HyperElectronicGames (Launcher for Electronic Games)
r0man0
Great work r0man0!!!    Quick question, are some of the games you have on the database missing?  an example is Chef.  I see on the db, artwork, but no folder for it?  Thanks in advance!
Hi , one of emulator folder is called "Handheld Quake" , it's a multi-emulator and some of simulators from database like "chef" come from this folder.
Be carefull with all path and filename if you made any change i'm not sure that my launcher still works.
r0man0
  • Replies 166
Hello again,
I wanted to report that majority of games are launching for me now, just the odd one doesn't seem to want to load and everything loads at 800x600 now.  I still can't seem to get it to recognize xarcade key presses, most of the handheld games use ctrl keys and arrow keys to move, neither of which are recognized when pressed on the controller.  I enabled xarcade controls in the settings.  Honestly though these games are more for the sake of having them, they aren't likely to get much play so I'm just happy they work at all.
One thing I would really like to see however is a demo video for the system wheel, there was a guy who posted on page 1 of this topic that had his own set up going and it looks nice, maybe you could get the system theme from him?  It's the only system on my wheel without a video and I'm not sure where to find one....
Regards
Dark
Hello again,
Regards
Dark
Ok Dark , it's a bit difficult for me to test X-Arcade option because i don't have this kind of controller at home. So i just want to know if you have set up hyperelectronicgames.ini correctly , can you post me this file ?
I understand that you are enjoy to get thoses games on your hyperspin hard drive , but for the rest of people that want to also play them , i will try to resolve this problem.
For the guy who post his own set up on first page : use this link to get the medias you want :
http://www.hyperspin-fe.com/topic/10427-electronic-games-for-hyperspin-game-watch-package/
Some of artworks from his pack come from mine. But i prefer keep my pack as he was originally. Just make your own mix of medias.
Thanks for report ,
r0man0
[General]
JoyNumber=1
Joy2Key=1
Azerty=1
800X600Only=1
ExitKey=enter
[XArcadeTankstick]
EnableXarcade=1
UpXarcade=UP
DownXarcade=DOWN
LeftXarcade=LEFT
RightXarcade=RIGHT
Button1Xarcade=1
Button2Xarcade=2
Button3Xarcade=3
Button4Xarcade=4
ButtonSelectXarcade=7
ButtonStartXarcade=8
Well I'm happy to report to you that key presses from x-arcade joystick now register.  The only bit of trouble is many of these games have strange controls, like Oil Panic for example uses 'Q' for left and 'P' for right and I don't see any way to change that.  There are still some games that won't launch through hyperspin for me.
use xpadder then you can use keyboard keys to control your gamepad or whatever you have in your palm its free via torrent or for a lil donation of 10$ you can keep up to date
sig.png 100%
Ok dark , for oil panic , do you mean that x-arcade emulation doesn't works ? i've tested with keyboard sucessfully but maybe it's different with x-arcade tankstick.
could you tell me witch ones doesn't launch from hyperspin ?
If emulation is ok for you i will update full package with the new launcher you've tested.
r0man0
  • 3 weeks later...
Hi roman , thank you for the games,
I cant get the HS to run the emulator at all , I am using Win8
Below is my ini config
[exe info]
path=H:\HyperSpin\Emulators\HyperElectronic\Emulators\Electronic Games\
rompath=
userompath=
exe=HyperElectronicGames.exe
romextension=
parameters=
searchsubfolders=
pcgame=false
winstate=NORMAL
hyperlaunch=false
[filters]
parents_only=false
themes_only=false
wheels_only=false
roms_only=false
[themes]
use_parent_vids=true
use_parent_themes=false
animate_out_default=false
reload_backgrounds=false
[wheel]
alpha=.15
small_alpha=1
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=
[sounds]
game_sounds=true
wheel_click=true
[navigation]
game_jump=50
use_indexes=false
jump_timer=400
remove_info_wheel=false
remove_info_text=false
use_last_game=false
last_game=BallToss-Up
random_game=false
start_on_favorites=false
[special Art A]
default=false
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[special Art C]
active=true
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active=true
show_year=true
show_manf=true
show_description=true
text_color1=0xffffff
text_color2=0x0099cc
text_font=Style1
text1_textsize=26
text1_strokesize=7
text1_x=32
text1_y=610
text2_textsize=36
text2_strokesize=8
text2_x=30
text2_y=640
i shitoken , your ini is ok , my launcher works on win7 sucessfully but I've not try with win8 :
First check if electronics emulators works directly from their executable.
Secondly you can use win 8 compatibility mode :
http://www.eightforums.com/tutorials/6832-compatibility-mode-use-windows-8-a.html
R0man0
Thanks Roman
I will try above mention first and let you know the result.
Hi Roman
Games is working if I just run the emulator.
I did troubleshoot the launcher to compatibility with win8 but not working not matter what I do.
For some autohotkey scripts Administrator mode is required.
You can try to set the executable to be run as administrator.
On win 7 you have to right click on executable (hyperelectronicgames.exe) then
"properties"-->"compatibility"-->check "Run as administrator".
Maybe this configuration is the same on win 8.
r0man0
Thanks.
Set this up last night but the games are so tiny. Had to use my binoculars just to be able to see what was happening in that tiny screen. Is there anyway to change that? The resolution is already set to 800x600. Not sure if lowering it even more is a solution.
Yes , most of emulators use 800x600 resolution , for some of them they can use 1024x768 ,
i've tested all of them to set the best resolution to fit all the screen ,
but as you said lowering it is not a good solution : recent monitors (like mine) do not support the 640x480 (maybe too has been) :pirate:
r0man0
  • 2 months later...
Hi main post updated with newer version :
CHANGELOG :
Version 0.9.3
Added --> MADrigal CD Collection 59.20 Update
(Dungeons&Dragons,DonkeyKongJr,DonkeyKongColeco,GalaxyII)
r0man0
One more game finally upgraded to the new "Standard 4", now featuring larger graphics, improved sound quality, removeable splash screen and full compatibility with MAME cabinets.
Big thanks to René Van Egmond and Rik Morgan for providing photos and scans of the game and manual.
This is the list of new files:
- Snoopy (Nintendo, Panorama Screen) S4/1.03 (Standard 4, complete rewrite)
- MADrigal CD Collection ver. 59.21
- ClrMamePro DATfile ver. 20151116 [59.21]
All files available on the downloads page.
URL: http://www.madrigaldesign.it/sim/
Yes I have setup according the main page. I am on Win 8.1.
Could you send me a screenshot of your Electronic games HYperHQ config ?
I believe the first posts package has a dead link. please reupload? Romano, you are a busy guy!
really ? I've downloaded with that link , no problem...
