needles Posted May 20, 2015 Posted May 20, 2015 Let me know if this should be raised as a new thread elsewhere... I started a year ago using HS 1.3.2.0 and RocketLauncher and used the RL migration tool (1.1) to update to RL & RLUI... I followed the instructions to also update to HS 1.4, but it didn't work so went back to HS 1.3.2.0 (keeping RL & RLUI). I've tried updating to HS 1.4 Beta 015 a few times and each time I'm getting an error (black screen with dialog box) when trying to launch games: No Default_Emulator found in "C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Emulators.ini" Please set one so RocketLauncher knows what module to use. I'm using Nintendo Entertainment System game Super Mario Bros. (World) in this case, however I get the same error (with varying path/filename to match) when testing other systems (N64, GBA, etc). All systems/games I have setup launch correctly from RLUI and all systems/games launch correctly when using the 1.3.2.0 HS exe. I've followed what I understand is the process to update to HS 1.4 (beta 015) by replacing the HyperSpin.exe with the new version and also extracting the new Scripts folder as below: C:\HyperSpin\Scripts\HScript\AutoHotkey.dll C:\HyperSpin\Scripts\HScript\HScript.ahk I found AutoHotkey.dll also exists in folder C:\HyperSpin\RocketLauncher and tried deleting this and running HS again (in case this was an old version?) which didn't work. My HyperHQ settings (Wheel Settings, eg. Nintendo Entertainment System, Emulator tab): Execution: Normal PC Game: Disabled Executable: C:\HyperSpin\RocketLauncher\RocketLauncher.exe Rom Path: <blank> Params: "Nintendo Entertainment System" -f "C:\HyperSpin\HyperSpin.exe" -p "HyperSpin" Extensions: <blank> Use Full Path To Roms: Enabled Search Subfolders: Disabled Command Line Preview: "C:\HyperSpin\RocketLauncher\RocketLauncher.exe" "RomName." "Nintendo Entertainment System" -f "C:\HyperSpin\HyperSpin.exe" -p "HyperSpin" The error leads me to believe I'm missing something simple (still very new to HS)... I'm new to looking at .ini files, so if there are some .ini files I need to check please advise the path and what to look for. Sorry for the long post... people ask for detailed posts to troubleshoot
needles Posted May 20, 2015 Author Posted May 20, 2015 Also just noticed... "C:\HyperSpin\RocketLauncher\RocketLauncherUI\Databases" is empty (except a blank "dir" text file and an empty XML file)... where as C:\HyperSpin\Databases has folders for all the default systems and each folder has the default XML file.
gigapig Posted May 20, 2015 Posted May 20, 2015 Your second post is fine, that is how it should be as long the databases in the HyperSpin folder are named after the system i.e Sega Genesis. However what is concern is the error which is asking for a default emulator "Super Mario Bros (World)" thats a Rom not an emulator. So something is very wrong. You probably need to post your RocketLauncher log set to troubleshooting. Maybe you database has exe tags??
needles Posted May 20, 2015 Author Posted May 20, 2015 [code] 22:26:24:806 | RL | INFO | +N/A | Main - RocketLauncher v1.0.0.0 (www.rlauncher.com) 22:26:24:875 | RL | INFO | +62 | Main - System Specs: RocketLauncher Dir: C:\HyperSpin\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 8.1 SKU: Windows 8 Total Memory: 16325.73 MB Free Memory: 14214.04 MB Used Memory: 2111.695 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce GTX 780 GPU 1 RAM: -1024.00 MB GPU 1 Driver Version: 9.18.13.5012 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: NVIDIA High Definition Audio Sound 2 Status: Enabled Sound 3 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 3 Status: Enabled OS Language: English_United_Kingdom OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 22:26:24:875 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\RocketLauncher.exe exists 22:26:24:890 | RL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.0.0.0 LegalCopyright �2015 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2083328 bytes Created: 5/3/2015 - 10:35:42 PM Modified: 5/9/2015 - 8:02:09 PM 22:26:24:890 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\BinHexRW.ahk exists 22:26:24:890 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:24:890 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4961 bytes Created: 5/9/2015 - 8:19:17 PM Modified: 5/9/2015 - 8:19:18 PM 22:26:24:890 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\BlockInput.exe exists 22:26:24:890 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 5/9/2015 - 8:09:12 PM Modified: 5/9/2015 - 8:09:14 PM 22:26:24:906 | RL | INFO | +15 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\CLR.ahk exists 22:26:24:906 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:24:906 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 4/28/2015 - 9:11:02 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:24:906 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\COM.ahk exists 22:26:24:906 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:24:906 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 4/28/2015 - 9:11:02 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:24:906 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Control_AniGif.ahk exists 22:26:24:921 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:24:921 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 4/28/2015 - 9:11:02 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:24:921 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\gdip.ahk exists 22:26:24:921 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:24:921 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 4/28/2015 - 9:11:02 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:24:937 | RL | INFO | +16 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\gdip_alt.ahk exists 22:26:24:941 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:24:944 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3394 bytes Created: 5/9/2015 - 8:11:27 PM Modified: 5/9/2015 - 8:11:28 PM 22:26:24:946 | RL | DEBUG1 | +15 | gdip_alt.ahk Version: 1.0.1 22:26:24:947 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\gsdll32.dll exists 22:26:24:949 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 13090816 bytes Created: 4/28/2015 - 9:11:02 PM Modified: 5/9/2015 - 8:18:27 PM 22:26:24:951 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\itextsharp.dll exists 22:26:24:954 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 4/28/2015 - 9:11:03 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:24:955 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Java.ahk exists 22:26:24:958 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:24:958 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 7841 bytes Created: 5/9/2015 - 8:04:06 PM Modified: 5/9/2015 - 8:04:07 PM 22:26:24:958 | RL | DEBUG1 | +0 | Java.ahk Version: 1.0.0 22:26:24:958 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\JSON.ahk exists 22:26:24:958 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:24:958 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 4/28/2015 - 9:11:03 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:24:974 | RL | INFO | +16 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Origin.ahk exists 22:26:24:974 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:24:974 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4904 bytes Created: 5/9/2015 - 8:08:13 PM Modified: 5/9/2015 - 8:08:14 PM 22:26:24:974 | RL | DEBUG1 | +0 | Origin.ahk Version: 1.0.2 22:26:24:974 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\RegRW64.ahk exists 22:26:24:974 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:24:990 | RL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 6915 bytes Created: 5/9/2015 - 8:12:05 PM Modified: 5/9/2015 - 8:12:06 PM 22:26:24:990 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\RIni.ahk exists 22:26:24:990 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:24:990 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 4/28/2015 - 9:11:03 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:24:990 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 22:26:24:005 | RL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 4/28/2015 - 9:11:03 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:25:005 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\Steam.ahk exists 22:26:25:005 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:005 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5347 bytes Created: 5/9/2015 - 8:08:23 PM Modified: 5/9/2015 - 8:08:24 PM 22:26:25:005 | RL | DEBUG1 | +0 | Steam.ahk Version: 1.0.2 22:26:25:005 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\VA.ahk exists 22:26:25:021 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:26:25:021 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 4/28/2015 - 9:11:03 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:25:021 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Module Extensions\VA_Extension.ahk exists 22:26:25:021 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:021 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3833 bytes Created: 5/9/2015 - 8:19:11 PM Modified: 5/9/2015 - 8:19:11 PM 22:26:25:039 | RL | DEBUG1 | +15 | VA_Extension.ahk Version: 1.0.1 22:26:25:042 | RL | INFO | +16 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Bezel.ahk exists 22:26:25:049 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:052 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 101747 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:12:13 PM 22:26:25:055 | RL | DEBUG1 | +0 | Bezel.ahk Version: 1.1.0 22:26:25:057 | RL | INFO | +16 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Fade.ahk exists 22:26:25:058 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:058 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36786 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/18/2015 - 9:31:34 PM 22:26:25:058 | RL | DEBUG1 | +0 | Fade.ahk Version: 1.0.10 22:26:25:058 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Fade Init.ahk exists 22:26:25:073 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:073 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 999 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:12:35 PM 22:26:25:073 | RL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.1 22:26:25:073 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Fade Animations.ahk exists 22:26:25:073 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:089 | RL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 79822 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/18/2015 - 9:31:38 PM 22:26:25:089 | RL | DEBUG1 | +0 | Fade Animations.ahk Version: 1.1.6 22:26:25:089 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Pause.ahk exists 22:26:25:105 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:105 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 379074 bytes Created: 5/9/2015 - 8:18:42 PM Modified: 5/9/2015 - 8:18:44 PM 22:26:25:105 | RL | DEBUG1 | +0 | Pause.ahk Version: 1.0.9 22:26:25:105 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Pause Init.ahk exists 22:26:25:105 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:105 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 590 bytes Created: 5/9/2015 - 8:13:12 PM Modified: 5/9/2015 - 8:13:12 PM 22:26:25:120 | RL | DEBUG1 | +15 | Pause Init.ahk Version: 1.0.2 22:26:25:120 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Keymapper.ahk exists 22:26:25:120 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:120 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33075 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:09:58 PM 22:26:25:120 | RL | DEBUG1 | +0 | Keymapper.ahk Version: 1.1.1 22:26:25:120 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Keymapper Init.ahk exists 22:26:25:137 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:140 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3455 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:12:28 PM 22:26:25:143 | RL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.3 22:26:25:145 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\MultiGame.ahk exists 22:26:25:150 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:152 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 40639 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:04:25 PM 22:26:25:154 | RL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.6 22:26:25:156 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\MultiGame Init.ahk exists 22:26:25:158 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:158 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:25:158 | RL | DEBUG1 | +0 | MultiGame Init.ahk Version: 1.0.0 22:26:25:158 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\MultiPlayer.ahk exists 22:26:25:158 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:174 | RL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 58641 bytes Created: 5/9/2015 - 8:11:57 PM Modified: 5/9/2015 - 8:11:59 PM 22:26:25:174 | RL | DEBUG1 | +0 | MultiPlayer.ahk Version: 1.0.5 22:26:25:174 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Password.ahk exists 22:26:25:174 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:174 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10040 bytes Created: 5/9/2015 - 8:09:17 PM Modified: 5/9/2015 - 8:09:19 PM 22:26:25:174 | RL | DEBUG1 | +0 | Password.ahk Version: 1.0.1 22:26:25:174 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists 22:26:25:189 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:189 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 73587 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:05:57 PM 22:26:25:189 | RL | DEBUG1 | +0 | Rom Mapping Launch Menu.ahk Version: 1.0.4 22:26:25:189 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Shared.ahk exists 22:26:25:205 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:205 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 148574 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:19:50 PM 22:26:25:205 | RL | DEBUG1 | +0 | Shared.ahk Version: 1.2.5 22:26:25:205 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Statistics.ahk exists 22:26:25:221 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:221 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26143 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:08:55 PM 22:26:25:221 | RL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.3 22:26:25:221 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\Statistics Init.ahk exists 22:26:25:221 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:221 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:08:37 PM 22:26:25:221 | RL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1 22:26:25:236 | RL | INFO | +16 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\XHotkey.ahk exists 22:26:25:242 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:244 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29626 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 5/9/2015 - 8:07:59 PM 22:26:25:246 | RL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.3 22:26:25:249 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Lib\XHotkey Init.ahk exists 22:26:25:252 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:26:25:255 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1236 bytes Created: 4/28/2015 - 9:10:35 PM Modified: 1/27/2014 - 3:36:00 PM 22:26:25:257 | RL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.0 22:26:25:259 | RL | DEBUG1 | +16 | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: C:\HyperSpin\HyperSpin.exe 22:26:25:261 | RL | DEBUG1 | +0 | Main - Raw CLI received: "Super Mario Bros. (World). Nintendo Entertainment System -f C:\HyperSpin\HyperSpin.exe -p HyperSpin" 22:26:25:263 | RL | DEBUG1 | +0 | Main - Received this dbName with no path via CLI: "Nintendo Entertainment System" 22:26:25:265 | RL | DEBUG1 | +0 | Main - dbName: Nintendo Entertainment System 22:26:25:269 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080 22:26:25:271 | RL | INFO | +0 | CheckFile - Checking if C:\HyperSpin\RocketLauncher\Plugins\HyperSpin.plugin exists 22:26:25:273 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 8969 bytes Created: 5/9/2015 - 8:04:49 PM Modified: 5/9/2015 - 8:04:50 PM 22:26:25:274 | RL | INFO | +15 | Main - Loading Front End Plugin: "HyperSpin" 22:26:25:274 | RL | INFO | +0 | Main - RocketLauncher received "Super Mario Bros. (World)." and "Nintendo Entertainment System" 22:26:25:274 | RL | DEBUG2 | +0 | CreateNewIni - C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Games.ini file not found, creating a new one. 22:26:25:274 | RL | DEBUG2 | +0 | CreateNewIni - C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Emulators.ini file not found, creating a new one. 22:26:25:274 | RL | DEBUG2 | +0 | CreateNewIni - C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\RocketLauncher.ini file not found, creating a new one. 22:26:25:274 | RL | INFO | +0 | Main - Did not find a "C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Game Options.ini" file, skipping any game-specific options. 22:26:25:274 | RL | WARNING | +0 | RIniReadCheck - Created missing RocketLauncher ini key: "Default_Emulator" in section: "Roms" in "C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Emulators.ini" 22:26:25:603 | RL | DEBUG1 | +329 | ScriptError - Playing error sound: error3.mp3 22:26:26:993 | RL | ERROR | +1390 | No Default_Emulator found in "C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Emulators.ini" Please set one so RocketLauncher knows what module to use. 22:26:26:993 | RL | INFO | +0 | ExitScript - Started 22:26:26:993 | RL | DEBUG1 | +0 | ExitScript - Restoring HyperSpin.exe to x0 y0 w1920 h1080 22:26:27:421 | RL | ERROR | +422 | No Default_Emulator found in "C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Emulators.ini" Please set one so RocketLauncher knows what module to use. 22:26:27:421 | RL | INFO | +0 | ExitScript - Started 22:26:27:421 | RL | DEBUG1 | +0 | ExitScript - Restoring HyperSpin.exe to x0 y0 w1920 h1080 22:26:27:543 | RL | DEBUG1 | +125 | ExitScript - Checking what application is currently in focus. 22:26:27:553 | RL | DEBUG1 | +0 | ExitScript - ErrorLayer is currently active. Putting focus back on HyperSpin.exe 22:26:27:693 | RL | DEBUG1 | +141 | ExitScript - Took 1 attempts to put HyperSpin.exe back in focus. 22:26:27:708 | RL | INFO | +15 | SystemCursor - Restoring mouse cursor 22:26:27:708 | RL | INFO | +0 | ExitScript - Ended [/code] Hope this is what you are after... I set the log to troubleshooting, ran Hyperspin.exe and tried to launch the same system/game. The fact that the error looks like a "path" error (not sure how to put that) makes me think there is a setting somewhere in HyperHQ or an .ini file that is different for 1.3.2.0 and 1.4 (but I'm new to HS, so I have no idea). :/
zerojay Posted May 20, 2015 Posted May 20, 2015 RIniReadCheck - Created missing RocketLauncher ini key: "Default_Emulator" in section: "Roms" in "C:\HyperSpin\RocketLauncher\Settings\Super Mario Bros. (World).\Emulators.ini" <--- You have Super Mario Bros as a system? Raw CLI received: "Super Mario Bros. (World). Nintendo Entertainment System -f C:\HyperSpin\HyperSpin.exe -p HyperSpin" <--- I don't know how you managed to pull this off. "I followed the instructions to also update to HS 1.4, but it didn't work" ....?
needles Posted May 20, 2015 Author Posted May 20, 2015 In short... when using HS 1.3.2.0 I can launch any game from within either RLUI or Hyperspin (have MAME, NES, SNES, N64, GBA, GB all setup with official XMLs). I started with a clean install of 1.3.2.0 a year ago with H L 3... recently came back and found RL had been released. Ran the transition tool to transition H L 3 to RL 1.0.0.0 (and RLUI)... may have selected HS 1.4 in this transition I then downloaded HS 1.4 015 beta, extracted over the existing Hyperspin.exe (which also added the Scripts folder)........ and from there HS 1.4 gives me the error. I can still launch any system/game I have setup from RLUI. I can only think something went wrong in the Transition Tool if I did select 1.4 (when I didn't have that installed yet).... only I know don't know where to look. All my HyperHQ settings seems to match what I'm told works with RL (and RLUI). EDIT: The Forum keeps auto editing H L 3 (without spaces) and making it RL .... this is bad for explaining troubleshooting.
gigapig Posted May 20, 2015 Posted May 20, 2015 Looks like a bit of a mess. I would be tempted to go back to 1.4 and follow the transition instructions very carefully. However I don't know if the transition tool will revert your HS system ini's which will be necessary. Not a big deal as you can do it manually but if you have lots of systems set up it may be painful. You should have addressed why 1.4 did mot work initially.
needles Posted May 20, 2015 Author Posted May 20, 2015 Thanks for the advice... it's late here so I'm going to come back to this tomorrow. I might try running the transition tool again (to 1.4) and see what happens... I've been creating full backups of my C:\Hyperspin directory each time I make some changes, so I can always go back to an old version (or check out the files). I might even just do a clean install as I don't have too much setup (can restore favourites, etc)... most of my time so far has been learning. I could probably do a clean install back to my current setup within a couple of hours. Cheers
gigapig Posted May 20, 2015 Posted May 20, 2015 I don't know if many will read this. People who have HyperSpin all set up and working should really consider whether they should update at all. I'm not sure if "update" is the correct word with regard to working set ups. We seem to be getting to a stage where only a fresh install will do for some.
premierswan Posted May 20, 2015 Posted May 20, 2015 Needoes I have exactly the same problem. All systems work in rlauncherui but not in hyperspin. Seems to be searching for game instead of emulator. Hopefully there's a solution or I to, will be looking at a clean install.
needles Posted May 23, 2015 Author Posted May 23, 2015 I'm up and running on a clean install...... didn't take too long as I was able to copy my Media, Favourites, Emulators, etc (and only had 6 systems setup). I'm sure I spent more time trying to fix my original install Thanks to gigapig for helping me try to restore my first setup. Also thanks to ghutch92 for the below setup guide... by far the most straight forward guide for a clean install I have found (and up to date... unlike most I found). http://www.hyperspin-fe.com/topic/2187-how-to-install-hyperspin/ As to what happened with the original setup (and the error)... I can only guess I made a mistake somewhere in my original 1.3.2.0 install and RL transition (followed by HS 1.4 Beta upgrade).
