AHK for black screen between emulator and Hyperspin
Jon.Damico
Hi Everyone,
I am working on Atari Jaguar using Virtual Jaguar. For whatever reason, every time I load a rom, the screen constantly flickers, to resolve the issue I would like to create a black screen, which will take over for the time of the flickering, similar to the extra screen setting in HLHQ for exiting. Has anyone written anything like this. I do not know much about AHK, but I pieced this together.
Gui, Color, black
Gui, Show, x0 y0 w%A_ScreenWidth% h%A_ScreenHeight%
WinActive ()
Sleep, 2000
It doesn't work so I am going to guess something isn't right.
I am also having a similar issue on Project64, but it shows the rom in 1/4 screen, then flashes and goes to full screen.
Thank you for your help!
Thank you GigaPig, but I do have Hide Emulator set to True. In fact everything is set to true except for the mouse. I have been tweeking the settings and discover that if I turn off Fade In, then it only flashes once. However, I have an image with the controller mapping appear during fade in that I want to continue to use. This way the user knows which buttons do what and with fade off, this image never appears.
Ideas?
I am going to keep tweeking the fade settings and see if I can minimize the flashing. I will post any findings here.
Thank you.
Well after fiddling with the settings for an hour, I have gotten it down to only a few flashes. I lowered the Fade In duration, and delay to 0, which cut the flashing by about 75% and then set exit delay to 10,000. Which I believe is overkill since the emulator takes over on fullscreen, but it seems to cut about another 10% off.
With these settings it is bearable now, where before it would flash for several seconds. As for Project 64, any ideas? I am going to tweek the fade settings and see if I can get something to work, but I have everything set to global, which means everything is true (except the mouse) and that fade is on with a 1000 duration.
Anyways, I will post my findings and if anyone knows or finds anything in the meantime I would be grateful.
Thanks again!
Well, that was easy. By increasing the delay and exit delay, the quarter screen doesn't appear anymore. I see a black screen, until the emulator is full screen. So, lesson learned. Fiddle with the settings until something works and every system seems to react alittle bit different. haha.
Thanks again.
  • 1 month later...
Where is this delay option? I am having similar issues with PC based games.. when i select the Rom to run hyperspin is still active for 2-3 seconds before focus switches to the 'app' so you can technically launch about 3 games at the same time. So adjusting the delay might prevent this?
