doomteam1 Posted July 17, 2015 Posted July 17, 2015 When trying to use hyperspin, i am unable to use Sega Genesis Roms, I can connect MAME just fine, but Gen will not connect. If i use Rom Renamer, it finds the roms and renames them, however if i use list generator it cannot detect the Roms. Inside of Rocketlauncher UI it finds the Roms, but cannot play them. it tells me no preferred controller and no joytokey.ini
SIMPLYAUSTIN Posted July 17, 2015 Posted July 17, 2015 Try that mate. I am not sure about the control and Koytokey.ini errors. have you enabled these but not set them up? Simply Austin's YouTube
doomteam1 Posted July 17, 2015 Author Posted July 17, 2015 i got this far, but they wont start still.b the emulator opens but no game
thcdgaf Posted July 18, 2015 Posted July 18, 2015 Which emulator you using? Sent from my LGL34C using Tapatalk
doomteam1 Posted July 18, 2015 Author Posted July 18, 2015 I've tried both fusion and gens. Any suggestions for one?
gr0bda Posted July 19, 2015 Posted July 19, 2015 On 7/18/2015 at 9:51 PM, doomteam1 said: I've tried both fusion and gens. Any suggestions for one? I just went through it myself. What worked for me was to go to HyperHQ and under Genesis Wheel Settings I checked: "Use Full Path To Roms:" I don't know your setup but maybe, just maybe?
doomteam1 Posted July 19, 2015 Author Posted July 19, 2015 its already set like this. Do you think if i become platinum in the additional forum space they would know?
32assassin Posted July 19, 2015 Posted July 19, 2015 On 7/17/2015 at 8:26 PM, doomteam1 said: When trying to use hyperspin, i am unable to use Sega Genesis Roms, I can connect MAME just fine, but Gen will not connect. If i use Rom Renamer, it finds the roms and renames them, however if i use list generator it cannot detect the Roms. Inside of Rocketlauncher UI it finds the Roms, but cannot play them. it tells me no preferred controller and no joytokey.ini you have a very misleading thread tittle, If you audit your roms with Rocketlauncher UI and if finds its roms; then how exactly is Genesis not finding your roms? you do not have a proper set up under rocketlauncher this is why you are not able to load play your roms. if you post your Rocketlauncher troubleshoot log and hyerspin log, we might be able to pin point your problem.
doomteam1 Posted July 20, 2015 Author Posted July 20, 2015 02:38:01 PM | HyperSpin Started 02:38:02 PM | Going FullScreen 02:38:03 PM | Checking for updates 02:38:03 PM | Update Check Complete 02:38:03 PM | Startup program unavailable 02:38:03 PM | Playing intro video 02:38:11 PM | Error intializing joysticks 02:38:12 PM | Menu Mode is single 02:38:12 PM | Loading Sega Genesis.xml 02:38:13 PM | Sega Genesis.xml successfully loaded 02:38:16 PM | Sega Genesis wheel loaded successfully 02:39:26 PM | Sega Genesis wheel loaded successfully 02:39:28 PM | Sega Genesis wheel loaded successfully 02:39:29 PM | Launching Game 02:39:29 PM | Not using HyperLaunch 02:39:30 PM | Running in normal rom mode 02:39:30 PM | Excecutable is gens.exe 02:39:30 PM | Command Line is: "C:\Emulators\Sega Genesis\gens.exe" "C:\Emulators\Sega Genesis\roms3 Ninjas Kick Back (USA).zip|7z|bin|md" "Sega Genesis" -f "C:\HyperSpin\HyperSpin.exe" -p "HyperSpin" 11:14:14:725 | RL | INFO | +N/A | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com) 11:14:15:041 | RL | INFO | +328 | Main - System Specs: RocketLauncher Dir: C:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 8.1 SKU: Windows 8 Total Memory: 3517.34 MB Free Memory: 1683.35 MB Used Memory: 1833.988 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 2 GPU 1 Name: AMD Radeon HD 8240 GPU 1 RAM: 512.00 MB GPU 1 Driver Version: 13.301.1001.1001 Sound 1 Device: AMD High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: Realtek High Definition Audio Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1360x768 (1360x768 work) [Landscape] (Primary) Current AHK Desktop Width: 1360 Current AHK Desktop Height: 768 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 11:14:15:041 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\RocketLauncher.exe exists 11:14:15:044 | RL | INFO | +0 | Main - 3 Ninjas Kick Back (USA) is being forced via CLI to use the emulator: Gens 11:14:15:044 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Plugins\HyperSpin.plugin exists 11:14:15:045 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 11:14:15:046 | RL | INFO | +0 | Main - RocketLauncher received "Sega Genesis" and "3 Ninjas Kick Back (USA)" 11:14:15:071 | RL | INFO | +31 | Main - Did not find a "C:\RocketLauncher\Settings\Sega Genesis\Game Options.ini" file, skipping any game-specific options. 11:14:15:071 | RL | INFO | +0 | Main - Checking for a [Gens] section in C:\RocketLauncher\Settings\Sega Genesis\Emulators.ini 11:14:15:072 | RL | INFO | +0 | Main - Checking for a [Gens] section in C:\RocketLauncher\Settings\Global Emulators.ini 11:14:15:074 | RL | INFO | +0 | Main - Found [Gens] in C:\RocketLauncher\Settings\Global Emulators.ini 11:14:15:074 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Modules\Gens\Gens.ahk exists 11:14:15:092 | RL | INFO | +16 | Main - CRC Check - CRC matches, this is an official unedited module. 11:14:15:092 | RL | INFO | +0 | Main - 3 Ninjas Kick Back (USA) will use module: C:\RocketLauncher\Modules\Gens\Gens.ahk 11:14:15:141 | RL | INFO | +47 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 11:14:15:147 | RL | INFO | +15 | CheckFile - Checking if C:\Emulators\Sega Genesis\gens.exe exists 11:14:15:150 | RL | INFO | +0 | Main - INI Keys read 11:14:15:150 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.exe exists 11:14:15:152 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.dll exists 11:14:15:162 | RL | INFO | +0 | Main - "3 Ninjas Kick Back (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 11:14:15:162 | RL | INFO | +0 | CheckPaths - Started 11:14:15:163 | RL | INFO | +16 | CheckPaths - Found rom: C:\Emulators\Sega Genesis\roms\3 Ninjas Kick Back (USA).md 11:14:15:163 | RL | INFO | +0 | CheckPaths - Ended 11:14:15:165 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 12 pluginPath = C:\RocketLauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = 1 rlMode = rlTitle = RocketLauncher rlVersion = 1.0.1.2 rlAuthor = djvj rlURL = www.rlauncher.com langFile = C:\RocketLauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = frontendPath = C:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = C: exitEmulatorKey = Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = C:\Emulators\Sega Genesis\gens.exe emuPath = C:\Emulators\Sega Genesis emuName = Gens emuExt = exe romPath = C:\Emulators\Sega Genesis\roms romPathFromIni = C:\Emulators\Sega Genesis\roms romExtension = .md romExtensionOrig = .md romExtensions = 7z|zip|md|bin executable = gens.exe systemDbName = Sega Genesis systemName = Sega Genesis dbPath = dbName = 3 Ninjas Kick Back (USA) dbExt = romName = 3 Ninjas Kick Back (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = C:\RocketLauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = C:\RocketLauncher\RocketLauncher.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 3 logShowDebugConsole = false logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = false rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = Numpad0 originalWidth = 1360 originalHeight = 768 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdAddDrive = true servoStikEnabled = false ledblinkyEnabled = false ledblinkyFullPath = ledblinkyProfilePath = C:\RocketLauncher\Profiles\LEDBlinky ledblinkyRLProfile = C:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoManufacturer = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = C:\RocketLauncher\Media\Fade RLDataPath = C:\RocketLauncher\Data RLMediaPath = C:\RocketLauncher\Media RLErrSoundPath = C:\RocketLauncher\Media\Sounds\Error modulesPath = C:\RocketLauncher\Modules moduleFullName = C:\RocketLauncher\Modules\Gens\Gens.ahk moduleName = Gens modulePath = C:\RocketLauncher\Modules\Gens moduleExtension = ahk moduleExtensionsPath = C:\RocketLauncher\Module Extensions libPath = C:\RocketLauncher\Lib 7zEnabled = false 7zPath = C:\RocketLauncher\Module Extensions\7z.exe 7zDllPath = C:\RocketLauncher\Module Extensions\7z.dll 7zExtractPath = C:\Users\sam\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false pauseEnabled = true pauseKey = ~NumpadAdd pauseBackToMenuBarKey = X pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = C:\RocketLauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = {F5 down}{F5 up} pauseLoadStateKeyCodes = {F8 down}{F8 up} keymapperEnabled = true keymapperAHKMethod = false keymapper = joytokey xpadderFullPath = C:\Utilities\Xpadder\xpadder.exe joyToKeyFullPath = C:\RocketLauncher\JoyToKey_en\JoyToKey.exe keymapperProfilePath = C:\RocketLauncher\Profiles\joytokey keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = joytokey keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = C:\RocketLauncher\Profiles\joytokey\HyperSpin defaultProfile = C:\RocketLauncher\Profiles\joytokey\_Default systemProfile = C:\RocketLauncher\Profiles\joytokey\Sega Genesis xPadderSystemProfile = C:\RocketLauncher\Profiles\joytokey\Sega Genesis\_Default emuProfile = C:\RocketLauncher\Profiles\joytokey\Sega Genesis\Gens romProfile = C:\RocketLauncher\Profiles\joytokey\Sega Genesis\3 Ninjas Kick Back (USA) RocketLauncherProfile = C:\RocketLauncher\Profiles\joytokey\RocketLauncher blankProfile = C:\RocketLauncher\Profiles\joytokey\blank ahkFEProfile = C:\RocketLauncher\Profiles\AHK\HyperSpin ahkDefaultProfile = C:\RocketLauncher\Profiles\AHK\_Default ahkSystemProfile = C:\RocketLauncher\Profiles\AHK\Sega Genesis ahkEmuProfile = C:\RocketLauncher\Profiles\AHK\Sega Genesis\Gens ahkRomProfile = C:\RocketLauncher\Profiles\AHK\Sega Genesis\3 Ninjas Kick Back (USA) ahkRocketLauncherProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe mon1O = pacDrivedllFile = C:\RocketLauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = C:\RocketLauncher\Lib\User Fade Animations.ini 11:14:15:195 | RL | INFO | +31 | BuildScript - Loaded XHotkey Init.ahk scripts 11:14:15:196 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 11:14:15:196 | RL | INFO | +0 | BuildScript - Loaded Pause Init.ahk scripts 11:14:15:196 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 11:14:15:197 | RL | WARNING | +0 | BuildScript - "C:\RocketLauncher\Lib\User Functions Init.ahk" not found 11:14:15:197 | RL | INFO | +0 | BuildScript - Validating module 11:14:15:199 | RL | INFO | +0 | BuildScript - Validation complete 11:14:15:199 | RL | INFO | +0 | BuildScript - Module: MEmu = Gens MEmuV = v2.14 MURL = http://segaretro.org/Gens MAuthor = djvj MVersion = 2.0.1 MCRC = 7B3AF9E0 iCRC = 2805229D MID = 635038268896537774 MSystem = "Sega CD","Sega Genesis","Sega Mega Drive","Sega Mega-CD" ;---------------------------------------------------------------------------- ; Notes: ; For Sega CD, don't forget to setup your bios or you might just get a black screen. ; Fullscreen and stretch are controlled via the variable below ; ; Sega CD & Sega 32X ; Configure your Sega CD bios first by going to Option -> Bios/Misc Files ; Gens only supports bin files for Sega CD, not cue ;---------------------------------------------------------------------------- StartModule() FadeInStart() settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) Stretch := IniReadCheck(settingsFile, "Settings", "Stretch","true",,1) 7z(romPath, romName, romExtension, 7zExtractPath) gensINI := CheckFile(emuPath . "\Gens.cfg") IniRead, currentFullScreen, %gensINI%, Graphics, Full Screen IniRead, currentStretch, %gensINI%, Graphics, Stretch If ( romExtension = ".cue" ) ScriptError("Gens does not support cue files, please use another extension") ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = 1 ) IniWrite, 0, %gensINI%, Graphics, Full Screen Else If ( Fullscreen = "true" And currentFullScreen = 0 ) IniWrite, 1, %gensINI%, Graphics, Full Screen ; Setting Stretch setting in ini if it doesn't match what user wants above If ( Stretch != "true" And currentStretch = 1 ) IniWrite, 0, %gensINI%, Graphics, Stretch Else If ( Stretch = "true" And currentStretch = 0 ) IniWrite, 1, %gensINI%, Graphics, Stretch Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("Gens ahk_class Gens") WinWaitActive("Gens ahk_class Gens") FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() RestoreEmu: Send, !{Enter} Return CloseProcess: FadeOutStart() WinClose("Gens ahk_class Gens") Return 11:14:15:255 | RL | INFO | +47 | BuildScript - Loaded Pause scripts 11:14:15:260 | RL | INFO | +16 | BuildScript - Loaded Multi-Player scripts 11:14:15:266 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 11:14:15:266 | RL | WARNING | +0 | BuildScript - "C:\RocketLauncher\Lib\User Functions.ahk" not found 11:14:15:266 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 11:14:15:272 | RL | INFO | +15 | Main - Module is built 11:14:15:272 | RL | INFO | +0 | CheckFile - Checking if C:\RocketLauncher\AutoHotkey.dll exists 11:14:15:279 | RL | INFO | +0 | Main - Running module
32assassin Posted July 20, 2015 Posted July 20, 2015 where to start Problem 1 Why your Games don't load through Hyperspin I'm assuming you are using Hyperspin 1.3 you have your execution set to normal aka Rocketlauncher is disabled and not being used by Hyperspin 02:39:29 PM | Not using HyperLaunch02:39:30 PM | Running in normal rom mode 02:39:30 PM | Excecutable is gens.exe if this is the case your executable should be Rocketlauncher you either need to run the transition tool or use Ghutchs Script to make Rocketlauncher compatible with Hyerspin 1.3 http://www.hyperspin-fe.com/topic/2187-how-to-install-hyperspin/ Step 5 HyperSpin 1.3.3 Get back in your HyperSpin folder. This time we are gonna do some manual ini editing . Open your Settings folder in your HyperSpin folder C:\HyperSpin\Settings. Find the file named Settings.ini, open it in notepad. you should see at the top a line that reads [Main]. Right up under the [Main] line add Hyperlaunch_Path=C:\RocketLauncher\ . Download this Hyperspin and RocketLauncher Compatibility Fix.zip 289.76KB 406 downloads and extract it into the same folder as RocketLauncher.exe. Run the contained executable once and a new file should appear named HyperLaunch.ini. Open it and set your path to your HyperSpin.exe (C:\HyperSpin\HyperSpin.exe or ..\HyperSpin\HyperSpin.exe). I suggest you go through an install tutorial, I'm not sure you understand how to install hyperspin yet. Problem 2 launching your games with Rocketlauncher the good news, rocketlauncher can find your roms 11:14:15:162 | RL | INFO | +0 | CheckPaths - Started11:14:15:163 | RL | INFO | +16 | CheckPaths - Found rom: C:\Emulators\Sega Genesis\roms\3 Ninjas Kick Back (USA).md11:14:15:163 | RL | INFO | +0 | CheckPaths - Ended11:14:15:165 | RL | INFO | +0 | BuildScript - User Variables: can you disable your keymapper keymapperEnabled = true keymapperAHKMethod = false keymapper = joytokey to remove your controller errors and launch a game with Rocketlauncher to see if you can load your games with rocektlauncehr, because I cant seem to find any problems. your main and probably only problem is getting Hyperspin to use Rocketlauncher.
doomteam1 Posted July 20, 2015 Author Posted July 20, 2015 i did everything this said except delete keymapper, every time i disable it, it goes back to enabled. also every time i open rocketlauncherUI.exe it says update available, but when it tries to update it says there are no updates
doomteam1 Posted July 21, 2015 Author Posted July 21, 2015 i got it to load the emulator and the games now, it was rocketlauncher. however Dons hyperspin list generator will not say i have any roms
