Changing parameters in HyperHQ
RoughDuck
Hello!
I am trying to feed the proper command line into hyperhq to get Hyperspin to work correctly with the "roms only" filter enabled.  Is there anyway to manualy adjust the order of parameters hyperhq receives for the command line? Particularly for the roms directory.
This is in conjunction with Rocket Launcher though.  The current command line is sending RocketLauncher.exe [some rom] [some system]  when rocketlauncher needs to take the arguments the other way around or give it a option -r or -s
upgrade to Hyperspin 1.4 and you don't need to update anything.
or use the transition tool found at the Rocketlauncher website to do it automatically.
