Bad Steam wheel
grendelrt
I have my Steam games setup and they launch in RL fine. But when I enter Hyperspin and click the Steam wheel nothing happens. When I go into HyperHQ and hit the Steam wheel, I cant change anything on any of the tabs other than how to launch games. My Steam XML in the databases directory looks like this format (built using SWC), maybe it is wrong?
<menu>
  <game SteamAppId="283680" name="Astebreed">
    <description>Astebreed</description>
    <manufacturer>Edelweiss</manufacturer>
    <year>2014</year>
    <genre>Action/Indie</genre>
  </game>
  <game SteamAppId="222940" name="THE KING OF FIGHTERS XIII STEAM EDITION">
    <description>THE KING OF FIGHTERS XIII STEAM EDITION</description>
    <manufacturer>SNK Playmore</manufacturer>
    <year>2013</year>
    <genre>Action</genre>
  </game>
</menu>
Have you guys got any wheel filters checked in HyperHQ? If not post your Steam.ini found in the HS settings folder and maybe your HS settings.ini.
All other tabs look like this, blank
Steam.ini
[exe info]
path=D:\Arcade\RocketLauncher\
exe=RocketLauncher.exe
parameters=
pcgame=true
winstate=NORMAL
hyperlaunch=false
[wheel]
text_color1=0x000NAN
text_color2=0x000NAN
text_color3=0x000NAN
text_stroke_color=0x000NAN
shadow_color=0x000NAN
Settings ini
[Main]
Menu_Mode=multi
Single_Mode_Name=XBMC
Enable_Exit_Menu=false
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Use_Last_Game=true
Use_Last_System=false
Last_System=MAME
Hyperlaunch_Path=D:\Arcade\RocketLauncher\
[Resolution]
FullScreen=true
Width=640
Height=480
Scanlines_Active=false
Scanlines_Image=
Scanlines_Scale=1
Scanlines_Alpha=0.1
[Optimizer]
CPU_Priority=normal
Quality=HIGH
Image_Smoothing=true
Animated_Backgrounds=true
Inter_Backgrounds=false
Level1_Backgrounds=true
Level2_Backgrounds=true
Level3_Backgrounds=true
Level4_Backgrounds=true
Special_Backgrounds=true
Wait_For_Special=false
Animated_Artworks=true
Level1_Artworks=true
Level2_Artworks=true
[introVideo]
Use_Intro=false
Stop_On_Keypress=true
[sound]
Master_Volume=50
Video_Volume=50
Wheel_Volume=20
Interface_Volume=20
[AttractMode]
Active=true
Time=30
MaxSpinTime=4
HyperSpin=false
Wait_For_Video=true
[Keyboard]
Key_Delay=true
[P1 Controls]
Start=49
Exit=16
Up=38
Down=40
SkipUp=37
SkipDown=39
SkipUpNumber=17
SkipDownNumber=90
HyperSpin=88
Genre=79
Favorites=32
[P2 Controls]
Start=69
Exit=81
Up=87
Down=83
SkipUp=65
SkipDown=68
SkipUpNumber=74
SkipDownNumber=77
HyperSpin=88
Genre=72
Favorites=90
[P1 Joystick]
Enabled=false
Joy=0
Threshold=40
Start=Button_8
Exit=Button_2
Up=POV_Up
Down=POV_Down
SkipUp=POV_Left
SkipDown=POV_Right
SkipUpNumber=Button_3
SkipDownNumber=Button_4
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_4
[P2 Joystick]
Enabled=false
Joy=1
Threshold=40
Start=Button_1
Exit=Button_2
Up=Analog_Up
Down=Analog_Down
SkipUp=Analog_Left
SkipDown=Analog_Right
HyperSpin=Button_5
Genre=Button_6
Favorites=Button_7
[Trackball]
Enabled=false
Sensitivity=90
[spinner]
Enabled=false
Sensitivity=90
[startup Program]
Executable=
Paramaters=
Working_Directory=
WinState=NORMAL
[Exit Program]
Executable=clear.bat
Paramaters=
Working_Directory=D:\Arcade\
WinState=NORMAL
[LEDBlinky]
Active=false
Path=D:\Arcade\LEDBlinky\
[HiScore]
Active=false
Y=550
Delay=2
Grendelrt, are you using HS 1.4? If so then you should be using HyperLaunch as the execution. But I have a feeling your using 1.3.
If you guys are using Rocketlauncher you should have used the Transition tool? If you have added a new system after running the tool then I assume you need to run it again to fix the new added system ini's.
Looking at the screen shot of HyperHQ I can't see any parameters in the param box, which suggests you haven't run the tool for Steam.
I don't think it should be set as a PC game either if using HS 1.3.
The best solution for grendelrt is to use the 1.4 beta but he may have reason not to.
Thanks for the reply. I am on 1.3 and I ran the transition tool after Steam had been there. I cant change the PC game check box, it wont let me. I just started using HS , so I didnt want to break something by moving to 1.4. Hoping to stick with 1.3 until 1.4 comes out of beta. Is there an example of what parameters I am missing? Would this prevent the wheel from even coming up when I try to enter it?
At the moment you have Steam set to Normal and PC Game so you will not get the sub wheel. All that may happen is RocketLauncher may start?
If you moved to 1.4 you could use Hyperspin normally with Gamepad/spinner/trackball support. There would be no need to mess with ini files you only need to set the full RocketLauncher path in the HS settings.ini file.
If you want to stick with 1.3 they you may need to look or post over at the RocketLauncher website.
Edit. I've been using 1.4 since the first beta release and it's fine apart from a few apps no working. If your new then that won't bother you anyway.
Fixed it, i started messing with Ini file after you mentioned I was missing Params. I added the params, rompath, etc. and disabled pc games via the ini (menu wouldnt allow it). Then it through an error on the wheel saying something about fades. I went into the MainMenu.ini inside databases and removed the exe flag that was tied to it. Now everything works, thanks for the replies =)
Hey are you running on hyperspin 1.4 or 1.3
