin, I'm taken to a black screen where the audio will play but no video (or if default load is set to 0, black screen with the option to select the game and then when I do, audio no pic still black). Its like nulldc is plying in the background but b/c I opened it using hyperspin there is an overlap and I can't see the video.  If I play nulldc outside of hyperspin, the emu works np (even with nulldc .cfg set to 0 or 1).  no issue. I think something in my ahk needs to be updated.
The answer is def out there I just can't see the posts from the other threads anymore.  Anyway to see those?
found the solution - these settings worked for me in the ahk (for those that need this going forward since these boards are F'd considering old topics aren't visible).
;*********************************SEGA DREAMCAST********************************
else if (systemName = "Sega Dreamcast")
hideDesktop()
Hotkey, %exitEmulatorKey%, CloseProcess
if(executable = "nullDC_Win32_Release-NoTrace.exe" ||executable = "nulldc" )
SetWorkingDir, %emuPath%
rom = "%romPath%%romName%\%romName%%romExtension%"
SetBatchLines -1
IniWrite, 1, %A_WorkingDir%\nulldc.cfg, nullDC, Emulator.AutoStart
IniWrite, 1, %A_WorkingDir%\nulldc.cfg, nullDC, Emulator.NoConsole
IniWrite, 1, %A_WorkingDir%\nulldc.cfg, drkpvr, Fullscreen.Enabled
IniWrite, 800, %A_WorkingDir%\nulldc.cfg, drkpvr, Fullscreen.Res_X
IniWrite, 600, %A_WorkingDir%\nulldc.cfg, drkpvr, Fullscreen.Res_Y
IniWrite, %romPath%%romname%%RomExtension%, %A_WorkingDir%\nulldc.cfg, imagereader, defaultimage
Run, %executable%
Process, WaitClose, fusion.exe
  • 2 months later...
