Cannot find C:\Hyperspin\module Extensions\dxwnd\dxwnd.ini
fishman
So when i launch a game in hyperlaunch to check them i get this message Cannot find C:\Hyperspin\module Extensions\dxwnd\dxwnd.ini so what am i doing wrong? Please help!
Go into the dxwnd folder and you should find a file called dxwnd (example).ini
Make a copy of this file and rename it to dxwnd.ini
Also I want to double check but is your modules folder in your hyperspin folder?
It shouldn't be.
You may want to double check your directory structure.
It should be something like
C:\Hyperspin\hyperlaunch\module Extensions\dxwnd\dxwnd.ini
Or if you are using the newer version that has been renamed to rocketlauncher it should be
C:\Hyperspin\rocketlauncher\module Extensions\dxwnd\dxwnd.ini
