zillion23
    142
Everything posted by zillion23
  1. Wheel sound effects do not make a sound until attract mode starts at least one time and then the wheel sound effects are normal for the rest of the time HyperSpin is open.
  2. Click on your avatar picture in Hypertheme, then go into your profile and click on clients and delete all the clients you do not want.
  3. The dropdown menu to select a different core is blank when you click on it. You still have to manually type a differnt core if you do not want to use the one that is default by HyperHQ. I am using Retroarch in a custom folder and not the retroarch than comes downloaded by HyperHQ.
  4. Just tried to start from scratch again deleting all my HyperSpin and HyperHQ folders. I installed HyperHQ and HyperSpin onto my G drive. When I closed HyperHQ and opened it back up again there was a 2.0.45 update notice and when I updated, it installed all new HyperSpin/HyperHQ folders on my C drive in my Program Data folder. So right now it is unusable unless I install everything on my C drive which I am not willing to do.
  5. You all should report this over at the bug reporting section.
  6. I was on HyperHQ 2.0.43 and have it installed on another drive other than C and when it updated to 2.0.45 this morning it installed it in the Program Data folder and did not respect the drive I currently have HyperHQ installed on. I thought it was previously fixed but it is doing the same thing again. Also currently when you try to download the latest HyperHQ from the HyperSpin website it is showing 2.0.43
  7. I had that happen the other day as well. Even though my emumovies credentials were correct, HyperHQ would not accept them. Eventually it started working later in the day.
  8. I have something new to add to this. It seems the wheel sounds do not begin until attract mode kicks in at least one time. You can then here the wheel sounds on the platform and system views while in HyperSpin until you exit out of HyperSpin. Then the next time you open HyperSpin you will not here wheel scrolling sounds until Attract Mode initiates at least one time.
  9. Yes, the same issue occurs. The strange thing is when I add carts to the overrides folder, it also corrects all the overrides boxart showing up correctly as well. If it matters I was testing on the N64 platform.
  10. That seemed to fix the problem, thanks!
  11. I do not know if this is a theme creator issue or a bug with HyperSpin. The cart arts in some themes are either way too stretched or either squished. This is the art that is downloaded through HyperHQ. I have attached videos to explain the problem. It would be nice for the artwork in HyperSpin to be more dynamic depending on your resolution. Most of the artwork is way oversized or not uniform in the system themes. 2025-02-08 11-24-01.mp4 2025-02-08 11-22-51.mp4
  12. As far as the gray wheels, all you have to do is go into the HyperHQ settings and uncheck grayscale wheel under the wheel settings.
  13. Hypertheme website does not respect custom name in HyperHQ Hypertheme client settings. When I go to download a new theme at the hypertheme website and choose my client that i set up in HyperHq it does not download, I have to choose another name with a bunch of characters and numbers in order to download.
  14. The overides are really buggy. For instance I put some 3D boxes in the overrides boxart folder and it displays correctly in HyperHQ but not all of them will show up in HyperSpin. It will be a mix of the 3D ones I put in the overrides folder and the ones in the main HyperSpin media folder. Also the carts disappear if I put boxart in the overrides folder but not put carts also in the overrides folder.
  15. There is no videos being downloaded from the server for Nintendo 64 even though the rest of my media downloads and the videos exist on emumovies
  16. The main menu and sound effects are not working even though they are installed in the folder and HyperHQ says that it needs updating. I press the update button and go to another screen in HyperHQ and then go back and it says update again and never applies. I have had this problem before in past updates but it went away and now its back again. I will add that the wheel sounds will work occasionally but most of the time they do not.
  17. This has been fixed for me as well. I autually had to reinstall the HyperSpin Core plugin again to get all the box, cart and etc to show again. I do not believe it was a cache issue. The plugin I think kept getting corrupted because the HQ update dialog was getting blocked by HyperHQ downloads and I had to force close HyperHQ in the taskbar in order to download the newest HyperHQ update the next time I opened it.
  18. The problem has been resolved for me. When I updated to 2.0.39 the updater installed everything in the correct folder. It is still installing lots of files into my C Users folder and appdata folder but I guess that is by design for now until it gets more portable to where everything is stored along side HyperSpin and HyperHQ if they are installed on a drive other than C. Thanks!
  19. I am using a Xbox controller and wanted to report a few controls with the controller settings that are either not functioning or not working correctly in Hyperspin. Exit screen where it ask "Are you sure" = Keyboard works correctly to scroll up or down to choose (yes) or (no) but controller does not work Menu Button = Keyboard works to pull up Menu but when you push the controller button that you have assigned to the menu, the menu appears but only stays up for 1 to 2 seconds and then disappears Search, volume up, volume down and hyperspin buttons do not work. Not sure what hyperspin button is supposed to do though?
  20. When using a video theme mp4 file added to the HyperSpin\media\Systems\_overrides\MainMenu\MainMenuTheme folder when you enter into the game theme in HyperSpin and then back out back into the main menu it continues to play the game theme video overlayed over the video theme in the main menu. Attached is a video showing an example. 2025-01-18 14-31-39.mp4
  21. Same issue for me as well. I got a bug report about it here.
  22. Wanted to add that the only way I can see box art, carts and etc at the moment in game themes is to put them in the _overrides folder in .png format
  23. I just noticed that the overrides folder only supports png files and not jpg as well unless that is by design
  24. I just noticed that the only way I can get media such as boxes and carts to show in the game themes (at the moment) is to put them in the overrides folder. Also the _overrides folder only supports .png files not .jpg
  25. Same thing has been happening to me as well with my boxes and carts not showing in the themes along with the wheel sounds. The last time they worked was on version 2.0.33 I believe. I created a ticket for it here.
