HS Bezel 0.0.1.2 BETA
Lets you create a bezel for Hyperspin when using it in Non 4:3 Resolutions.
Now with dynamic bezels and you can use 4:3 and 16:9 themes together ;)
New in 0.0.1.2 BETA
Not require one specific bezel anymore for each resolution (you can still use them to exactly fit your screen), it will resize one bezel to any screen resolution.
The Bezels now can be named as you wish but they have to start by "HSBezel" and end with the ".png" extension and be inside the right folders.
The folder structure of the Bezels as changed to support this new feature. Donwload the
new Bezels pack, it includes the new correct folder structure:
New Bezels Pack 0.0.1.2 BETA
New Folder Structure for BETA 0.0.1.2 BETA
Including a few New Bezels (Including klopjero's MS-DOS Thanks :) )
Most of the original bezels come from this Autors: Nosh, alexdc22, Knewlife(Me), some other???
How to use
Quote
Warning: Your "C:\Hyperspin\Scripts\HScript\HScript.ahk" will be replaced, backup that first
1- Copy the 7z file contents to your HyperSpin folder ("C:\HyperSpin\") and replace existing files.
2- Set in HyperHQ hyperspin to use WIndow mode in 1024x768 resolution.
3- Set your monitor resolution to something like 1360x768, you can set something like FULL HD resolutions but hyperspin is not designed to run like that.
4- Create a HSBezel.png file with the left and right bars... the center should be transparent. (put the bezel directly inside the _Default/System/Game folder to use it as multy-resolution bezel or inside a folder with your resolution values as name to use as Resolution Specific Bezel).
You can use the ones included here as model.
5- Launch HSBEZEL.exe (should be in Hyperspin folder)... this will launch hyperspin and keep runing in the background.
Every time HS Window is active AND the position of the window or the bezel has changed they will be centered again.
This normally happens when enter an application that changes monitor resolution. This problem dont exist when runing HS in full screen,
but remember we are in Window mode here.
6- NOW YOU CAN EDIT THE INI FILE INCLUDED TO RUN APPS, THE APP ALSO HIDE THE MOUSE CURSOR (can be disabled by ini setting: 1 enabled, 0 disabled)
CTRL+ALT+H Shows/Hide cursor.
Quote
Dynamic Bezels (Depend on themes)
WIth HyperSpin 1.4 update, autohotckey code can be executed on theme change, so we now can change the bezels dinamically.
In the 0.0.1 BETA download a hsscript.ahk file is included, you can replace your old "C:\Hyperspin\Scripts\HScript\HScript.ahk" file with it or modify it if you already have code there.
Bezels for each system / game will be stored like this:
You can use 16:9 themes by creating a file with the extension "169" in the same folder and using the same name:
A 16:9 theme called "Nintendo Game Boy.zip" needs "Nintendo Game Boy.169" in the same folder.
The 0.0.1.2 BETA download includes default bezels and a example system bezel ("DICE").
New in 0.0.1.2 BETA
Not require one specific bezel anymore for each resolution (you can still use them BTW), it will resize one bezel to any screen resolution. The folder structure of the Bezels as changed to support this new feature.
What's New in Version 0.0.1.2 BETA
  • BETA 0.0.1.2: New HSBezel folder structure and Bezels are Resolution-Adaptable now.
  • BETA 0.0.1.1: Icon and some small fix.
  • BETA 0.0.1: Dynamic Bezels.
  • PRE BETA: RandomBezel option.
  • Upvote 1
