thcdgaf Posted June 10, 2015 Posted June 10, 2015 Dunno much about it my cue and bin match up and play window mode just not full screen is BTW its hook up HDMI video and sound it that helps any knowledge is welcome tired of banging my head on this problem
iNTiGOD Posted June 10, 2015 Posted June 10, 2015 Check out this page for a good rundown on getting retroarch setup. There is a video (at around 2min:50sec) that goes into further detail on how to access the retroarch menu and go to fullscreen. MAME High Score Tutorial For HyperSpin
thcdgaf Posted June 10, 2015 Author Posted June 10, 2015 I got it setup audio don't play in full screen
Awakened Posted June 10, 2015 Posted June 10, 2015 Does pressing F enter fullscreen properly? Make sure video_fullscreen = "true" is in your retroarch.cfg.
Awakened Posted June 11, 2015 Posted June 11, 2015 Hmm, well, I'm not sure about the audio issue. You could try enabling Windowed Fullscreen in the video options if it's disabled. It should act like a fullscreen window then and could fix your audio.
thcdgaf Posted June 12, 2015 Author Posted June 12, 2015 It's hdmi retroarch don't support it or I'm missing something Speakers work fine with regular sound input In full screen bump this for now maybe there be w solution thanks
iNTiGOD Posted June 12, 2015 Posted June 12, 2015 It's hdmi retroarch don't support it or I'm missing something Speakers work fine with regular sound input In full screen bump this for now maybe there be w solution thanks Hey whats your native tongue? MAME High Score Tutorial For HyperSpin
guyverjay Posted June 12, 2015 Posted June 12, 2015 Make sure you are launching the cue file and not the bin,check your extensions in the emulator set up
thcdgaf Posted June 12, 2015 Author Posted June 12, 2015 But pretty sure it's hdmi it don't like Sent from my LGL34C using Tapatalk
baddeolv Posted June 12, 2015 Posted June 12, 2015 But pretty sure it's hdmi it don't like Sent from my LGL34C using Tapatalk Mine works fine, I also use hdmi. Make sure the "cue" extension is listed before "bin" in your global emulator settings Sent from my iPhone using Tapatalk Instagram : baddeolv Facebook : Brian Addeo
thcdgaf Posted June 12, 2015 Author Posted June 12, 2015 Mine works fine, I also use hdmi. Make sure the "cue" extension is listed before "bin" in your global emulator settings Sent from my iPhone using Tapatalk Right before bin? Sent from my LGL34C using Tapatalk
thcdgaf Posted June 12, 2015 Author Posted June 12, 2015 Also genesis does same thing Sent from my LGL34C using Tapatalk
baddeolv Posted June 12, 2015 Posted June 12, 2015 Right before bin? Sent from my LGL34C using Tapatalk Nah, just have it listed before in the list. This will also help with tgcdSent from my iPhone using Tapatalk Instagram : baddeolv Facebook : Brian Addeo
thcdgaf Posted June 12, 2015 Author Posted June 12, 2015 tried that didnt work i feel its something simple
thcdgaf Posted June 12, 2015 Author Posted June 12, 2015 Hey whats your native tongue? I speak english and what do you mean?
Dunk3000 Posted June 14, 2015 Posted June 14, 2015 So I tested my retroarch Sega cd and sound is fine via hdmi. Have you checked your volume mixer on windows whilst retroarch runing? Just make sure we haven't missed something obvious like the volume just for retroarch is turned down. I remember my dolphin levels were turned off when I first installed and it took me a little while to work out why I got no sound from it Sent from my SM-G925F using Tapatalk
thcdgaf Posted June 14, 2015 Author Posted June 14, 2015 So I tested my retroarch Sega cd and sound is fine via hdmi. Have you checked your volume mixer on windows whilst retroarch runing? Just make sure we haven't missed something obvious like the volume just for retroarch is turned down. I remember my dolphin levels were turned off when I first installed and it took me a little while to work out why I got no sound from it Sent from my SM-G925F using Tapatalk It wasn't that plays if I put it in Windows mode by shift f but not in full screenSent from my LGL34C using Tapatalk
thcdgaf Posted June 15, 2015 Author Posted June 15, 2015 I thought i figure it out but hdmi works for windowmode but not fullscreen how do i get it to work in fullsceen through retroarch
thcdgaf Posted June 25, 2015 Author Posted June 25, 2015 i finally figured it out it wasnt rlauncher or hyperspin or retroarch it didnt like the driver it was using i put it on sd12 and it works sound in full screen admins get rid of this thread and other one i made thanks everyone for the insight though
iNTiGOD Posted June 25, 2015 Posted June 25, 2015 Good work... MAME High Score Tutorial For HyperSpin
