shitoken Posted June 20, 2015 Posted June 20, 2015 I have updated from Mame 0.159 to Mameuifx 0.162 If I set to use with opengl I am getting black screen but if change to D3D or auto is working fine. I have checked my card support opengl and is turned on. In HLHQ global settingsI can see the HLSL only with set to true but I do not see any GLSL as per GIGA video he is using rocket launcher. What is the difference if I use HLSL and not GLSL? Video Mode I have set to opengl. Please guide me thanks
volumetric Posted June 21, 2015 Posted June 21, 2015 HLSL is pretty much the same thing as GLSL only HLSL works under DX and GLSL works under opengl. My guess is that your black screen is caused by having HLSL enabled while running opengl. If you are not seeing an option to enable GLSL, it may be a case of an outdated module. Try updating rocketlauncher (or updating to rocketlauncher, if you're not currently using it).
potts43 Posted June 21, 2015 Posted June 21, 2015 On 6/20/2015 at 9:54 AM, shitoken said: I have updated from Mame 0.159 to Mameuifx 0.162 If I set to use with opengl I am getting black screen but if change to D3D or auto is working fine. I have checked my card support opengl and is turned on. In HLHQ global settings I can see the HLSL only with set to true but I do not see any GLSL as per GIGA video he is using rocket launcher. What is the difference if I use HLSL and not GLSL? Video Mode I have set to opengl. Please guide me thanks Black screen can be fixed by selecting hide emulator on RLUI
shitoken Posted June 21, 2015 Author Posted June 21, 2015 Is Rocket Launcher better than Hyper launcher?Do we have easy guide how to switch to update rocket launcher without effecting my setups?
shitoken Posted June 21, 2015 Author Posted June 21, 2015 What I did now is set MameUIX video to opengl&in HLHQ under Mame Module global setting tapunder Setting tap I have changed to HLSL to falseunder Mame tap I have changed HLSL to trueit works now with shader but how can I set both Horizontal and Vertical Shaders? Do we have more options for shaders of just 4 which is included in Mameuix?
shitoken Posted June 24, 2015 Author Posted June 24, 2015 Finally I have converted HLHQ to RL last night and still Mameuifx goes to black screen after the bezel and first screen of numbers loaded if set video to Opengl what should I do now dears.
shitoken Posted October 1, 2015 Author Posted October 1, 2015 Why the Bezel takes more up space on the screen then the game screen? How can I change the game screen to bigger with smaller bezel
