Nintendo 64 error when launching in Hyperspin
firebird2727
Why am I receiving this error (Cannot find Rom - D:\Roms\Nintendo 64\Batman Beyond - Return of the Joke (USA) with any provided extension).
In HyperHQ I have the following extensions 7z|zip|n64|z64|v64.
Emulator is Project64 1.7.0.50Ver23\Project64.
Module is Project64 (v2.x).ahk
Any suggestions
I also attached a error I get when launching a game from the Rocketlauncher. But after a few seconds after that error, the game actually launches.
In RocketLauncher, the extension for your roms is listed under global settings, emulators, and your chosen emulator on the list, right? I'm assuming you've got HyperHQ pointing towards your rom directory also.  Do you have wheel filters turned off/on in HyperHQ?  Sometimes those cause issues for me.  If you open your Nintendo 64 settings file in the Hyperspin, Settings folder, is everything correct?  The rom path, userompath set to true, search sub folders, etc... ?  Look through the settings file for any irregularities or issues.
In HyperHQ, I do have the roms directed to the location of where they are at.  I currently have no filters turned on in HyperHQ.
Here is my Settings inside Hyperspin:
[exe info]
path=C:\Hyperspin\Emulators\Project64.1.7.0.50.Ver.23\
rompath=D:\Roms\Nintendo 64\
userompath=true
exe=Project64.exe
romextension=7z|zip|n64|z64|v64
parameters=
searchsubfolders=true
pcgame=false
winstate=HIDDEN
hyperlaunch=true
Per_Game_Modules=false
Skipchecks=false
Hide_Cursor=use_global
Hide_Desktop=use_global
Hide_Taskbar=use_global
CPWizard_Enabled=use_global
CPWizard_Delay=use_global
CPWizard_Params=use_global
Fade_In=use_global
Fade_Out=use_global
Fade_Color=use_global
Fade_In_Duration=use_global
Fade_Out_Duration=use_global
Fade_In_Delay=use_global
7z_Enabled=use_global
7z_Extract_Dir=use_global
7z_Delete_Temp=use_global
Keymapper_Enabled=use_global
Keymapper=use_global
MultiGame_Enabled=use_global
MultiGame_Background_Color=use_global
MultiGame_Side_Padding=use_global
MultiGame_Y_Offset=use_global
MultiGame_Image_Adjust=use_global
MultiGame_Font=use_global
MultiGame_Text_1_Options=use_global
MultiGame_Text_1_Text=use_global
MultiGame_Text_2_Options=use_global
MultiGame_Text_2_Offset=use_global
MultiGame_Use_Sound=use_global
MultiGame_Sound_Frequency=use_global
MultiGame_Exit_Effect=use_global
MultiGame_Selected_Effect=use_global
MultiGame_Use_Game_Art=use_global
MultiGame_Art_Folder=use_global
[filters]
parents_only=false
themes_only=false
wheels_only=false
[themes]
use_parent_vids=false
use_parent_themes=false
animate_out_default=false
reload_backgrounds=false
[wheel]
alpha=.15
small_alpha = 1
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=C:\HyperSpin\Media\Nintendo 64\Video\
[sounds]
game_sounds=true
wheel_click=true
[navigation]
game_jump=50
use_indexes=false
jump_timer=400
remove_info_wheel=false
remove_info_text=false
use_last_game=false
last_game=007 - GoldenEye (USA)
random_game=false
start_on_favorites=false
[special Art A]
default=false
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[special Art C]
active=true
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active=true
show_year=true
show_manf=true
show_description=true
text_color1=0xffffff
text_color2=0x0099cc
text_font=Style1
text1_textsize=26
text1_strokesize=7
text1_x=32
text1_y=610
text2_textsize=36
text2_strokesize=8
text2_x=30
text2_y=640
Im not seeing anything that sticks out.
The only thing that I see that's different from my setup is that my exe= path is blank.  I'm using RetroArch though, and I'm fairly new to all this, so I may be way off with that being an issue.  You said you get the error you posted in your OP in RocketLauncher also, but then it still launches the rom?  What format are your roms in?  I noticed you don't have RAR on your list of extensions (if they aren't RAR'd though, then doesn't matter).
Now I am getting the samething with my MAME.
Is there another log file or something I can look at.
I am new at this, any information will be greatly appreciated. Or maybe share my screen to have someone take a look to get me on the right path.
Thanks in advanced.
 you should zip all your roms. this way you only have one extension.
Project64 can load your zip compressed roms, you will also save hard drive space.
a few minor points
you only need to add your emulator path in HyperHQ if you are using Hyerplaunch 2.
you only need to add rom paths and extensions in HyperHQ if you are using rom filtering.
You will see the 100 or so posts of people  not being able to select their sub wheel because
they ignore this fact.
very important points
Are you using Hyperspin 1.3?
if the answer is yes you need to run a transition tool.  Hypersin 1.3 is not smart enough to distinguish between
Rocketlauncher and Hyperlaunch.
jump to step 3 IF YOU HAVE Rocketlauncer installed.
http://www.rlauncher.com/wiki/index.php?title=Transition_From_HyperLaunch3
the transition tool will add emulator paths to HyperHQ. This paths are not to your emulators but it will set
Rocketlauncher.exe as your emulator for all your systems.
it will do many more things so don't think you can do this manually
You need to post your Rocketlauncher log not your system settings
you can find it in your Rocketlauncher folder.
load a game through Rocketlauncher
before you do that
Open RocketlauncherUI
select the main Game Settings tab
look for the Logger Section and select "TroubleShooting" from the drop down menu
and please post your logs at
Past Bin
http://pastebin.com/
none of us want to scroll thorough so many lines of code when we read posts.
  • 4 weeks later...
